33 inch tires; what offset? do I need to trim with my current setup?
Discussion in 'Wheels & Tires' started by 2011trdsportmg, May 8, 2023.
  1. May 8, 2023 at 7:42 AM
    2011trdsportmg
    2011trdsportmg [OP] Member
    Tommy
    CT
    2017 TRD Off Road
    Falken Wildpeak AT4W 265/75R16, Baja Designs Squadron SAE Fog Lights
    Want to upgrade to 33 inch tires, will be going with a 2.5 inch Bilstein 6112 lift. I have a steel front bumper and currently have 275/65/r18. is a cab mount chop necessary? I will only be doing mild offroading
  2. May 8, 2023 at 8:19 AM
    Wayfaring Stranger
    Wayfaring Stranger Active Member
    Ken
    The Woodlands
    2014 FJ Cruiser/2015 Taco/2017 Rav4
    I just went to a 285/70/17, and I already know the mud flaps have got to come off. Everything else seems to be rub-free, but I'll be doing a full wheel alignment, especially caster and camber, before removing anything. I'm running 6112s also, but only with 1.5 lift to level out the 5160a and Alcan 1"springs in the rear.
  3. May 8, 2023 at 8:22 AM
    lilyota12
    lilyota12 Well-Known Member
    Shredona
    2012 Tacoma DCSB 4.0 TRD Off-Road
    See Build Thread
    I can tell you with my current setup of Camburg UCAs, SCS wheels, 285/75/16 and a 2.5" lift you'll need to remove the mudflaps, CMC, pinch weld and buy a rotary tool :)
    I only rub at a full stuff now or when cranking the wheel in reverse. If you get SPC UCAs you can offset some headaches if not most.
    2011trdsportmg[OP] likes this.
  4. May 8, 2023 at 8:30 AM
    Slick Taco
    Slick Taco Id Rather Be Airborne
    Lost somewhere in the PNW
    Current vehicles: 2019 Rav4 Lunar Rock. 2018 TRD OR DCSB KD Max tuned. 2010 Tundra Limited Crew Max . 1991 4Runner Crawler. Ivan Stewart Edition
    KD Max Tune, King 2.5 coil overs T.C. UCA's, Deaver leafs, 17x9 Black Rhyno Warlords, 33" Toyo M/T's, Metal Tech rear bumper, Westin HDX drop steps with Bullet Liner coating, K&N CAI, Baja Designs fog pods, Rigid Midnight addition 3" pod ditch lights. Cali Raised brackets and 32" behind the grill mounted light bar, Southern Style Offroad Lopro Stage II front bumper, Warn winch, FACTOR 55 Ultra Hook, FACTOR 55 Hawes Fairleed, full debadge, Cosmetic goodies such as 15% carbon tint, matte black in channel rain guards, interior LED's, Teton Workshop shift knob, Inferno vinyl detailing on the interior, Cali Raised multi rocker switch cubby insert with Mc Tuning LED switches and a few other mods I've probably left out.
    As stated above you will most certainly need a CMC, pinch weld fold, and possibly some trimming of the wheelwell liners. I'm running -12 offset but I believe even guys running 0 or better offset still need a CMC and pinch weld fold
  5. May 8, 2023 at 8:39 AM
    Clearwater Bill
    Billy
    Largo Florida
    33 is just a dia
    The tire specs and wheel fitment matter. A lot.
    You can run 33 on stock suspension with no rubbing with the right combo.
    98_3RZ_NIC and tcjacado like this.
  6. May 8, 2023 at 9:03 AM
    2011trdsportmg
    Tommy
    CT
    2017 TRD Off Road
    going to pair them with method 305s will those make a difference
  7. May 8, 2023 at 10:12 AM
    Wayfaring Stranger
    Ken
    The Woodlands
    Mine are on Rough Country 17 x 9 steelies, -12 offset.
  8. May 8, 2023 at 10:21 AM
    2011trdsportmg
    Tommy
    CT
    2017 TRD Off Road
    any rubbing or have you done any cutting/trimming?
  9. May 8, 2023 at 10:37 AM
    Wayfaring Stranger
    Ken
    The Woodlands
    Just did the install this morning, and, so far the only chatter I get is from the mudflaps. I do not drive this truck much right now because I am still in the "build" stage, but a full suspension set-up is in the near future. I MIGHT go with the SPC UCAs just for the adjust-ability
