3/4 inch wheel spacer by Headstrong?
Discussion in 'Wheels & Tires' started by totmacher, Jan 18, 2013.
  1. Jan 18, 2013 at 6:43 PM
    totmacher
    totmacher [OP] automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    I saw on the Headstrong Offroad site that they have 1 inch wheel spacers or can special order 3/4 inch spacers.
    Anyone using these?
  2. Jan 19, 2013 at 11:55 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    No spacers but you can see the difference .75" can make.
    255/85/16 BFG KM2s on 1st Gen TRDs 4.5" BS
    245/75/16 Dungflops on stock steelies 5.25" BS
  3. Jan 20, 2013 at 11:56 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Are they hub-centric wheel spacers?
  4. Jan 20, 2013 at 8:39 PM
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    yes. It says hubcentric.
    It's last item at bottom of this page.
    http://www.headstrongoffroad.com/all-other-product-tacoma-05-6-lug.html
    I've just never heard anyone mention spacers from these guys so was curious.
    I'm actually looking for the thinnest I can get that has its own studs. I'd be fine with a 1/4" spacer except I don't trust ET lugs and don't want to press in longer studs. So, I'm guessing these 3/4" might be my best bet. My goal is just a little more clearance between tire and spindle/UCA.
  5. Jan 20, 2013 at 8:53 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    By reading the description of them it seems like they are made out of the same aluminum as the All-Pro Offroad spacers and the Spidertrax. Plus they are anodized for rust protection. Plus a warranty. Sounds good to me.
  6. Jan 21, 2013 at 7:10 AM
    snoope
    snoope Well-Known Member
    Winter Haven Florida
    2002 Tundra Limited 4x4
    I can not speak of Headstrong But I can tell you I purchased .75" Bora spacers and they are working perfectly...i needed that extra space when i purchased new wheels & tires; UCA's were almost rubbing but the .75" made the perfect match...
    They are BOTH Hub and wheel centric.
    Same specs being made of aluminum,andonized and warrantied PLUS good customer service....
    They too, are also here as a TW vendor....
    If your Headstrongs are the same...Why not call them and see what they can do for you...CSR is what it is all about...
  7. Jan 21, 2013 at 8:27 AM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    OP - did you get a price quote on the 3/4" ?
  8. Jan 23, 2013 at 6:38 PM
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    Haven't had called them yet. been busy at work plus sick wife & kids at home.
  9. Jan 26, 2013 at 4:47 PM
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    FYI, the spacers definately are made by Bora.
    Around $47.50 each for either 3/4 or 1 inch thick. People at Headstrong were very helpful over the phone. Sounds like they can get a lot of stuff that's not listed on the website.
