33’s vs. 35’s - opinions??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TheGreatWhiteBuffalo, Apr 9, 2020.
  1. Apr 9, 2020 at 8:47 AM
    TheGreatWhiteBuffalo [OP] Well-Known Member
    2016 Tacoma TRD Off-Road
    Hey guys, wanted to open up a thread for discussion on 33” vs 35” tires.
    Let’s go for the average Joe usage... daily driver, some off-roading, some overlanding.
    What are you guys running? Do you want to go bigger/smaller? Was it worth the extra money/work for 35’s? Do you actually get a lot more performance out of 35’s or mpg out of 33’s?
  2. Apr 9, 2020 at 8:51 AM
    Bannerman
    Bannerman Tasteful Thickness
    Johnson
    Charlotte, NC
    22 Tremor 402A, 22 T4R ORP
    33s, close the thread.
  3. Apr 9, 2020 at 8:52 AM
    Savoia
    Savoia Well-Known Member
    Ray
    2018 Quicksand Tacoma TRD Sport 4x2 DCSB
    35s if you wanna cut a shit ton, regear for a lot of money, and still have bad mpg. But you'd look cool as hell in the end :)
  4. Apr 9, 2020 at 8:53 AM
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    Want vs need discussion here
  5. Apr 9, 2020 at 8:54 AM
    Savoia
    Ray
    And we don't need any of this stuff that we all do to our trucks haha:rofl:
  6. Apr 9, 2020 at 8:55 AM
    EubeenHadd
    EubeenHadd Bit of a derp
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    Encounter AT 32", OME 90021/885+63005/895
    Skinny 33's fit stock rigs, I see no reason to go bigger unless you get beyond moderate offroading.
  7. Apr 9, 2020 at 8:56 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    I don't see 35s to be worth it considering the amount of cutting you gotta do to actually make them fit.
    They sure do look bad ass though
  8. Apr 9, 2020 at 8:57 AM
    deuceb
    deuceb Well-Known Member
    Denver | Austin
    2018 Taco BBPDCLBTRDOR | 2004 MB SL55 | 86 VW GTI
    33's. 35's just aren't worth it if you do some research, you might as well go 37's. Either way you should plan a regear to 5.29's in the budget too.
  9. Apr 9, 2020 at 8:58 AM
    I’ve had two 3rd gen tacos, one on 33’s with a good amount of weight, mostly overlanding and some moderately technical terrain on a 2” lift. My experience is that I did find some limitations where bigger tires would’ve helped.
    Got another truck with a 6” lift (to clear tires) and 35’s. No armor, no gears. I noticed a big difference with my approach/departure angles with the added height, but only had a minor increase in traction (if I could even tell at all)
    The big surprise was actually mpg... after corrections for size difference, I got about 17mpg hwy on 35’s and 17.5mpg on 33’s with no armor. City mpg was garbage on the 35’s but a little better on 33’s
  10. Apr 9, 2020 at 9:19 AM
    Ariyan
    Ariyan Well-Known Member
    NM
    4x4 TRD Sport
    SAS, 40s, and some armor.
    I agree with this, I know I'm in a second gen but close enough. If I went back with the amount of cutting/banging I did for 35's I would have just gone to 37s and tubbed the front, but I'm not one for advice, Im ramping for a SAS and 40s. :rofl:
  11. Apr 9, 2020 at 9:33 AM
    Clearwater Bill
    Billy
    Largo Florida
    Your usage description is the key.
    You don't even 'need' 33s. And if I'm wrong, skinnies on OE wheels don't require any suspension work, cutting or trimming.
  12. Apr 9, 2020 at 9:46 AM
    EubeenHadd
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    I forgot to mention, my MPG's improved measurably by going to 255/85R16's, but I'm driving a 6speed truck and can keep my foot off the skinny pedal, so the longer ratio outweighs the extra weight. Your mileage may literally vary.
  13. Apr 9, 2020 at 9:47 AM
    NWTacoTime
    NWTacoTime Well-Known Member
    Nate
    WA - Seattle/Kent
    Cement SB 2019 TRD offroad -
    Car Seats
    prob just run 33s or if you like a slightly bigger look you could do 34s .
    33s depending on your offset you prob wont need a CMC.
    DevilTaco4 likes this.
  14. Apr 9, 2020 at 9:49 AM
    badkids
    badkids Well-Known Member
    ‘83 Hilux with a 2JZ
    It’s not about how big, it’s about how wide. That’s what the I’ve been told over the years. Ladies like ‘em wide.
    crhsharks12 likes this.
  15. Apr 9, 2020 at 10:06 AM
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    35s/thread
    strongrob likes this.
  16. Apr 9, 2020 at 10:08 AM
    DevilTaco4
    DevilTaco4 Well-Known Member
    Folsom, CA
    2017 SR Access 5MT
    Up until a week ago I REALLY wanted 35s - did all the necessary cutting short of beating back the firewall or tubbing (which I would have ended up doing).
    Then I started looking at true measurements and noticed how most of them being 315s really run ~34.5ish like the STT Pros I wanted. Made me switch things up and decide to run Toyo 285/75/17 which is a true 34”. IMO, rather have the almost as tall tire that is much more narrow - a lot less stress on steering rack and wheel bearings
    Only time 12.5” wide tire would make sense to me would be 37s - and by then I’d probably sas (if 3rd gen kits come out by then).
    Shellshock likes this.
  17. Apr 9, 2020 at 10:20 AM
    Woodrow F Call
    Colorful Colorado
  18. Apr 9, 2020 at 10:23 AM
    monkeyevil
    monkeyevil Victory 4x4
    Daryl
    Kalamazoo, MI
    35's look cooler in my opinion, open up some trail and obstacles for sure. 33's are way easier to fit, drive daily, deal with in general... Unless you are wheeling some serious trails 33's and a locker will be plenty.
    I like 35's tho :D
  19. Apr 10, 2020 at 10:53 AM
    Nice. I like the stuffed look too. I totaled my truck so I’m gonna start another build soon. I’ll probably do BP-51’s with SPC UCAs and a bumper to push the tire forward, CMC/relocation and gears to run 35’s (After reading everyones opinion though I’m kinda rethinking... 34’s might be the best balance). My problem is that I’m in CA near Tahoe and a lot of trails can have some decent gatekeepers. My favorite trail is more of a “Jeep on 35’s trail”... but I make it work with steel skid plates and a lot of wood stacking/Maxtrax lol.
  20. Apr 10, 2020 at 11:12 AM
    EubeenHadd
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    So by some offroading, you mean serious offroading. 35's then, duh.
