2nd Gen. Tacomas (2005-2015) -- Paint Codes w/ years used
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Xx Ares xX, May 12, 2020.
  1. May 12, 2020 at 7:56 PM
    Xx Ares xX
    Xx Ares xX [OP] Well-Known Member
    South Carolina
    2009 Silver Tacoma TRD SPORT, PRERUNNER, SR5, DC
    Naveronski, E-ROC, BizzyB726 and 5 others like this.
  2. May 13, 2020 at 1:45 PM
    EdgemanVA
    EdgemanVA Well-Known Member
    Virginia Beach
    2008 X-Runner
    Several
    Speedway Blue Metallic! Rock on!
    racerX969 and Xx Ares xX[OP] like this.
  3. May 13, 2020 at 5:21 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Got my paint for the hood and roof from them in spray cans. Just beware that you have to watch for buildup where the spray seems to collect on the recessed can top and if you don't keep a rag to wipe it off alot drips will get into your job. Told them about the spray nozzle not being high enough to clear the spray can lip (of lip too high maybe a new can they went to) but NO response so............ perfect paint match. You can get the primer and clearcoat there also so all works together.
    Xx Ares xX[OP] and TomTwo like this.
  4. May 13, 2020 at 9:11 PM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    So 040 Super White was the only color that carried through all of the Gen 2 production, then?
    (Darren’s site, formerly toyotareference.com, is really quite useful. He has lots of the advertising in addition to colors.)
    Xx Ares xX[OP] likes this.
  5. May 13, 2020 at 9:46 PM
    Skyway
    Skyway Well-Known Member
    Ande'
    St.Pete
    White 2009 regular cab
    White nail polish enamel, also a great choice as well as black...
    Well there ya go... 2 buck Chuck!
  6. May 14, 2020 at 2:05 AM
    mikkydee
    mikkydee My Taco 2007 DCLB 4x4 Man Truck
    Doyle
    Florida
    2007 Silver DCLB Tacoma, 4X4, 4.0 Liter, 6" lift, 20" rims, 34" tires
    6" lift, 20 " inch rims, 34" tires, billet grill, aftermarket fender flares, custom rear bumper, DVd player with backup camera, all LED lights
    How many cans did it take of the paint and also of clear to paint and clear coat the hood and roof on yours? Did you use the 2k clear or the cheaper clear coat?
  7. May 14, 2020 at 4:01 AM
    muddog321
    FL
    Bought 5 cans of each but 4 coats paint and 5 clear only used 4 cans each. Have the others for other areas as needed.
    Used the cheaper high gloss clearcoat 9.95 as doing inside no respirator mask. Got the spray can handle , used 1 two oz bottle of prep solvent and tac clothes, and then a clearcoat pen for other areas as I touchup. I spray some paint on cardboard then use small brush for dents/chips around truck then use that clearcoat pen (or color does not match).
    The final step after like 2 days drying is full buff out and mine is too slow so you really need a multispeed with the form head and spend some serious time on it. I was not that good so color matches perfectly but the final coat is slightly dull (more buffing later).Did sand down then dent fill in on front of hood and a full roof spots, followed by a serious prime (have to do the bondo spot areas really well sand and prime so they don't show thru the paint). Then another full sand. Sanding was a messy and dusty job. I pulled the hood spray nozzles ot but on roof only taped off shark fin antenna as looked new. At rear of roof I did a blend in and looks OK down to bottom of roof stop lamp. Pro shops pull off the bed and paint the whole area by rear window down below the bed. Its 10 years old so only did the major clearcoat/paint peeling.
    If you have a compressor I would buy (if doing it again I would) a mid grade like $75 spray gun and done that and bought a better buffer.
    Takes a whole day to do all the coats with drying time between as well as mask and tape.
  8. May 14, 2020 at 1:45 PM
    BizzyB726
    BizzyB726 Well-Known Member
    Brandon
    New Jersey
    2012 Black Tx Baja
    Got any progress pics or before/after?
  9. May 14, 2020 at 1:49 PM
    BizzyB726
    Brandon
    New Jersey
    2012 Black Tx Baja
    Is this an equivalent substitute for Black 202?
  10. May 14, 2020 at 11:12 PM
    oh6_taco
    oh6_taco Member
    Southern California
    2013 Regular Cab, 2.7L, 5-spd
    none
    What a fantastic guide. Thanks for posting this!
  11. Jun 12, 2022 at 10:02 AM
    mcl77
    mcl77 Well-Known Member
    does anyone know what paint color tge 2013 black bumper is?? there is a small rust spot i want to touch up
