2nd gen Tacoma bad control arm bolt
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nazareth7, Nov 4, 2022.
  1. Nov 4, 2022 at 8:42 PM
    Nazareth7
    Nazareth7 [OP] Well-Known Member
    2007 Tacoma 2x4
    Hi community it’s me again, I was installing lift for my Tacoma and one of the control arm bolts is stuck and not even opening but it spins some times . What should I do to get it off , I can’t install the lift currently due to that bolt.
  2. Nov 4, 2022 at 9:04 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    You wouldn’t be the first person to have to cut the bolts out.
  3. Nov 4, 2022 at 9:06 PM
    Nazareth7
    2007 Tacoma 2x4
    So what should I use to cut the bolt ? And there’s no open area to cut
  4. Nov 4, 2022 at 9:15 PM
    TnShooter
    Deogee
    STOCK
    burrito782 likes this.
  5. Nov 4, 2022 at 9:39 PM
    burrito782
    burrito782 Shit Throwing Ape
    08 TRD Off Road
    ^This. And unless you want the same shit to happen again you may want to read up...
    https://www.tacomaworld.com/threads/cam-bolt-question-now-with-answers-and-writeup.502084/
    https://www.tacomaworld.com/threads/lower-control-arm-bolts-picture-part-numbers.568025/
    TnShooter[QUOTED] likes this.
  6. Nov 4, 2022 at 9:43 PM
    Bishop84
    Bishop84 Well-Known Member
    Which control arm bolt?
    If you're trying to get the shock out and need the arms to collapse downwards and won't there's plan B.
    Unbolt the upper ball joint, make sure to unbolt the ABS line off of it and keep a bungee handy. Then ratchet strap both lower arms to each other at the far point and pull each other down.
    You may need to unbolt the sway bar link as well, but this will get the shock out.
    If you want to remove the control arm you have to cut the forward bolt, its a bastard, you need replacements before you start.
    TnShooter likes this.
  7. Nov 5, 2022 at 6:35 AM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    Very common for the lower front bolt to sieze. Use Toyota OEM bolts, they are the best alignment bolts available.
  8. Nov 5, 2022 at 9:16 AM
    Nazareth7
    2007 Tacoma 2x4
    I have 2nd gen 5 lug Tacoma, so there’s only one upper control arm on each side, the bolt of them is not coming out
    Bishop84[QUOTED] likes this.
  9. Nov 6, 2022 at 6:40 AM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    Upper control arm bolt requires one of two things:
    1. Bend the shelf metal to make clearance, or…
    2. Cut out the bolt with a sawzall using a ~9” carbide blade.
    Either way you go, I’d suggest reinstalling that big long bolt in the opposite direction when you put it back together. Use some blue loctite on the threads to help it not back off. Read these threads and make your own decision on that though.
    https://www.tacomaworld.com/threads/cut-or-bend-removing-uca-bolt.258284/page-4
    https://www.tacomaworld.com/threads/mis-adventures-removing-the-uca-bolt-on-my-2020.720105/
