3.4L Rebuilt Long Block
Discussion in '1st Gen. Tacomas (1995-2004)' started by YoDaddy1, Jul 10, 2014.
  1. Jul 10, 2014 at 8:47 AM
    YoDaddy1
    YoDaddy1 [OP] Member
    Yoda
    Brentwood Cal.
    The Green Beast285/70 R17 Good Year MTRs
    5" lift, Fixing mods from Prev owner
    I have recently discovered the wealth of knowledge in this venue, It is a great source of information... Thanks
    With that being said, I had an overheat issue over the 4th of july, Upon my return I took truck to a friend and we quickly discovered that I have HC present in my cooling system. = Blown Head Gasket
    I live in the Bay area and have looked around for replacement engines as I don't want to screw with redoing the top end only on a motor with 229K on it. I have found several suppliers that offer a long block Rebuilt in the 3.4L Prices range from $1,600.00 to $3,700.00 I found a company in Emeryville Cal. that imports engines from Japan and does the work on them here local. This company is Called Engine world and is on the low side of the price range. This post is to get info out to this forum and to also solicit some opinions. I've also got a Mechanic lined up to do the install at a price of about $1,100.00 I am anticipating another $500-$800 in Parts Water pump, Radiator, Hoses, Belts, And misc.
    Any feed back or opinions on this would be great.
    Thanks
    Yoda
  2. Jul 10, 2014 at 10:55 AM
    lipster
    lipster Well-Known Member
    Northern MN
    2004 ext cab 3.4 auto TRD
    License plate frame
    Me? I would fix the one I have.
  3. Jul 10, 2014 at 11:14 AM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Don't ever go cheap on engine rebuilds. This is one of those jobs you want to do yourself or have the highest bidder do, IAW your budget.
    URD has a lot of knowledge on the 5VZ and does rebuilds on the 1GR. I doubt he will do the rebuild (he's usually swamped) but he might be gracious enough to point you in the right direction.
    Running Board Man likes this.
  4. Jul 10, 2014 at 11:16 AM
    YoDaddy1
    Yoda
    Brentwood Cal.
    Repairing it was my first inclination, I have taken it to several shops and talked to several other ASE Certified Mechanics, 90% are saying they would love to take my Money to just do the heads, but they know they will see me back within 6Mo. with lower end problems.
  5. Jul 10, 2014 at 11:32 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
  6. Jul 10, 2014 at 11:54 AM
    2scars
    2scars Swollen Member
    Brandon
    RVA
    2003 TRD 4x4 Doublecab
    All-pro, T-G, Budbuilt, Warn, Tepui, Homefab rear bumper
    I just put a JDM 3.4 in mine, but it was a pain with the differences in the oil pan, cooler, wiring harness, and other bits and pieces. I also had the factory motor sitting there to look at and I took my time. slow the first time but not awful. This motor runs like a top and cost me $1350 with tax, not bad extension of the trucks life.
    Brandon
    Dalandser likes this.
  7. Jul 10, 2014 at 5:50 PM
    XR1200
    XR1200 Active Member
    SF Bay Area
    00 PreRunner SR5 V6
    Why not rebuild the one you have? Only reason not to is time and with 229k on the clock don't be a fool and just do top end. It could last forever by just doing the heads but you will be pissed if the bottom end starts to have issues.
    Call Toy Connection in Santa Clara and if they are in a good mood they should be able to answer your questions and give you their recommendation.
  8. Jul 11, 2014 at 7:49 AM
    Lumpskie
    Lumpskie Independent Thinker
    New Hampshire
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15º clocking
    I don't know anything about the shops you listed, but I was thinking...
    If you're having a shop pull the head, would it be cheaper to inspect the block and go with a slightly oversized piston set, if you find something wrong?
  9. Jul 11, 2014 at 8:29 AM
    lipster
    Northern MN
    License plate frame
    I'm no machinist, but to do that, you have to bore the cylinders, as they really aren't round anymore, among a lot of other reasons.
  10. Jul 12, 2014 at 7:58 AM
    YoDaddy1
    Yoda
    Brentwood Cal.
    I am leaning toward a rebuilt long block, cylinders bored .020 over and all components replaced, can get it done a total of about $3,500.00 VS $2,500.00 for just the top end, don't have the time or the patience to tackle it in my Garage!! Lol
  11. Jul 12, 2014 at 5:47 PM
    XR1200
    SF Bay Area
    00 PreRunner SR5 V6
    And you don't know how the original owner treated it so you could end up being out even more money.
  12. Jul 12, 2014 at 6:52 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Not much of a gamble with the 5VZ...
  13. Jul 12, 2014 at 9:39 PM
    XR1200
    SF Bay Area
    00 PreRunner SR5 V6
    Then don't look under the timing belt cover on the truck Ibought used where I found remnants of a shredded belt or the crank pulley bolt that was not properly tightened and had nearly fallen out.
    Used is still used and you never know how it was taken care of prior to you purchasing it.
    Arctic Taco likes this.
  14. Jul 31, 2014 at 5:00 PM
    YoDaddy1
    Yoda
    Brentwood Cal.
    ...... All Done, New Longblock installed, New life to an old truck. Seems to be running great, Total for the swap, $3609.62 On to the next project on the truck!!! New springs in the back, Prev owner put 2" blocks under the factory springs BAD combo!!
    chirkin, 1997tacomav6 and otis24 like this.
  15. Jul 31, 2014 at 5:12 PM
    Tinmann
    Tinmann Well-Known Member
    NorCal
    Good to hear that you got it sorted out. Did you use engine world or another source?
  16. Jul 31, 2014 at 5:16 PM
    YoDaddy1
    Yoda
    Brentwood Cal.
    I used Engine world, They were great to deal with, got the core charge back within a few days.. So Far So Good
    chirkin likes this.
  17. Jul 31, 2014 at 5:22 PM
    12Mk6gti
    12Mk6gti Well-Known Member
    Scott
    Sunshine state
    2019 Nautical Blue TRD OffRoad 4Runner
  18. Aug 1, 2014 at 7:26 AM
    Tinmann
    NorCal
    Thanks for the feedback. :)
  19. Aug 1, 2014 at 10:06 AM
    68dave
    68dave Well-Known Member
    Dave
    Baltimore/WV mountains
    $500.00 project 04 TRD 4x4 Lifted 4runner Stock Tacoma TRD Lifted 94 FZJ80 Stock 95 FZJ80
    Toytec Boss kit & OME leafs, 231mm tundra brakes SCS wheels...
    I was in the same situation as you except i bought my 04 as a project with head damage from oil loss. I purchased a used but complete 3.4L with 69k miles off of ebay from a salvage yard in Arizona. I replaced all the maintance items while it was on the engine stand then installed it. 3 days after i installed it i did a 3300 mile camping trip with it, didn't even burn or drip a drop of oil. Gotta love Toyota's!
  20. Aug 1, 2014 at 10:14 AM
    Yarddog
    Yarddog Member
    Vance
    Santa Clarita, CA
    Prerunner TRD Off-Road
    Glad you went the long block route...you initially assumed a blown head gasket due to hydrocarbons in the coolant, but actually, my first thought is always a cracked head...especially if the heads are aluminum... so the long block took care of that.
    This is a little late in the running, but generally, I always prefer rebuilding what I have. Thataway, I know EXACTLY what I have when the job is done! But, I also have the technology and ability to get that done, and access to high quality automotive machine shops. Unless you're buying a brand new OEM crate engine, buying a rebuilt engine from an engine supplier is always a pig in a poke to some degree. Americans seem to be 'value conscious'...ie 'cheap'...and 'cheap' comes with a price...generally the cheaper a thing is, the poorer the quality...and everybody's anxious to maximize their profit margin.
    That said, you'll likely get good service from your long block, and it was VERY wise going with a long block rather than the short block, because of the likelihood that your original problem was caused by a cracked head...better safe than sorry. A used engine from a junkyard is NEVER a good idea, unless you're just getting a vehicle on the road again, to sell, or just for a short term solution...
    Well played, OP...
    chirkin and Nessal like this.
