3 inch front, 1.5 rear lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by machotaco2012, May 27, 2016.
  1. May 27, 2016 at 8:24 PM
    machotaco2012
    machotaco2012 [OP] Well-Known Member
    •3” front blocks •2” steel rear blocks •1.25" spidertrax spacers for clearance •285/70/17 (33's) Ko2's •20% tint
    For sure putting a 3 inch lift in the front but undecided what to put in the rear. Probably go with 1.5 inch blocks. Does anyone have pictures of this?
  2. May 27, 2016 at 8:26 PM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    I'd go with a add a leaf. Blocks just are horrible. wheelers single add a leaf is like $80, cheaper then blocks and u-bolts.
    Desert fan 55 and ChadsPride like this.
  3. May 27, 2016 at 8:51 PM
    BigOlBish
    BigOlBish Member
    Jake
    2005 White AC TRD OR 2wd
    4" Max Trac Spindle 2" leaf block
    4" front and 2" rear. Not quite the same lift but basically what it would look like if you went 3" front 1" rear. Looks level to me idk. Also I used rear blocks and they were only $51 before tax, so an AAL isn't cheaper.
    Sterling_vH111 and ChadsPride like this.
  4. May 27, 2016 at 8:55 PM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Blocks are horrible, my strong advice is steer clear of them. Do yourself a favor and spend a little more money. Icon progressive aal. It'l lift your rear 1.5. I believe wheelers sells a progressive aal also which is the same thing.
    Desert fan 55 likes this.
  5. May 27, 2016 at 8:56 PM
    RogueFuel
    RogueFuel Well-Known Member
    If you want upgraded suspension but don't need a full race set up, go with bilstein 5100s all around, old man emu 887 coils up front and a progressive 3 leaf aal in the rear.
  6. May 27, 2016 at 9:00 PM
    machotaco2012
    To get the 4 inch front did you put new shocks or just add a block?
  7. May 27, 2016 at 9:03 PM
    RogueFuel
    If you're going to do 4 inches of lift, your going to need more than just new shocks and coils....
  8. May 27, 2016 at 9:05 PM
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    You'll need 4" spindles. But I believe you can only install those on a 4x2 and not a 4x4....I could be wrong on that one. If you hit the 3" Mark or above you'll more than likely need uca's too.
  9. May 27, 2016 at 9:10 PM
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    My honest suggestion for you is take the time read and research what you should get. There's a ton very useful information on this site. When I give advice it's usually because I've done it before. I've now had 4 tacomas lifted 4 different ways. Aside from that.....steer clear of spacer lifts on your coilovers and blocks on your rear springs...
    Naveronski and Sterling_vH111 like this.
  10. May 27, 2016 at 9:23 PM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    3" Fox shocks/coil overs and airbags.
    bama trd likes this.
  11. May 27, 2016 at 9:25 PM
    Mully
    CA
    SPC LR ARMS.
  12. May 28, 2016 at 6:02 AM
    lawrenccar1
    lawrenccar1 Well-Known Member
    Springfield, Virginia
    2015 4x4 DCSB TRD Off-Road
    3" toytec lift with 2" AAL.
  13. May 28, 2016 at 6:17 AM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    Blocks aren't the most horrible scourge to ever hit the planet. They aren't the best option, but not horrible.... That said, the shorter the block the better off you'll be. The higher you "block" a vehicle, the more apt you are to get axle wrap. 1" seems to be about the magic number with anything I've ever dealt with. Problem is, the STOCK LEAF PAC is junk for the most part. AAL's are better and with various types of AAL's, even better yet. You still have that weak stock leaf pac at the heart of your rear suspension. I'm running a 2" Deavers AAL from Headstrong Offroad. It does what I wanted. A little better load capacity....not a ton, but enough. I got a full 2" lift. Ride is balanced between front and rear at highway speeds. I'm using OME 885X's on the front. Better YET is full leaf pac's. In time, I'll probably move to OME Dakars.
    BigOlBish and Mully like this.
  14. May 28, 2016 at 3:00 PM
    BigOlBish
    BigOlBish Member
    Jake
    Used max tracs spindle, they're only for 2wd. Regarding blocks it's up to you. if you're going to offroad or haul a lot of stuff then I'd suggest AAL or a new leaf pack but if not blocks are fine. I'm only 20 and my dad has an f250 for if we ever need to haul a whole lot of stuff so I wasn't too worried about the blocks. Up to you who to believe if they're bad or not, just make sure if you do get them get tapered ones to avoid axle vibration
  15. May 29, 2016 at 7:34 PM
    Eric J
    Eric J Well-Known Member
    Ponte Vedra Beach
    2008 MGM dcsb 4x4 Trd sport debadged
    To many to name
    Will 3/1 level it out or 3/2?
  16. May 29, 2016 at 7:52 PM
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    3/2 will level it out.
  17. May 29, 2016 at 7:53 PM
    Eric J
    Ponte Vedra Beach
    To many to name
    I had a 3/1 lol and it was squatting alittle bit and I just put 2in blocks on and it sits A lot better
  18. Aug 5, 2016 at 7:06 PM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    What about with a 1st gen? I have 3" Eibach coils in the front w/ adjustable 5100's on the bottom setting and Camburg UCA's. I am looking to get the Headstrong off road progressive 3 leaf AAL pack. It says it will lift the rear of your truck 2.5" w/ the overload and 2" without. I plan on taking the overload out. I currently have a 1.5" AAL with the OEM leaf pack that has 245,000 miles. My question is should I go w/ a 2" Prigressive 3 leaf pack or a progressive 1.5" AAL pack. I just don't want a raked truck and Headstrong off road has a great price w/ free shipping. But I don't want the back to be higher than the front. Should I go with the 3" in the front I already have and the 1.5" leaf pack or will it be better to do the 2" leaf pack? Overload spring taken out for sure. I can't decide or find any threads on it beside this one which isn't helping much since most on here are 2nd gens
  19. Aug 6, 2016 at 1:30 AM
    Desert fan 55
    Desert fan 55 Active Member
    Dave
    Great thread, I am learning a lot from you guys. I am going with AAL over blocks. :dancingbacon:
