3 way OEM switch for lightbar
Discussion in 'Lighting' started by medic7556, Mar 10, 2021.
  1. Mar 10, 2021 at 2:38 PM
    medic7556
    medic7556 [OP] Well-Known Member
    Blue Ridge, Ga
    17 MGM Tacoma SR5 4x4 DCSB
    I am about to install a 20 inch rough country dual row light bar with amber DRL. The lightbar comes with a round 3 way switch but I am wanting to use an OEM style 3 way switch. Any recommendations on a 3 way switch. If I cant find an OEM 3 way switch, can I use 2 OEM switches using one for the lightbar and one for the DRL. Anyone that has the black series rough country lightbar with DRL how did you wire it in? Thanks.
  2. Mar 13, 2021 at 11:33 AM
    swils
    swils Well-Known Member
    Maryland
    2018 OR Blazing Blue, MT
    Looking for something similar, would be interested to hear/see what you end up going for
  3. Mar 13, 2021 at 4:58 PM
    ljh824
    ljh824 Regular Guy
    Lou
    Kabul, Afghanistan / Oviedo, Florida
    -21 AG Sport 4x4 DC
    Just did mine today, and wondering the same damn thing. Looking online everywhere, so I'm in for responses also.
  4. Mar 18, 2021 at 6:34 AM
    caribe makaira
    Caribbean, Puerto Rico
    https://www.anytimebackupcamera.com/collections/switches/products/a-b-light-switch-toyota
    Puppypunters idea hole
    The light bar instructions do not state any info on having both lamps ON, but the fact that they provide a either/or switch makes it obvious that the switch substituting theirs should be of same type. The switch on the links does not preform in such a way, but may be used as long as the operator is aware.
    ljh824 and medic7556[QUOTED][OP] like this.
  5. Mar 19, 2021 at 12:38 PM
    swils
    Maryland
    This has potential. Now that one's got 4 plugs, the 3-way switch I've got only has 3 wires. Presumably one of them's for the backlight? I'm electronically illiterate and don't know how I'd plug the two together
  6. Mar 19, 2021 at 1:13 PM
    squarenone
    squarenone Well-Known Member
    SoCal
    2018 TRD OR 4x4 6sp-mt
  7. Apr 23, 2021 at 8:48 AM
    Toolndie7
    Toolndie7 Well-Known Member
    2019 Sport DCSB Cavalry Blue
    Im waiting on this same light. I was thinking toss the RC harness and use a single pole double throw relay would be the way to go. Tap into the running light circuit to turn on DRL, and use an OEM style switch. When switch is flipped it would automatically switch relay to turn off the DRL and switch on the LED if Im picturing this correctly.
  8. Apr 23, 2021 at 8:54 AM
    ljh824
    ljh824 Regular Guy
    Lou
    -21 AG Sport 4x4 DC
    If you can figure this out, and actually make it work, adult beverage is on me!!
  9. Apr 23, 2021 at 8:58 AM
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    Auxbeam light controller
  10. Apr 23, 2021 at 9:01 AM
    ljh824
    ljh824 Regular Guy
    Lou
    -21 AG Sport 4x4 DC
    That is absolutely a possible solution. I think the question we're trying to solve on the Rough Country lights, is the integrated DRLs. With the wiring harness they provide, it's either the LEDs, or the DRLs. What we want to do, is tap into the existing DRLs in the headlights, and have the DRLs come on when they come on, and have the capability to turn on the actual LED bar with a separate switch. the Rough Country harness only has 3 wires. DRL, off, LED. you have to actively turn on the DRL. Last time I did that, i left them on all night.
    TomTwo[QUOTED] likes this.
  11. Apr 23, 2021 at 9:06 AM
    medic7556
    Blue Ridge, Ga
    I use the below switch. I installed it on the left side of steering wheel below the cubby hole. It has 5 wires and the light bar has 3 if I remember correctly. Spliced them together. Ran the ground to a nut that secures the fuse box under the dash. Left the dash light wire disconnected since the light will remain on if connected directly to the battery. You can connected it to the ignition switch but that above my expertise. The way my buddy and I wired it up there is not back light on the button unless the buttons are switched on. Top button works the lightbar bottom works the DRL.
    ljh824 likes this.
  12. Apr 23, 2021 at 10:03 AM
    Toolndie7
    Seems pretty straight forward. A regular single pole single throw relay that gets turned on by running lights, then that passes power onto the single pole double throw relay which will default to the lightbars DRL at rest and when energized by an OEM style switch will flip flop and turn on LED while DRL is off. When tail lights are off nothing works.
  13. Apr 23, 2021 at 10:19 AM
    caribe makaira
    Toolndie7[QUOTED] likes this.
  14. Apr 23, 2021 at 10:45 AM
    TomTwo
    Bill
    I-85 Southbound
    Take and make an extra ground wire from the ground wire on the light. Then you will have two positive wires and two ground wires and then you can wire them to any kind of switch or DRL etc.
  15. Apr 23, 2021 at 11:22 AM
    caribe makaira
    Extra ground FROM the light bar...WTF4?
  16. Apr 23, 2021 at 12:18 PM
    TomTwo
    Bill
    I-85 Southbound
    You need a ground to go to each switch or tap on another light. The light bar has two positive wires and one ground wire you will need to create an additional ground so that the lights in the light bar can act independently from each other
  17. Apr 23, 2021 at 12:21 PM
    caribe makaira
    That's big NFWD. The internal circuit in the light bar shares the ground, splitting the ground after does nada...It does not split the circuit as you stated.
  18. Apr 23, 2021 at 12:23 PM
    TomTwo
    Bill
    I-85 Southbound
    You have to split the ground if you are using two different switches
  19. Apr 23, 2021 at 12:25 PM
    caribe makaira
    I think you are confusing switch with light bar...
  20. Apr 23, 2021 at 1:22 PM
    ljh824
    ljh824 Regular Guy
    Lou
    -21 AG Sport 4x4 DC
    The intent would be to wire the Light bar DRLs, with the truck's DRLs. Then wire the LEDs to a switch. If you T-Tap into the DRLs (if that is even possible), would you need the extra ground?
    TomTwo likes this.
