2nd vs 3rd Gen reliability
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Coopsdaddy, Jul 26, 2024.
  1. Jul 26, 2024 at 5:35 AM
    Coopsdaddy
    Coopsdaddy [OP] Well-Known Member
    Quinton
    2012 dclb tacoma
    6112/5160 Deaver stage 1 Are topper Steelies,255/80/17
    Looking at a 2nd or 3rd Gen 6 cyl and preferably a manual.
    Are the 2nd Gen really that much more reliable ?
    i definitely like then3rd Gen looks.
    Plan to buy used and keep awhile so reliability into 250-300000 miles is important.
  2. Jul 26, 2024 at 5:47 AM
    Smacky2020
    Smacky2020 Well-Known Member
    Bristol, VA
    2020 TRD ORDC - Cement
    Stock wheels and suspension. Random "utilitarian" mods featured on this great forum.
    Given that a lot of 2nd gens left are probably around/at 200k mi by now (unless you find a unicorn), your best bet would be a 22 or 23 3rd gen.
    Do a search for high mileage thread and you'll see that 3rd gens can last as long or longer than 2nd gens. Everyone has their love/hate thoughts about either but both are solid vehicles if you take care of them. You're posting this question on the 3rd gen side so you'll naturally get answers skewed towards the 3rd.
    Edit: here's one such thread: https://www.tacomaworld.com/threads/400k-club.721719/#post-25695260
  3. Jul 26, 2024 at 6:17 AM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    I'd go 3rd gen. Better looking inside and out. The newest 2nd gen is 10 years old at this point. I'll take the newer, pretty reliable truck, over the older pretty reliable truck any day.
    Having said that the 3rd gen isn't without its flaws. Drive one and make sure the engine/trans is for you. For me the only major problem I've seen on here that is concerning is the valve burning but that's been pretty rare. Others such as leaking timing cover (also a 2nd gen issue) and leaking coolant crossover are on the radar but something I'd deal with if they happened.
    I know long term reliability is your end goal but if I were buying right now I'd take a hard look at the 4th gen.
    Pwakchop and Chew like this.
  4. Jul 26, 2024 at 6:21 AM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers and a skewp
    I don’t think you can go wrong with either provided they were taken care of. Look for maintenance records and beware of rust!
    kwanjangnihm likes this.
  5. Jul 26, 2024 at 6:29 AM
    Brikan
    Brikan Well-Known Member
    2018 Inferno Tacoma TRD Offroad
    B&M shifter Hood gas strut Injen Intake OSC catch can
    The drivetrain is essentially the same, the gearing is a little funky from 1st to 2nd due to EPA noise limit shenanigans, the 3rd gen does have more electronic limiters, especially when in 4lo, which, kinda sucks, but helps keep you from digging the truck down to its frame, you do get ATACS and eLSD on the higher trims. It is a much more complex machine over the 2nd gen, especially in the power plant side of things.
    In the end, durability I'd say is no different, but reliability is lower. And I am using the words durability and reliability in the classical sense. They will both handle the same obstacles similarly without breaking, but the 3rd gen is not as field repairable friendly in a sense, you have more sensors, more complex systems such as VVT, high and low pressure fuel pumps, Direct injectors and all that jazz which take more tools, more parts, etc.
    3rd gen is a nicer truck on and off the road if you have the money, they are just as durable as the 2nd gens, they are more complex machines however.
    EvoRescueVehicle likes this.
  6. Jul 26, 2024 at 6:52 AM
    slossboss
    slossboss Well-Known Member
    Troy
    FL
    2013 TRD Sport 4x4 Nautical Blue Metallic
    Ultimately I think you should be open to both as you shop. as far as going 250k miles.. I think they both have similar odds, from new. In reality 3rd gens are just going to be not as old and therefore less exposed to the elements, lower mileage, etc,.
    The 2nd gens technically have a more proven record. But the 3rd gen has showed virtually no signs of being any less reliable overall. Plenty of cases of them going 300k+ already. Again this is my 2nd hand experience but I’m just trying to drive home the point that if your truck is going to go over 250k, it’s going to because of routine maintenance and overall care, not dependent on 2nd vs 3rd gen.
    I have a 2013, if I were to buy another Tacoma today.. I would be looking at 12-15. But that’s due to my preferences and bias. Test drive both if possible. My 2nd gen is outdated on many comforts and features by modern standards, but that’s partially what I love about it. Hypothetically, if you were looking at an identical (good) condition 2013 vs 2018, and the interior of the 3rd gen is not a strong preference to you over the 2nd gen interior. I’d probably take the 2nd gen considering it’ll cost about 10k less and get the same mpg ! These trucks are much more similar than they are different. Good luck !
    Chew likes this.
  7. Jul 26, 2024 at 6:56 AM
    2024OffRoad
    2024OffRoad Well-Known Member
    The 2nd gen is a better truck. A clean one would be the best option
  8. Jul 26, 2024 at 6:58 AM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    3rd gen with 2nd gen engine and trans...
    If only, all day, any day..
  9. Jul 26, 2024 at 9:12 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Allow me to stir the pot a bit. I have two neighbors that drive 1st Gen Tacomas and love them. When you buy any vehicle used, make sure it appears well maintained and well cared for.
  10. Jul 26, 2024 at 9:23 AM
    jmneill
    SE
    Is there really anyone out there that doesn't?
  11. Jul 26, 2024 at 9:25 AM
    545 Well-Known Member
    2015 Access Cab
    The only thing better than a 2nd gen
    they are tiny inside tho
  12. Jul 26, 2024 at 9:46 AM
    Clinch Mountain Preacher
    Clinch Mountain Preacher Serpent handler
    3rd gen AC SR5 4x4
    Brake controlled "LSD" is on all 4x4 3rd gens no matter the trim
  13. Jul 26, 2024 at 9:49 AM
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    What does “that much more reliable mean”?
    They are essentially the same truck and one is almost a decade newer.
    Pwakchop likes this.
  14. Jul 26, 2024 at 9:51 AM
    3rd gen AC SR5 4x4
    Massive difference between the 4.0 and the Atkinson 3.5.
  15. Jul 26, 2024 at 9:53 AM
    jmneill
    SE
    You mean they both have four wheels and a bed?
    That's about where the similarities end.
    2024OffRoad likes this.
  16. Jul 26, 2024 at 9:53 AM
    maxmk8
    And same engine and trans.
  17. Jul 26, 2024 at 9:54 AM
    maxmk8
    Short of the dual injectors nope. Same understressed pos
  18. Jul 26, 2024 at 9:55 AM
    jmneill
    SE
    Negative...
  19. Jul 26, 2024 at 9:59 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Sounds like you have more than one priority; looks and reliability
    Lol, there is always some bargain hunters out there looking for the most beat up piece of shit they can find!
    jmneill[QUOTED] likes this.
  20. Jul 26, 2024 at 10:00 AM
    3rd gen AC SR5 4x4
    lol. Sure man
