2wd Prerunner at the boat ramp?
Discussion in 'Towing' started by grant22, May 2, 2010.
  1. May 2, 2010 at 6:38 PM
    grant22
    grant22 [OP] Member
    Grant
    Lake Havasu
    N/A
    Hello, My boat weighs in at around 5000 lbs but I'd like to buy a Tacoma Prerunner if possible (I really have no other need for 4wd).
    Does anyone know if the Prerunner TRD & Tow Package (I'd get a year with that has a rear locker) can pull a 23' 5000 lb boat out of an average ramp?
    THX
  2. May 2, 2010 at 6:40 PM
    Sparky4.0
    Sparky4.0 Well-Known Member
    Aaron
    WestTexas
    01 trd beat to hell
    i would say it possible.. but if it wet i wouldnt wanna try it
  3. May 3, 2010 at 10:50 AM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    I'd go for the 4x4. I pull my boat and launch it in some pretty crazy spots with my 4x2 but I have trouble with clay. I've had to use a pull from abuddy at one unpaved ramp that is a mixture of clay and marl and sand. Other sand ramps without the slick clay have not been a problem for me. The LSD works well but if both back tires are slipping you go nowhere.
  4. May 3, 2010 at 12:52 PM
    Barnone
    Barnone Guest
    What's a average ramp? Around here they vary quite a bit. Wet,slimy,steep, drop off?
    4x4 if you want to be safe.
  5. May 3, 2010 at 12:58 PM
    alex1988
    alex1988 Well-Known Member
    Galveston, Texas
    2wd>4wd.... Its all about the cup holders
    5000 lb 23 foot boat? sounds like our regulator. Well I know from experience that our suburban struggles pullin that boat around, and its a v8. If i were you I would go for the tundra
  6. May 3, 2010 at 1:26 PM
    Danosabre
    Danosabre Well-Known Member
    Dan
    Gardner,Ma
    09 TRD Off Road
    Extang Trifold bed cover,DDM 55W 6000k HID, maglight, Vent visors
    Get a lighter boat??? :D
  7. May 3, 2010 at 6:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Though my boat is only 3000#, I have pulled it out of the water off of realatively steep spots on the shore, with no slipping, or trouble. Pulls it right out every time.
  8. May 3, 2010 at 6:39 PM
    waynesworld
    waynesworld Well-Known Member
    wayne
    hampton ,va
    05 trd off road 4x4 dcsb auto silver streak
    rancho lift 2in rs9000shocks on front,avs in channel vent visors,tacoma entry guards,oem bed extender,weathertech floor mats,access vanish bed cover,tailgate mod ,alpine stereo,xm stereo.trd skidplate.mobil 1 extended performance oil, avid light bar
    hey, i have a 89 toyota 4x4 with a 22re 4cyl. and a 1730 center console boat that weighs 3500lbs.and i never had 2 lock the front hubs in .but i put it in 4low 2 make it easier 2 pull my boat out of the water .
    hope this helps.:cool:
  9. May 3, 2010 at 6:43 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    Maybe spring for the 4x4, mine has not had any trouble in 4hi
  10. May 3, 2010 at 7:14 PM
    grant22
    grant22 [OP] Member
    Grant
    Lake Havasu
    N/A
    Thanks all 4 the help.
    The 5000 lb figure is a conservative one taking into consideration: Boat=3025 lbs, Trailer=1000 lbs, Fuel/Gear/People=1000 lbs.
    My closest ramps are all paved, normal incline, and sometimes have algae slick.
    I don't want a tundra (I'm trying to downsize from my Chevy 1500 4x4) cuz I'm only pulling 5 miles or so.
    I don't want a 4x4 Taco cuz I don't want those 17" wheels or the hood scoop.
    I know! I'm being high maintenance here, but if I can get away with with a prerunner, I'd be pretty happy about that!
    If any locals with a V6 Taco Prerunner wanna meet up and try the launch ramp with my boat attached, I'd be happy to buy lunch or trade for a case of beer or sumthin' !
  11. May 3, 2010 at 7:20 PM
    fishinsteeg234
    fishinsteeg234 Well-Known Member
    Alex
    Atlanta, GA
    06 PreRunner Short Bed
    Pro Comp 3" suspension lift kit, Pro Comp 8128 alloy wheels with 285/75/16 BFG AT KO's, Gorilla Lugs, Camburg 1.5" uniball UCA's, AFE cold air intake, Black N-Fab bars, SS extended brake lines, HID bixenon's
    the pre-runner has enough power for a 23' boat tow, but just watch out for slippery ramps...
  12. May 3, 2010 at 7:36 PM
    BravesFan
    BravesFan The MOST Badass Offroad Truck
    Rob
    Brentwood, TN
    09 Super rock crawler
    You can get the 4x4 without the scoop and the 17in wheels im pretty sure....chris correct me
  13. May 3, 2010 at 7:39 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Correct. The SR5 and TRD Off Roads have 16" wheels, and no scoop.
  14. May 3, 2010 at 7:41 PM
    tacomaprerunner
    tacomaprerunner Dang liberals.
    1995 Ford F350 7.3L PowerStroke Diesel
    A 4x4 Taco won't necessarily have the hood scoop - that's the Sport Package. The Off Road Package comes with the locker and no hood scoop.
    edit - dang, they beat me to it.
  15. May 3, 2010 at 7:50 PM
    grant22
    grant22 [OP] Member
    Grant
    Lake Havasu
    N/A
    But if I want a long bed, I gotta get the sport, right?
    I kinda don't like how Toyota packages their Tacomas. If you want this, you gotta get that over there. I wish they would offer a TRD Long Bed with the off road pack.........
  16. May 3, 2010 at 7:52 PM
    4x4jeep
    4x4jeep Well-Known Member
    Kyle
    Destin FL.
    I tow my 21' boat just fine with my V6 prerunner. Sometimes you just need a fat guy in the bed to get up the ramp. You should be fine but sometimes it would be nice to have 4x4
  17. May 3, 2010 at 8:11 PM
    grant22
    grant22 [OP] Member
    Grant
    Lake Havasu
    N/A
    Sounds like it's kinda a 'tweener.......and I need to bone up and get the 4wd. Ugh!
  18. May 3, 2010 at 10:22 PM
    Black Taco
    Black Taco Well-Known Member
    Rob
    WPB, FL
    TOYOTA
    No mods whatsoever!
    My buddy towed his 18 ft Key West up a slimy ramp with a 4 cyl Prerunner (with the locker) many times and never spun a tire. He had Michelin LTX on it. Like others have stated, a paved ramp shouldn't be a problem. Dirt= another story.
  19. May 3, 2010 at 10:28 PM
    4x4jeep
    Kyle
    Destin FL.
    Yea I think the dunlops are my problem. Looking at getting better tires in my near future
  20. May 4, 2010 at 6:04 AM
    jrider636
    jrider636 Well-Known Member
    justin
    tally,fl
    08 tacoma prerunner
    i have a prerunner as well and i pull my 19' boat bass boat with no prob, there is a slight weight diff, but never have had a prob with it
