33" + Tire Psi Poll
Discussion in '1st Gen. Tacomas (1995-2004)' started by Stm82, Feb 15, 2018.
What psi do you run in your 33 or above tires?
Poll closed Mar 2, 2018.
  1. 10-20
    0 vote(s)
    0.0%
  2. 20-25
    0 vote(s)
    0.0%
  3. 25-30
    4 vote(s)
    26.7%
  4. 30+
    11 vote(s)
    73.3%
  5. Bought the 100% nitrogen at the tire shop and haven't checked them.
    0 vote(s)
    0.0%
  1. Feb 15, 2018 at 1:13 PM
    Stm82
    Stm82 [OP] BRAAAPPP!!!
    Mb. Canada
    95.5 2.7 5 speed 4x4 reg cab
    33x12.5x15 Nitto Trail Grapplers on M/T 15×8 3.25" Bs 3" Toytech front Mystery add a leaf back with random shocks Bush whacker cutout flares (extra firewall smash) Side dump exhaust Washer fluid relocate 91 (or so) bucket seats and console Twin stick transfer case Toyota elocker
    Just curious havent seen much talk on tire pressures.
    I personally run 25 or 26 psi for general driving and air down if nessisary wheeling. Ran 32psi for about 30 miles when I first put on the 33's and thought I was going to bounce out the window.
  2. Feb 15, 2018 at 2:19 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I usually do 35 in the front and 30-33 psi in the rear. I usually leave them all at 35 though, because I am lazy and don't want to adjust the air pressures after rotating tires.
    That being said, a chalk test would be the best way to decide what PSI to run at. Also what your tolerance for MPGs is, if you consider that as a personal factor. Each vehicle's weight will differ depending on gear and stuff, so optimal psi could vary from truck to truck.
    02hilux likes this.
  3. Feb 15, 2018 at 3:34 PM
    02hilux
    Planet: EARTH
    Chalk test, you'll find your answer
    COMAtized99 likes this.
  4. Feb 16, 2018 at 10:54 AM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    To have mine wear properly I have to have 32 front 34 rear. Anything more will wear the center too much and anything less will wear the outside too much
  5. Feb 16, 2018 at 10:59 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    25-26 seems pretty low for street driving. Anything under 30 psi and I feel like I'm steering a boat on the street...I usually keep mine between 32-35 for daily driving.
    Offroad sort of depends on the terrain, but 15 - 18 psi is the sweet spot for good traction and a softer ride, I've found. Gone as low as 6 psi in the sand to get unstuck but quickly aired back up when I was out of it.
    I have E rated KO2s for what it's worth. When I first got them, the shop had them at 40 psi and I thought I was going to die on the freeway ride home, the back end was so jarring and bouncy.
  6. Mar 9, 2019 at 4:07 PM
    Bartlett18
    Bartlett18 Well-Known Member
    Edmonton, Alberta, CANADA
    2009 Silver Tacoma ShBx DBLC 4X4
    3"Lift, 285/70/17, OVTune, fog light mod, oil, volt, vacuum gauges, map light mod, RI light bar/pods, Leer 100XQ, bedliner lights, LR UCAs, Rear airlift bags, tinted side windows, XD Revolver rims, colour coded door protectors, 100/90 headlight bulbs and harness, 65 fog bulbs and harness, side splitter mirrors, Bilstein 5100s, OME 887 springs, 4:30 gears, TruTrac, Hurst/Core short shifter, CC grill,
    I have P285 70 17 (so, almost 33). I have tracked my air pressure over the last 9 years, anywhere from 25 psi to 31 psi and have found that my truck feels best at 26 psi in all four tires. Chalk test yielded 27, but I like the ride better at 26. There's less "jolting" over frost heaves and road imperfections. Anything over 27 for any period of time started to wear out the middle of the treads on my truck.
    285 70 17 -12 offset 4.5 BS
  7. Mar 9, 2019 at 4:47 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    A lot of this is going to depend on the load range of the tires. C's will run at a lower PSI than E's for instance. Likely also the wheel diameter.
    So, for a valid comparison, folks need to put in the tire size they are running as well as it's load range.
    Personally, I'm running 255/85R16 Cooper ST Maxx at 40psi on-road, and go to 16-18psi aired down on the trail.
