2TR-FE oil consumption issues
Discussion in '4 Cylinder' started by TYetti, Oct 23, 2018.
  1. Oct 23, 2018 at 7:51 AM
    TYetti
    TYetti [OP] 4cylinders of awesomeness
    Mat
    Abbotsford, BC, Canada
    09 Tacoma AC 2.7L 5spd 4x4
    I'm looking to hear about oil consumption issues between oil changes with 05-15 trucks. I'm talking chronic oil usage with no visible leaks or indications of oil entering the combustion chambers. I'm looking to hear about if solutions were found so far my search shows me a couple who just added more oil and sold their truck or at the other end of the spectrum BabyTaco did a rebuild with I believe bad rings on cyl 4. Any insights into this issue are helpful
  2. Oct 23, 2018 at 1:39 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    I just read through the other (old) thread where you chimed in on this issue. Yes it could be a valve stem/stem seal, but also oil burning or "consumption" can be caused by a stuck ring(s). So contrary to to others advice, I believe a compression check *might* help. If this is the problem, some common solutions are engine flushes, fuel detergent additives and oil detergents to clean the ring pack and free any stuck rings.
  3. Oct 24, 2018 at 9:25 AM
    TYetti
    Mat
    It's not the rings. 160 across the board, I now believe it to be an oil control ring, it gets stuck open and allows the oil to basically drain out in a short amount of time but then closes an operates normally so the plugs don't get fouled and there's no smoke. this is an issue on other Toyota 4cyl engines they even issued an enhanced service campaign on them. However the 2trfe is not apart of that campaign and to fix the issue would require a full rebuild. It's cheaper to find a complete engine and drop it in and hope it doesn't happen again but chances are this will affect most 2trfe engines as they age. From my investigation on my engine there doesn't appear to be any real damage so I'll fill everything back up and monitor it closely, and decide what to do because based on how I use the truck I can't have en engine that randomly decides to dump oil 500km in the bush with no help available.
  4. Oct 24, 2018 at 9:42 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Shouldn't be hard to find at a wrecker, they still use it in new Taco models I believe
  5. Oct 24, 2018 at 9:57 AM
    SnowB0und
    SnowB0und Well-Known Member
    4cyl 4x4
    Could it be a PCV issue? You could inspect the intake after where the PCV line comes in and see if its more than normal.
    The new ones are VVTI on intake and exhaust so I'd think it would be a little complicated sorting that out.
    12TRDTacoma likes this.
  6. Oct 24, 2018 at 10:48 AM
    TYetti
    Mat
    It's still a crap shoot, whether or not Toyota addressed the issue or just pretend it's not happening like they did at first with the 2az, I've even found a report of a local guy having the same issues with a 6cyl he solved it by replacing the engine
  7. Oct 24, 2018 at 10:52 AM
    TYetti
    Mat
    My earlier assumption that it wasn't the rings is incorrect I was basing it on the compression test because it's an intermittent problem with the rings not enough oil passes by to cause smoking or any other signs it may eventually as it gets worse but this is the beginning of the end for this engine. I'm pretty sure she's gonna go the way of @BabyTaco and I feel like there's a few dozen trucks here that will go the same route, if you have this issue have it confirmed and report it to Toyota it's too late for my truck I have too many miles on it even if they issued a tsb I wouldn't qualify. The price I pay for using my truck I suppose
  8. Oct 24, 2018 at 10:58 AM
    black coffee
    black coffee A is A.
    Glenn
    509
    2010 AC 4x4 SR5 V6
    You said “chronic oil usage” but haven’t said how much it’s using. All engines will consume some oil. How bad is yours if you think it’s a problem?
  9. Oct 24, 2018 at 11:41 AM
    TYetti
    Mat
    With mine it started with 1L every 8000km this has slowly increased over time, at first I was of your opinion it's just oil breaking down. now it's up to 4.4L in less than 8000km (7000 to be exact) most recently I was able to hear the valve trail clacking away on the freeway shutting off the engine instantly i added oil till full it took 4.4 L it's never smoked, never leaked, I didn't find any shavings in the oil or the filter, there's nothing in the coolant or the PCV system. It exhibits all the symptoms of the 2AZFE which had a tsb issues for new rings and pistons.
  10. Oct 24, 2018 at 11:54 AM
    TireFire
    Olympic Peninsula
    If he pulls it from a wrecker just get the harness and ECU also.
  11. Oct 24, 2018 at 11:55 AM
    TireFire
    Olympic Peninsula
    I sure as shit wouldn't rebuild this because low mileage used ones are cheap and plenty and it's less work
    Steves104x4 and TYetti[OP] like this.
  12. Oct 24, 2018 at 12:05 PM
    TYetti
    Mat
    Also if I pull another 2tfe it's bolt in. I don't need anything but the long block as my truck has all the parts. If I were to switch engine platforms yes I would need the harness
  13. Oct 24, 2018 at 12:31 PM
    DGXR
    Friend
    Sacramento, CA
    As stated by SnowB0und, the updated 2TR-FE has cam phasing on the intake and exhaust, where your 2nd gen only has exhaust cam phasing. So I'm thinking the ECU *may* be different... obviously I am not sure but it's worth checking.
  14. Oct 24, 2018 at 1:56 PM
    TYetti
    Mat
    I wouldn't be pulling a 2tr from a 2016+ as they're going to be very few in a wrecker locally and they'll want a premium for them. The 4cyl is exceptionally rare here I've only ever come across a hand full, I'd look to get one from an 05-15 if and i mean if I stay with the 4cyl platform. My current thinking is that based on the amount of guys here having a ring issue This will affect all or most 2trfe engines from at least 05-15. Which to me makes the 4cyl a non reliable platform
  15. Oct 24, 2018 at 2:14 PM
    TireFire
    Olympic Peninsula
    You're manual, right? Should be a bunch of other engines that mate easily to the r series trans you have
  16. Oct 24, 2018 at 2:17 PM
    TYetti
    Mat
    It's what I'm looking into right now. I'm actually trying to find the guy that did the V8 swap in is 4cyl just out of curiosity, but I'm looking at a bunch of options, it's gonna have to be an engine that lasts the long haul to justify the cost
  17. Oct 24, 2018 at 2:22 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I would strongly advise keeping it simple and attempting the cheap fix of PCV valve before assuming the worse and digging into oil control rings or valve stem seals.
    Though Toyota has a long history with crap oil control rings, a PCV valve is easier to access. Try it first and report back.
    AxisCab and BassAckwards like this.
  18. Oct 24, 2018 at 2:26 PM
    TYetti
    Mat
    It's already off and been looked into. Also got a good look at the pistons it all fits and makes sense the more I chew on the results of yesterday's deconstruction.
    12TRDTacoma[QUOTED] likes this.
  19. Oct 24, 2018 at 3:32 PM
    SnowB0und
    4cyl 4x4
    So your burning a quart every 1k miles? That’s considered normal by most vehicle manufacturers. Especially turbo European cars. If that’s it just add a quart every other fill up and don’t worry about it.
  20. Oct 24, 2018 at 4:09 PM
    TYetti
    Mat
    Re read what I posted it's now consiming 4.4 liters per 7000 km
