30-pin built in
Discussion in 'Audio & Video' started by ryrydtl, Oct 21, 2012.
  1. Oct 21, 2012 at 1:11 PM
    ryrydtl
    ryrydtl [OP] Well-Known Member
    Cailifornia
    2019 Tacoma Pro
    I got board today and was tired of having to put my iphone in my glovebox where my headunits 30-pin connector is. Soo, i decided to make use of a empty switch cover and a Cablejive dockXtender
  2. Oct 22, 2012 at 10:01 AM
    TurboGT
    TurboGT Stirring the pot since...
    Gabe
    Portland
    '16 Inferno DC LB 4x4
    None yet, starting over!! OME lift w/ Dakars & 885's Remote Start w/ window control
    that is effin brilliant.... since it looks like you've got good access to tools needed to do this, can I send you a blank of mine and some $$ and have you cut one for me too??
  3. Oct 22, 2012 at 10:02 AM
    4x4jeep
    4x4jeep Well-Known Member
    Kyle
    Destin FL.
    does it stay connected fine?
  4. Oct 22, 2012 at 10:05 AM
    benbacher
    benbacher Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    I don't get it. Doesn't look like a phone would fit there sideways? :notsure:
  5. Oct 22, 2012 at 10:09 AM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    So do you just stick your phone or ipod on there? Or is there a female to male 30 pin cord that you plug into it?
  6. Oct 22, 2012 at 10:12 AM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Seems like the phone will fall off the connector at every bump in the road.
  7. Oct 22, 2012 at 10:13 AM
    benbacher
    Anchorage, AK
    ^that would make sense. I've just never seen one of those cords work. Maybe he's got the iPhone 5 and uses the adapter to another charging cable? Man it sure is fun to speculate. Haha I bet we're all wrong.
  8. Oct 22, 2012 at 10:15 AM
    benbacher
    Anchorage, AK
    He says he uses this right in the OP. whoops.
  9. Oct 22, 2012 at 10:17 AM
    akaryanreynolds
    akaryanreynolds STRIKER TRD
    Los Angeles
    2012 DCLB MGM TRD Sport 4x4
    Debadged, Tint, Euro Antenna, OEM Roofracks, OEM skid plate, SMD LED interior lighting, AFE ProDry Drop-in, FX-R 6000K headlights w XB halos, VHT taillights, Fog light mod, Flyzeye V2W, T-Rex T1 Eyelids by Toyota Man, King 2.5 resis Front and Back, Devil Horns by Andres, Redline Hood Struts, PIAA 2500K H11 Fog Bulbs, Escort 9500ix, Ultra Gauge, Cobra 75 WXST, Firestik II w/ Quick Disconnect & Spring
    :facepalm: You do know they changed the port
  10. Oct 22, 2012 at 10:30 AM
    evanmb31
    evan
    connecticut
    09 trd off road
    Is that what you call a cablelive dockXtender? I looked for one of these for awhile, i thought he was talking about one of those little extenders that is like an inch long for docks so you can use them with an otterbox
    Edit: googled, yep thats what it is. Did this exist 6 months ago because i searched online for awhile trying to find this cord so i could do exacty what the OP did
  11. Oct 22, 2012 at 10:32 AM
    TurboGT
    Gabe
    Portland
    I've got a nano that I take in and out of the truck constantly, and having a setup like this would be awesome, just snap it into place, and "yank" it off when I need to.
    Besides, I don't believe there's enough room where the connector is at to actually put the phone there.
  12. Oct 22, 2012 at 10:54 AM
    ryrydtl
    Cailifornia
    2019 Tacoma Pro
    yeah my cablejive dockXtender is 2ft long. so i just plug it into the port i made and i have 2ft to move my phone around. i just wanted a cleaner install than what i had before in my glovebox. My head unit only has a 30-pin connector, no lightning yet. I plan to take out the stock AUX jack in that same row and put a lighting plug just like how i installed the 30-pin once i decide to trade in the 4s.
  13. Oct 22, 2012 at 11:19 AM
    evanmb31
    evan
    connecticut
    09 trd off road
    ^+1 for you, that came out so clean. I wanted to do this months ago but i couldnt find that cord. I will probably attempt it by drilling two holes for the ends and cutting inbetween them with a dremel. I actually have a cnc, but its a poor mans DIY cnc made for carving wood.
  14. Oct 22, 2012 at 11:46 AM
    ryrydtl
    Cailifornia
    2019 Tacoma Pro
    It makes everything much cleaner! And to be honest drilling and using a file would work just as well. My cnc didn't cut deep enough so I filed like crazy. It was a tight fit to make the male end of my cable fit. I just filled the back with plastic epoxy.
  15. Oct 22, 2012 at 11:49 AM
    ryrydtl
    Cailifornia
    2019 Tacoma Pro
    One thing that is important is to find a cable that dosnt lock to your device. It took a lot of returning cables that weren't true 30-pin. Meaning they would only have some of the wires that would only charge a device and not transfer all the data video/audio/power.
  16. Oct 22, 2012 at 11:52 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I think I would have kept the 30 pin behind the dash and ran the dock extender into the cubby below the radio. It would stay coiled there when not in use and you wouldn't have any protrusions from the dash. Not trying to bash at all, overall I like the idea, just would have executed it differently and possibly giving others a different spin for their project :eek:
  17. Oct 22, 2012 at 12:01 PM
    ryrydtl
    Cailifornia
    2019 Tacoma Pro
    Everyone has there different needs for different applications. I still have the connector in my glovebox too if I ever need it. But this way if I'm not using the cable from the plug I installed I just coil it up and it goes in my center council
  18. Oct 22, 2012 at 12:06 PM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    Haha this is the first thing I thought of too.
  19. Oct 22, 2012 at 12:14 PM
    ryrydtl
    Cailifornia
    2019 Tacoma Pro
    I just can't seem to spend the money for 5 instead of 4s :/ I'm going to install a lightning plug but I'm not sure if head units interface to them yet
  20. Oct 22, 2012 at 12:17 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    Hmmm ya good point, i didnt think of that. the cord i have does lock on. But thats the only cord i can use with my headunit if i want video as well as audio and charge. Maybe i can modify it or use something to keep the little clips pushed in so it always stays unlocked.
    Edit: thinking out loud here, but since my cord locks...Maybe i can get one of those little dock extenders, the one with no cord that are designed for docks and iphones with cases. Then i can cut the dock extended in, plug my head unit cord into the back, and the male to female cord into the front....ok problem solved, probably didnt need to share that lol.
