3.4 spark plugs.... Dual vs single electrodes
Discussion in '1st Gen. Tacomas (1995-2004)' started by COMAtized99, Aug 2, 2017.
  1. Aug 2, 2017 at 4:41 PM
    COMAtized99
    COMAtized99 [OP] Well-Known Member
    North Carolina
    99 DCLB v8
    The Bed is stock...ish
    I'm about to buy spark plugs for my 3.4. what's everyone running? The reason I ask is currently there are single electrode plugs in the engine, but right on the timing cover, just above the left cam sprocket is a sticker specifically stating dual electrodes only, no single.
    What's the deal? My friend just put single electrode iridium plugs in his 04 3.4 and it runs just fine...
  2. Aug 2, 2017 at 4:45 PM
    Kleenax
    Kleenax Well-Known Member
    Ray
    Michigan
    2001 SR5 4WD V6 Auto - Mica Green
    New frame & stuff CBI bolt-on Sliders
    I am wondering the same thing......
  3. Aug 2, 2017 at 4:46 PM
    tacoma_2002
    tacoma_2002 Where We're Going We Don't Need Roads...
    Andrew
    Cotton Plant, Mississippi
    '02 Tacoma 4x4 TRD
    I used regular NGK copper plugs (single electrode) for a few hundred miles in mine at one point. I KNEW going into it that Toyota recommends the dual electrode plugs but everyone in town that day had low on hand qty of the correct plugs.
    Seemed like it had a little more hesitation than normal but that could've been psychological....
    I replaced those plugs the next week for the correct NGK plug....that's all I've put back in it...
    Likely psychological but maybe not....
    FWIW the correct plug is cheaper than an Iridium plug and they last plenty long. Just my .02
    COMAtized99[OP] likes this.
  4. Aug 2, 2017 at 6:42 PM
    austinsdad99
    austinsdad99 Well-Known Member
    1999 prerunner 3.4
    My truck ran ok with platinum plugs for awhile then developed at bad miss. I swapped to Ngk dual ground plugs and Ngk wires and it runs better than ever now.
  5. Aug 2, 2017 at 7:03 PM
    Glamisman
    Glamisman Well-Known Member
    there is newer technology out now than when the motor was introduced and the single tips should run just fine. The ignition system on the 3.4 because of the ignition system... the plugs are fired twice per 4 stroke cycle.
    McMash and Dalandser like this.
  6. Aug 2, 2017 at 7:59 PM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    There will be absolutely no performance difference between dual ground and single ground plugs. The laws of electricity don't change with how many ground straps you have. The only reason for dual grounds is longer life with the waste spark ignition on these engines, simply from having twice the surface area to wear out.
    4XMountains and McMash like this.
