2RZ Oil Filter Mount, Proper Name?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Murd3rd, Apr 22, 2025 at 10:22 AM.
  1. Apr 22, 2025 at 10:22 AM
    Murd3rd
    Murd3rd [OP] I believe I Toyota harder than most
    Your Mom's House, USA
    00.5 Reg Cab Slammed, Turbo'd/19 TRD OR 6MT S/C
    1st gen - it's got a built engine, a turbo, and waaaaaaay too much to list. 3rd gen - basic-bitch lift, S/C, Pro Wheels
    I've searched and searched... Can't seem to find the actual name of the aluminum 'adapter' like mount for the oil filter on the 2RZ. Or maybe it's just called an oil filter mount or bracket (searched multiple variations of those descriptions) and they just don't exist besides the one that comes on the truck from the factory? :notsure::help:
    Pics for reference... I've rendered mine unusable :anonymous:
    (If anyone happens to have one they don't need, and you're willing to sell it, I'd be seriously interested :D)
  2. Apr 22, 2025 at 10:34 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Murd3rd[QUOTED][OP] likes this.
  3. Apr 22, 2025 at 10:35 AM
    Murd3rd
    Sunnuva! That's way more than I thought it'd be :annoyed:
    After a second look, that one doesn't look the same as the 2RZ mount...?
  4. Apr 22, 2025 at 12:33 PM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    The one @se7enine posted is the one that's on my 3RZ (I replaced the o-rings because they were leaking).
    If the photo you posted is of yours, it almost looks like a 90 degree adapter. Do you have a 2RZ?
  5. Apr 22, 2025 at 12:35 PM
    Murd3rd
    Yep, 2RZ. I honestly figured they'd share the same bracket\mount\whatever. I'm assuming that's not the case?
  6. Apr 22, 2025 at 12:46 PM
    nzbrock
    Noah
    San Marcos, TX
    Doesn't look like its the same.
    https://www.toyotapartsdeal.com/oem/toyota~bracket~sub~assy~oil~filter~15609-75010.html
    Found it through toyodiy.com by searching a gasket part number I found on this site: https://www.yotashop.com/oil-seal-t...-filter-housing-seal-kit-1995-2004-kit-1075c/
    Toyodiy: https://www.toyodiy.com/parts/p_U_199706_TOYOTA_TACOMA_RZN140L-TRSDKAB_1502.html
  7. Apr 22, 2025 at 1:16 PM
    2RZNoShi1
    2RZNoShi1 Well-Known Member
    Jayson
    91 SAS Pickup
    Turbo 2rz swap Haltech 750 3067 pulsar turbo 750cc injectors Solid axle swap 5.29 gears with 35's
    I have one off my old 2rz if you wanna shoot me a message! I'll send a pic of it when I get to the shop!
    Murd3rd[OP] likes this.
  8. Apr 22, 2025 at 1:34 PM
    Murd3rd
    PM inbound!
    2RZNoShi1[QUOTED] likes this.
  9. Apr 22, 2025 at 4:07 PM
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
    Any chance you could get side-by-side pics of a 2RZ and 3RZ bracket/filter installed on an engine? I'm curious how they compare. It looks like the 2RZ bracket puts the filter lower.
    I'm specifically wondering if a 2RZ bracket could be swapped onto a 3RZ to make the filter less awful to change.
  10. Apr 22, 2025 at 4:19 PM
    2RZNoShi1
    Jayson
    91 SAS Pickup
    They are very different. The 2rz pedestal mounts with a big banjo bolt that is the same thread as an oil filter stud, and the 3rz one bolts on with 3 bolts and a weird shaped rubber o ring. We were going to try to use the 2rz pedestal on my 3rz and realized very quickly they are different
  11. Apr 22, 2025 at 4:20 PM
    2RZNoShi1
    Jayson
    91 SAS Pickup
  12. Apr 22, 2025 at 4:24 PM
    nzbrock
    Noah
    San Marcos, TX
    It’s almost like the original plan was to have the filter horizontal off the side of the block.
  13. Apr 22, 2025 at 6:10 PM
    6P4
    Colorado Springs
    Interesting, I figured the mounting would be the same since they're both RZ engines. Thanks for the knowledge.
  14. Apr 22, 2025 at 10:38 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Hate to say the fastest way is same on 3rz/2rz.....pop off the passenger tire and its a breeze...
    if you have a floor jack and impact at the ready.
    OTherwise if that filter is on too tight......
    Those brackets come in different numbers.....but think they are all same...2rz's
    【NEW】Toyota Genuine BRACKET SUB-ASSY, OIL FILTER 15609-54014 | eBay
    2rz one is held on mainly by this giant banjo....
    90401-19005 Bolt, Union(For Oil Filter Bracket) Toyota | eBay
    Bet you somebody in the 'for sale' forums already has a junk 2rz...
    ....all you got to do is find him......swapping out frames all the time
  15. Apr 22, 2025 at 10:44 PM
    O'Silver_Taco
    MD
    On 2rz you could actually bypass the bracket an just use a straight nipple like they've done in the past for 100yrs
    with nipple,, the filter will seal against the block........just have to use shorter filter to clear the headers...
    this is the way they did on 22re's.............when they switched sides on the exhaust on 2rz's....they had to drop the filter to clear the new headers
    And will be an absolute mess when you pull that filter off with it being horizonal.....
    but it could be done....if only temp until you stubble into that
    Toyota OEM Engine Parts-oil Filter Union 9040419013 for sale online | eBay
    Same threads as that giant banjo.....
  16. Apr 23, 2025 at 6:25 PM
    Murd3rd
    Thanks to @2RZNoShi1 I scored a very reasonably priced replacement! Thanks man!
    2RZNoShi1 and Bishop84 like this.
