2nd Gen Torque settings
Discussion in 'Northern California' started by CaliAsh, Jun 15, 2013.
  1. Jun 15, 2013 at 1:53 PM
    CaliAsh
    CaliAsh [OP] Well-Known Member
    Jesse
    Left Coast
    2012 Taco TRD Sport DCLB
    Trail Limo
    After searching a bit, it seems torque values are kind of spread around the forums. Since I do not have a shop manual for my truck yet, I am trying to put together a set of torque setting for my 2012 in one spot.
    For now, I researched suspension items since that was my first major modification. (borrowed mostly from BJMoose's OME install thread)
    I'd appreciate any input on corrections.
    Front Suspension:
    Lower Shock Mount - 61 ft lbs
    Upper Shock Hat center Jesus bolt (take it off accidently and you will be screaming his name, or something else) - 20 ft lbs
    Upper Shock Hat Mount (3 small bolts) - 47 ft lbs
    UCA to Frame * (long pain in the ass bolt) - 85 ft lbs
    UCA to spindle (adjustment) - 60 ft lbs
    Sway bar mount to frame - 30 ft lbs
    Sway bar to spindle - 52 ft lbs
    Rear Suspension:
    Lower Shock Mount - 74 ft lbs
    Upper Shock Mount - 15 ft lbs
    Rear Leaf Pack * (Front bolt and two rear bolts) - 89 ft lbs
    Ubolts - 73 ft lbs (stock), 75 ft lbs can be recommended by some aftermarket vendors
    Wheels:
    Lugs * - 83 ft lbs
    Notes:
    * torque under load (wheels resting on level ground under truck weight)
    *edit for Ubolts* Toyota transposed numbers in the service manual for ubolt torque. It is actually 73 ft lbs and not 37.
  2. Jun 15, 2013 at 4:45 PM
    sytfu510
    sytfu510 Instagram: tacoma510
    Alex
    Bay Area
    06 DBL Cab Long Bed TRD Sport
    Dirt Designs LT kit front and 3 link kit rear SCS Wheels BAMF rack, bumper ,sliders
    Good info to have handy.
  3. Nov 23, 2013 at 9:53 AM
    rjjencke
    rjjencke Well-Known Member
    Robbie
    Arizona
    '15 MGM DCSB OR 4x4 JBL
    I have been collecting and creating this list myself for the past few days. Mainly because the 'Service Specifications - Suspension' link can be a bit confusing to a newbie.
    Torque Specs link:
    http://www.tacomaworld.com/forum/suspension/283708-torque-specs.html
    Guide of install - Front:
    http://www.tacomaworld.com/forum/suspension/31862-how-front-shock-spring-removal-8.html
    Guide of install - AAL:
    http://www.tacomaworld.com/forum/suspension/54186-aal-install-second-gen.html
    This would be a nice sticky IMO.
    PatMcKrotch likes this.
  4. Nov 23, 2013 at 10:00 AM
    BamaToy1997
    Bill
    Navarre, FL
    Some of this will be a great addition, however because there are various changes in torque value over the multiple years and platforms, you would have one VERY large list. I have access to torque specs from Toyota, and I can tell you it would take 300 lines to even try and post just the torque specs for the engines for just a few years. Perhaps limit it to certain sections of the Tacoma for specs?
  5. Nov 23, 2013 at 10:02 AM
    Taqoma
    Taqoma Well-Known Member
    Brennan
    Los Angeles
    2011 TRD Off-Road
    TRD Supercharger, TRD CAI, Camburg LT, Fox 2.5x8 coilovers, Fox 2.0 bumps, Deaver e30 leafs, Fox 3.0x18 triples, Avid sliders, Yaesu 2900R, Pro Comp 7089 16x8, DDM 55w HID Hella 500FF, DDM 35w HID headlights, Magnaflow 11255 muffler, PLX DM-100 OBDII, Autometer Ultra-Lite II Boost gauge, Flex Pod gauge mount, LSK tube bumper, McNeil fenders, Fiberwerx bedsides, 285/75/16 Toyo MT's
    I just replaced my LCA bushings and was looking to re-torque all the major points in the suspension and used the attached PDF that is floating around TW.
    Besides what is mentioned in the OP don't forget about:
    LCA to frame (cam bolts) ~100 ft lbs
    LCA to spindle ~118 ft lbs
    tie rod ~41 ft lbs
  6. Nov 25, 2013 at 12:39 PM
    rjjencke
    Robbie
    Arizona
    CaliAsh, after some research on this site, Toyota appears to have typo'd the U-bolts torque at 37. Everyone seems to think this should be 73 lbs instead.
  7. Nov 25, 2013 at 4:33 PM
    CaliAsh
    Jesse
    Left Coast
    Trail Limo
    Yeah, I need to edit that as I found that out a few weeks ago. The service manual transposed the numbers for the u-bolts.
  8. Oct 31, 2024 at 5:55 PM
    cactusred
    cactusred Active Member
    North Texas
    2013 Magnetic Grey Tacoma
    Interesting, I'm doing my 2013 Tacoma Pre-Runner TRD Offroad shocks in back and struts up front. Watched a few video's and I even went to techinfo toyota to download the official service manual info. Most of the vid's and info I'm seeing out there say on Rear Shocks, the upper nut is 15ft lbs which seems to be correct but the lower shock mount bolt most are saying 74ft lbs for a 2nd Gen and 43ft lbs on the 3rd Gen. My truck being 13 is definitely a 2nd Gen but Toyota says 43 on the lower bolt. And it's not just in one or two areas they say it, it's in several.
  9. Nov 2, 2024 at 1:40 PM
    P4x4
    P4x4 Well-Known Member
    Pascal
    2015 Dark Gray Tacoma 4x4
  10. Nov 2, 2024 at 2:27 PM
    cactusred
    North Texas
    You got me, I just went several years of Tacomas trucks on the techinfo site which is where my pic and the one posted on this page came from. I wonder if they have modified that number over the years to a lower torque. It didn't change until somewhere around 2002ish where the rear shock was like the old school shock absorbers with bolts on top and bottom.
