2nd Gen third brake light replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoma13_NC, Mar 22, 2022.
  1. Mar 22, 2022 at 11:07 AM
    Tacoma13_NC
    Tacoma13_NC [OP] Well-Known Member
    2013 SR5 4x4 DCSB 4.0L (Black) OTT
    Bilstein 6112/5160; JBA HD UCAs; 1.5" 3-Leaf AAL's w/ overload; OME CB drop; RCI aluminum skids w/ catalytic converter shields; Wheeler's U-Bolt flip kit with Superbumps; TRD Pro 4-Runner Wheels; BFG KO2's (265/70/17); Diode Dynamics SS3 Sport (Yellow) fogs; CaliRaised 32" hidden light bar; Morimoto XB LED headlights with upgraded HD harness; Unifilter mod; Rear-View mirror riser bracket; Truxedo Lo Pro tonneau cover; New OEM color-matched grille; Bumpershellz color-matched rear bumper cover; Ultra-Gauge MX 1.4 w/Spiker mount; Baja Designs S2 Sport Ditch Lights with SDHQ brackets; Fog Light Anytime Mod; Overland Tailor Tune (OTT)
    The third brake light on my truck is looking old and dated and I'd like to replace it out with a LED smoked version. I've been searching around and have found several on Amazon for around $30 that seem to fit the bill, but I'm curious as to the quality of them. I'm also planning on swapping out my factory taillights for some Alpharex Pros most likely soon. Do you have any recommendations or experiences with any of these? Thanks!
  2. Mar 22, 2022 at 11:13 AM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Tacoma13_NC[OP] likes this.
  3. Mar 22, 2022 at 11:16 AM
    Tacoma13_NC
    Thanks! That was one of the ones I was looking at. I watched a YouTube video of an install of one and it seemed to be pretty well made. This is probably what I'll go with but I just wanted to get other people's opinions first.
  4. Mar 22, 2022 at 11:22 AM
    Geeves77
    Mark
    Northeast
    2011 Tacoma DCSB
    Just do not over tighten them once snug. Leave it or plastic will crack with to unchanged torque
  5. Mar 22, 2022 at 12:40 PM
    Geeves77
    Mark
    Northeast
    2011 Tacoma DCSB
    Not sure bout that one I’ll let other chime in
  6. Mar 22, 2022 at 12:57 PM
    AJKlug1
    AJKlug1 Well-Known Member
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Full sound system, 3rd gen OR suspension, pro headlights & more
    Is it bright? have any pictures? I wasn't at all thinking about doing this but now I can't resist:D
  7. Mar 22, 2022 at 1:58 PM
    Pingu
    Pingu Member
    Romany
    Riverside
    09' Tacoma PreRunner
    Just bought that same light lol hopefully it looks sick
  8. Mar 22, 2022 at 5:47 PM
    metrick1215
    metrick1215 Pirate Medic
    Habersham GA..
    Black 2008 4x4 4door
    For the ones looking at the Amazon one above. Here's what it looks like at night.
    I like it. Looks good in the day and wife says she can see it when she drives behind me.
  9. Mar 22, 2022 at 7:15 PM
    VXEric
    VXEric Well-Known Member
    Eric
    Worcester, PA
    07 ACS V6 6 Spd TRD Sport
    265/70/17 ATs on 17x8"wheels and 0 offset Morimoto XB LED Fogs Reinforced tailgate 2011 Honeycomb grille URD Short Shifter and cue- ball style knob
    I have this one and it's been fine. Only issue I had is the pin on the connector pushed in during install and made poor contact. Thought the light went out after 4 months but it was just the bad connection. Was able to pull it back into place with pliers and it's worked fine since.
  10. Mar 22, 2022 at 7:21 PM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
  11. Mar 22, 2022 at 7:28 PM
    Minny Taco
    Minny Taco For the Horde!
    Minnesota
    2015 TRD Off Road DCSB
    - Dobinsons shocks and leaf pack - Level 8 MK6 wheels - 265/70/17 Goodyear Wrangler Duratracs load C - SPC UCA - Moog LCA - TRD Pro headlights - Bullet Proof Fab skid plate w/ Line-X - 3M Matte Black roof vinyl - Astrostart remote - Debadged - Black shifter bezel - Front window tint 50% - Color matched grill surround - MESO LED red/white map lights - Osram Super Bright H4 bulbs - Headlight Services upgraded wiring harness - Auxito LED reverse lights - Zulu Nylon Gear MOLLE visor cover - Truxedo Lo Pro QT tonneau - Weathertech floor mats - Weathertech vent visors - Redline Tuning Elite hood struts - OEM bed mat - AJT Design custom shift knob - AJT Design custom climate knobs - Center console organizer - Salex glove box organizer - 1" driver seat spacers - AntennaX 14" antenna - AVS door sill protectors - Trimmed OEM mud flaps - Candyapple red tow hook - Painted pinch weld and radiator frame - Custom radio knobs from Hondo Garage - Xtunes black tail lights - Black LED third brake light - Ruff Tuff Kryptek Typhon seat covers - ACEkraut license plate relocation bracket - Cali Raised Side Shooter ditch lights w/ lo-pro mounts - Subaru tweeters + Rockford Fosgate speakers - Thinkware F800 Pro dash cam - Stickers n shit
    I've had a smoked third brake light from Amazon for a couple years now and its worked great. If I were to do it again, I'd buy the OEM gasket just for piece of mind sake.
  12. Dec 19, 2023 at 5:47 PM
    TacoTuesday1
    FL
    I’ve got one like this
    Seems to fade yellow every year
    looks ok, cheap, works
    want to ask yall about “better” ones
    flush design (such as OEM or above) clears a shell. Softopper. Etc
    there’s barely space if you put a shell
    is there a flush upgrade that fits?
    Or anyone know/confirm what does?
    I see like 4+ upgrades out there
    -Morimoto
    -Meso
    And more
    but they all seem to protrude a lot like it would need removing to fit a shell or open a Softopper…
  13. Dec 19, 2023 at 7:45 PM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 Super White S/C DCLB TRD SPORT
  14. Dec 19, 2023 at 7:46 PM
    TegoTaco
    Ontario, Canada
