2nd Gen Tacoma 4.6 V8 1UR-FE and GX powertrain Swap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dpanibratets, May 22, 2022.
  1. Aug 8, 2023 at 10:41 PM
    #841
    dpanibratets
    dpanibratets [OP] Well-Known Member
    Denis
    Vancouver, WA
    2005 DCSB soon to be with V8 1UR-FE
    Yes the B27A5 is gone.
  2. Aug 8, 2023 at 10:42 PM
    #842
    Pittsy
    Pittsy Ex car guy, currently in rehab
    Davis
    Cave Creek, AZ
    07 DCSB 4x4, 20 DCSB PRO 6MT
    BTF Fab +4.5 - DMZ SUA - TE Cage - LS6 Swap
    Still won’t even try to start?
  3. Aug 8, 2023 at 10:43 PM
    #843
    dpanibratets
    Denis
    Vancouver, WA
    Nope, doesn't even turn the starter. And I don't hear any relay clicks.
  4. Aug 8, 2023 at 10:47 PM
    #844
    Pittsy
    Davis
    Cave Creek, AZ
    Check your certification ECU. We had to take a look at mine, but make sure the ground is solid on and and obviously make sure nothings chafed or broken. Your TacomaGX thinks it’s stolen probably lol
  5. Aug 8, 2023 at 10:49 PM
    #845
    Pittsy
    Davis
    Cave Creek, AZ
    Hey, I realized you’re not using GX doors and door handles. Plug in the GX door handles/antennas.
    the door handles have sensors and antennas in it for the keyless entry.
    libagui likes this.
  6. Aug 8, 2023 at 10:50 PM
    #846
    dpanibratets
    Denis
    Vancouver, WA
    Yeah I plugged those in
    saf023 likes this.
  7. Aug 8, 2023 at 10:56 PM
    #847
    Pittsy
    Davis
    Cave Creek, AZ
    Did you ever buy a new ECM for the GX? Or is it the original one that came with the wrecked car?
  8. Aug 8, 2023 at 11:03 PM
    #848
    dpanibratets
    Denis
    Vancouver, WA
    Everything original from the wrecked GX. I will start looking into the engine codes tomorrow. You're probably right, it probably thinks it's stolen.
    Gunshot-6A likes this.
  9. Aug 8, 2023 at 11:05 PM
    #849
    Pittsy
    Davis
    Cave Creek, AZ
    I bet your non start condition is due to B279A and not the engine codes. I wonder if it's because you’re not using the GX multifunction display. You’re using the gauge cluster though aren't you?
    Kinda throwing the book at you here, probably all things you've already thought of, Im just excited to see this thing run, as im sure every here is.
    Gunshot-6A and saf023 like this.
  10. Aug 8, 2023 at 11:10 PM
    #850
    Pittsy
    Davis
    Cave Creek, AZ
    That GX should've come with a DCM, albeit a 3G one so it won't be of literally any use, but it sounds like the power management ECU talks to the immobilizer ECU through the telephone transceiver.
    did you bring the DCM over? Is there anything you didnt Bring over?
  11. Aug 9, 2023 at 12:22 AM
    #851
    dpanibratets
    Denis
    Vancouver, WA
    Okay sorry for the pictures by my wifi decided to stop working. Here is what I found. B279A is disconnect between the ECM and ID code box (which I don't know what that looks like yet). Also the location on the diagram chart doesn't help at all. The symptoms I am experiencing match to this code. Any help figuring out what this unit is would be much appreciated.
    20230809_001400.jpg 20230809_001318.jpg 20230809_001526.jpg 20230809_001422.jpg
  12. Aug 9, 2023 at 12:37 AM
    #852
    dpanibratets
    Denis
    Vancouver, WA
    I am going to sleep easier tonight know that like an idiot I chopped off the immobilizer thinking it was part of the hvac system.
    We'll try it again tomorrow.
    not_nick, Gunshot-6A, saf023 and 20 others like this.
  13. Aug 9, 2023 at 12:10 PM
    #853
    Pittsy
    Davis
    Cave Creek, AZ
    Well?
    saf023, AllTacosFloat and Toyko Joe like this.
  14. Aug 9, 2023 at 12:25 PM
    #854
    dpanibratets
    Denis
    Vancouver, WA
    Working on it now.
    not_nick, Gunshot-6A, saf023 and 6 others like this.
  15. Aug 9, 2023 at 12:26 PM
    #855
    Toyko Joe
    Toyko Joe Here for the pictures
    :eek::drool:
    so
    Close!:burnrubber:
    saf023 and Brownmatthall like this.
  16. Aug 9, 2023 at 12:32 PM
    #856
    Schlappesepple
    Schlappesepple Well-Known Member
    Joe
    2020 4Runner ORP
    Burnout emoji reminded me: this thing's going to be quick, and you should be able to launch it hard without spinning the tires.
    Not sure of your intent for the build, but some impromptu red light races might be a lot of fun.
  17. Aug 9, 2023 at 12:45 PM
    #857
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    I've looked through most pages and never caught this detail, but are you using the driveline from the Lexus and retaining the center diff?
    It's not even started yet (I know it will), but I already want one so bad!
  18. Aug 9, 2023 at 1:03 PM
    #858
    dpanibratets
    Denis
    Vancouver, WA
    Just cleared all the DTCs, Cranks but doesn't fire.
    I just did an a manual actuation test on the fuel pump, it turns on.
    https://youtu.be/fJ1a1qwGNzU
  19. Aug 9, 2023 at 1:10 PM
    #859
    Pittsy
    Davis
    Cave Creek, AZ
    Any new DTC’s pop
    Up?
  20. Aug 9, 2023 at 1:13 PM
    #860
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    Maybe it's something silly. I blew the fuse that lights up the instrument cluster on an older Cadillac. The car wouldn't even attempt to turn over until I replaced that fuse.
