2nd gen to 3rd gen bed dimensions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Backwoodsraider, Jan 11, 2019.
  1. Jan 11, 2019 at 2:42 AM
    Backwoodsraider
    Backwoodsraider [OP] Active Member
    Are they the same? getting mixed answers
  2. Jan 11, 2019 at 2:48 AM
    Maint1
    Maint1 Well-Known Member
    NC
    2019 DCLB Quicksand
    17" matte black 4Runner rims
    Don't think so. Shells will not interchange.
    Backwoodsraider[OP] likes this.
  3. Jan 11, 2019 at 8:17 AM
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    As far as I know the beds are identical except for the 19s where they deleted the driver side cubby. The bedsides are completely different but the actual bed should be the same.
    tcjacado likes this.
  4. Jan 11, 2019 at 8:26 AM
    upTOPOverland_Drew
    upTOPOverland_Drew upTOP Overland Technical Design and Application
    Drew
    Littleton, CO
    2017 TRD OR DCSB SUPER WHITE
    All the things...click the link in sig
    bed size, yes
    but shells are not interchangeable because 2016+ has a much larger bed rail
  5. Jan 11, 2019 at 8:43 AM
    Dr. Emmett Brown
    Dr. Emmett Brown Well-Known Member
    3rd gen is an inch taller I think
    Outer bed sides are different dimensions
    BSFord likes this.
  6. Jan 11, 2019 at 8:45 AM
    upTOPOverland_Drew
    Drew
    Littleton, CO
    what he said
    Norsemanvike likes this.
  7. Jan 11, 2019 at 8:45 AM
    Bishop84
    Bishop84 Well-Known Member
    Bed is different, it's 1" longer. No topper or canopy is interchangeable.
  8. Jan 11, 2019 at 8:52 AM
    Sub_Par
    Buffalo NY
    2011 TRD Off Road
    Let’s clear this up, OP are you talking about the actual bed as in the composite bed or the dimensions of the bedsides?
  9. Jan 11, 2019 at 9:00 AM
    Backwoodsraider
    Dimensions like the title of the thread appreciate you all answering
  10. Jan 11, 2019 at 9:03 AM
    salmonmigration
    salmonmigration Well-Known Member
    2018 TRD Sport 6MT
    Straight from Toyota's product information documents.
    2015 Tacoma:
    Length 60.3" or 73.5"
    Depth 18.0"
    Inside Bed Width: At Tailgate 53.4" At C-Channel 56.7" Between Wheel wells 41.5"
    2018 Tacoma:
    Length 60.5" or 73.7"
    Depth 19.1"
    The floor of the bed is the same. The tailgate panel is the same but the caps are different. The main differences are on the 3rd gen there is no front rail and all the sides are about 1" taller.
  11. Jan 11, 2019 at 9:24 AM
    here4cake
    here4cake Well-Known Member
    It is 1" TALLER, not longer.
    FFS.
  12. Jan 11, 2019 at 9:27 AM
    ervandew
    ervandew Well-Known Member
    FWIW, the softopper off my 2nd gen fits just fine on my 3rd gen.
  13. Jan 11, 2019 at 9:30 AM
    upTOPOverland_Drew
    Drew
    Littleton, CO
    Softtopper rests on bed rails, it wont need to clear the edge like fiberglass
  14. Jan 11, 2019 at 9:33 AM
    ervandew
    No doubt, just noting that "No topper or canopy is interchangeable." isn't entirely true.
  15. Jan 11, 2019 at 9:35 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    but if the softtopper front forward edge sits into the wind instead of level with cab, that softtopper and frame will be under much more stress
    than a softtopper that fits and was made for a 3rd gen. I'd not want to travel far or fast with an incorrect fitting softtopper sticking above cab.
  16. Jan 11, 2019 at 9:37 AM
    ervandew
    Mine sits level with the cab, and I could tighten the straps to pull it down more if I wanted to. Lots of 80mph speed limits here, and it's just fine.
    sallad4x4 likes this.
  17. Jan 11, 2019 at 9:39 AM
    upTOPOverland_Drew
    Drew
    Littleton, CO
    @127.0.0.1 i agree with @ervandew it's negligible
  18. Jan 11, 2019 at 10:37 AM
    Sub_Par
    Buffalo NY
    2011 TRD Off Road
    And if the OP is not putting on a cap/topper/canopy then none of this matters. Instead he’s cryptic with answers so have fun hope you get the info you’re looking for.
  19. Jan 13, 2019 at 3:25 PM
    tacofish
    tacofish Well-Known Member
    N NJ
    14 ext cab 4x4
    3/1 lowrange spacer lift 285/70/17 wildpeaks
    used this thread to pick up a 3rd gen softopper yesterday
    6 months old great shape
    going to use mainly for camping
    I had a hard shell but was a pia to take on and off
  20. Jan 13, 2019 at 3:31 PM
    Larmo63
    Larmo63 Well-Known Member
    SoCal
    2019 Tacoma Access Cab TRD Sport
    Before I put my '07 TRD up for sale, I decided to try the bed mat out in my '19 because it didn't come with one.
    It fits perfectly in the new truck. Exact.
    RobP62 and Sub_Par like this.
