3 link vs 4 link
Discussion in 'Solid Axle Suspension' started by ZRTX, Jul 31, 2020.
Which one?
  1. 3 link
    62.0%
  2. 4 link
    38.0%
Multiple votes are allowed.
  1. Jul 31, 2020 at 7:44 AM
    ZRTX
    ZRTX [OP] Well-Known Member
    Des Moines Iowa
    What is a better front setup for a solid axle swap that will be used for rock crawling and some street driving? I'm looking at either a rock slayer offroad 4 link or a rock solid toys 3 link. Axle wise I'd probably us a dana super 60 out of a f550. The vehicle is a 2nd gen tacoma regular cab.
  2. Jul 31, 2020 at 7:52 AM
    81Trekker
    81Trekker Well-Known Member
    La Jolla SD
    81 Trekker and 2015 CCSB Tacoma
    Too many to remember
    On what vehicle? A true 4 link is very tricky unless you push the motor way back to clear the upper links.
    3link with a panhard is much easier but doesn’t cycle as clean as a true 4 link. Either way the axle hitting the oil pan will be the limiting factor on wheel travel.
    desertjunkie760 and Ritchie like this.
  3. Jul 31, 2020 at 8:31 AM
    ZRTX
    Des Moines Iowa
  4. Jul 31, 2020 at 9:10 AM
    81Trekker
    La Jolla SD
    Stick with a 3 link/panhard setup so you can get a little bit more uptravel and use a steering box. A true 4 link will be a nightmare. As someone who does this for a living I would want nothing to do with trying to 4link the front of a Tacoma
  5. Jul 31, 2020 at 10:18 AM
    v5ensx
    v5ensx CARB legal is not CALI legal
    The only kit that will require a 3 inch body? LMAO
  6. Jul 31, 2020 at 10:20 AM
    ZRTX
    Des Moines Iowa
    What do you mean?
  7. Jul 31, 2020 at 11:23 AM
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    3” body lift.
    If the solution requires a 3” BL, you may want to rethink the problem.
    dfanonymous likes this.
  8. Jul 31, 2020 at 11:26 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    RST all day i would not trust the cockslayer kit.
    Philthy_taco, Ritchie and slander like this.
  9. Jul 31, 2020 at 11:28 AM
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    May want to do a lot more research on the rock slayer (cockslayer) kit. Google it with pirate4x4 after and look at the Toyota groups on Facebook. Horrible geometry and link design etc.
    me personally going with 3 link and doing hydro assist if you plan on street driving at all.
    Ritchie, slander and jubei like this.
  10. Jul 31, 2020 at 11:30 AM
    v5ensx
    Yep, known an cockslayer for a reason.
    malburg114 likes this.
  11. Jul 31, 2020 at 1:58 PM
    02hilux
    Planet: EARTH
    They call it the 3" FRAME DROP, not body lift. Funny. Their kit doesn’t throw off your center of gravity and allows more clearance underneath your vehicle. Plus this will makes your vehicle easier to work on and not have to cut your body for clearance.
    Ha Ha Ha
    slander and malburg114 like this.
  12. Sep 28, 2020 at 7:28 PM
    ToyotaRoamer86
    ToyotaRoamer86 Well-Known Member
    Brandon
    Frisco, CO
    2007 Tacoma TRD Sport
    3 Link, all day! For sure on a 2nd gen taco, Here is mine!
    SR-71A, kingk0ng and malburg114 like this.
  13. Sep 30, 2020 at 1:33 PM
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    Wyatt rocks.
    He's currently building my rear 3 link kit.
    Can't wait.
  14. Sep 30, 2020 at 1:48 PM
    ZRTX
    Des Moines Iowa
    How much does it cost for the RST ultimate package?
  15. Sep 30, 2020 at 2:45 PM
    Ritchie
    Describe 'ultimate'. F&R?
  16. Sep 30, 2020 at 2:54 PM
    81Trekker
    La Jolla SD
    I gave up on solid front axles and lack of up travel
  17. Sep 30, 2020 at 2:56 PM
    t.hornstra
    t.hornstra Well-Known Member
    Ted
    NorCal
    White with 4 wheels
    Little this. Little that 4x4 Swap’d PreRunner
    like the ‘beast’ treatment? Probably Take a second mortgage out.
    @jAndyMendo ‘s is at RST for a full build. He may be able to give more insight.
  18. Sep 30, 2020 at 3:32 PM
    ZRTX
    Des Moines Iowa
    Sorta
  19. Sep 30, 2020 at 3:33 PM
    ZRTX
    Des Moines Iowa
    The RST Three link kit starts with the basic Bracket kit all the way up to the Ultimate kit which has everything from the axle, links, joints, steering, brackets, frame plating, hardware, etc.
  20. Oct 1, 2020 at 1:05 PM
    ToyotaRoamer86
    Brandon
    Frisco, CO
    Good luck on getting your parts.. Just my 2 cents.. It 11 months and a fuck ton of phone calls..
