3.5L turbo kit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ahelms114, Apr 28, 2022.
  1. Apr 28, 2022 at 4:36 AM
    ahelms114
    ahelms114 [OP] But did you die?!?!?!
    Andrew
    Robertsdale, Alabama
    2021 Tacoma TRD Sport
    6.5" Maxtrac Spindle lift w/ Fox 2.0 shocks and struts 22" Hardrock Rims 33" Nitto Recon Grappler tires Fender Flares TRD Style Grille w/ Amber L.E.D. lights S&B Cold Air Intake 4.88 rear gear Hood, tailgate and bedside vinyl All AMSOIL fluids
    I know the 3rd gens only for e brief time had a twin turbo kit through the OVtune website. But does anyone know, being the new Tundras are using a 3.5L engine thats turbo charged if anyone has been able to use those turbos on the tacoma 3.5L engine.
    I would assume they are almost identical. Can it be done? Has anyone done it?
  2. Apr 28, 2022 at 4:42 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    Don't assume anything, lol. Have you read about the problems they are having with turbos?
    turboeverything and Chew like this.
  3. Apr 28, 2022 at 4:50 AM
    ahelms114
    Andrew
    I have seen a few people having issues with them. Im sure eventually the quirks will be worked out. I was just curious to know if someone has tried or knows they can just be bolted on and minimal modification is needed and what difference it made.
    Ive seen mixed reviews on supercharging our engines, some say its worth it, and others say its not as much of a difference as youd like for 7 grand.
    Im interested to see more turbo set ups and how they compare regardless of turbo lag
    turboeverything likes this.
  4. Apr 28, 2022 at 4:53 AM
    skeletron
    skeletron Disgraced Member
    Clark
    Sakerlina
    2020 TRD Broh
    @mZiggy can give you a full report since he's actually had the TT kit on a Tacoma. I can tell you based on what you've said so far this is not a project for you. Nothing will be straightforward or easy, especially compared to the supercharger.
    Lt. Dangle, tonered and Chew like this.
  5. Apr 28, 2022 at 4:58 AM
    ahelms114
    Andrew
    Im not concerned with difficulty. Im a master mechanic and used to build performance BMW's and Audis, I was just curious if anyone has had any experience with it yet. I figured the answers would be slim to none being that the new tundra engine has hardly been out.
    But like they say, if you never ask the answer is always no! lol
  6. Apr 28, 2022 at 6:24 AM
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    maybe go to the vftuner forum and see what you can find from those who have it. That would be the best source. GL.
    skeletron likes this.
  7. Apr 28, 2022 at 6:30 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Tundra uses completely different 3.4L v6.
    dr4g1116 and Chew like this.
  8. Apr 28, 2022 at 8:29 AM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    I did it. It was a PITA. Hardware wasn't that bad but the software/tuning will be the achilles heel.
  9. Apr 28, 2022 at 8:33 AM
    Benny blanco
    Benny blanco Mr. Jiggletits
    Ben Day Ho
    Whoville<>Trollhättan
    21 Cement TRD OR MT
    Some stuff
    APR?
  10. Apr 28, 2022 at 8:54 AM
    mabepossibly
    mabepossibly I know enough to make an ass of myself
    Andrew
    Albany, NY
    2021 TRD OR Manual
    Skids, Sliders, Lights
    Tundra has completly different engine. Its still GR based, but everything inside the block is different.
    Exhaust manifolds probably bolt up, but the odds of the same turbo positioning not having major clearance issues in the Tacoma is slim.
    I'd move the battery to the back seat, mount a single smallish (K04?) turbo in that area. But unless you are going for a crazy build to run huge boost, the supercharger kit seams a lot easier to bolt on and run 8-10lbs. I like the procharger kit over the magnuson because it allows you to run a front mount intercooler, much easier to upgrade vs the magnuson air to water setup.
    -Also have a turbo VW/Audi background.
  11. Apr 28, 2022 at 9:08 AM
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    I bought in at the preproduction price and sold at the new standard pricing and super happy I did. The guy I sold to I still don’t think has it figured out and last time I looked at the vftuner forum someone was stating his truck just sits in his yard, however this has probably been a year ago now. So I gave up hope and moved on. That turbo kit money did get used though for two weeks in Hawaii.
    Skydvrr and MESO[QUOTED] like this.
  12. Apr 28, 2022 at 9:19 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Is it from the same family? The 3.4L is V35A-FTS.
  13. Aug 22, 2022 at 11:06 AM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    It doesn't matter how mechanically skilled you are to turbo the 2GR-FKS.. you'll need to be an embedded computer programmer guru and have some electrical engineering skills to get fueling to a point where it won't grenade.
  14. Aug 22, 2022 at 2:22 PM
    ExGunner
    ExGunner Well-Known Member
    Paul
    2017 Tacoma TRD Sport Blue
    how well does the Turbo work with the Atkinson timing or the engine switching between Atkinson and Otto . I got to imagine that is a bit of a bitch to get everything working correctly and lots of Gremlins to iron out. Maybe I'm wrong and its no big deal but just thinking the way the Valve timing with Atkinson works and the Increased air flow and intake pressures from the turbo.
  15. Aug 22, 2022 at 2:25 PM
    saint277
    saint277 Vigilo Confido
    Would think a strait engine swap would be easier, probably cheaper to if you can get a junk yard one.
  16. Aug 22, 2022 at 2:40 PM
    Gen3TacomaOBX
    S
    I don't think there is a twin turbo kit available for the 2GR-FKS any longer. I believe there were a dozen or so released but you don't hear much about them and the rest of the orders were refunded afaik. If you want forced induction on the 3rd gen Taco it seems that superchargers are the only commercially available solution.
    Perhaps the refined VF tuner software *might* support a home grown turbo kit without being an ECU developer <shrug>.
    Chew likes this.
