2nd Gen Tacoma 4.6 V8 1UR-FE and GX powertrain Swap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dpanibratets, May 22, 2022.
  1. Jun 24, 2023 at 9:02 PM
    #681
    Pittsy
    Pittsy Ex car guy, currently in rehab
    Davis
    Cave Creek, AZ
    07 DCSB 4x4, 20 DCSB PRO 6MT
    BTF Fab +4.5 - DMZ SUA - TE Cage - LS6 Swap
    I can check tomorrow on a 2UR-GSE.
    I found this image of a 2UR-FSE online that has a 1UR stamp on it.
  2. Jun 25, 2023 at 12:03 AM
    #682
    dpanibratets
    dpanibratets [OP] Well-Known Member
    Denis
    Vancouver, WA
    2005 DCSB soon to be with V8 1UR-FE
    Interesting, any idea what the "4" means? Mine has a 5 on it.
  3. Jun 25, 2023 at 1:06 PM
    #683
    Pittsy
    Davis
    Cave Creek, AZ
    No clue. Cant find any info on it. Maybe its just signifying which mold it came out of, lol.
  4. Jun 25, 2023 at 5:07 PM
    #684
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    It’s almost certainly which mold it came out of.
    The GSE heads definitely won’t be the same. The 2UR-FSE probably won’t be either.
    I haven’t looked anything up but I suspect if anything the car 1UR and 2UR heads may be the same and the truck 1UR and 3UR heads would be the same. But maybe not.
    I’ll check later.
    Jeff
  5. Jun 26, 2023 at 10:32 PM
    #685
    dpanibratets
    Denis
    Vancouver, WA
    Well I think I lined it up pretty good. Going to take another day off tomorrow and shoehorn it in! Clears everything quite nicely. Radiator and fan are about 3/4 inch apart from each other.
  6. Jun 26, 2023 at 11:24 PM
    #686
    Schlappesepple
    Schlappesepple Well-Known Member
    Joe
    2020 4Runner ORP
    Exciting stuff, looks great as it's coming together.
    You're going to confuse some people into thinking Toyota had a 4.6L option for the truck, lol, since it's going to look like it belongs in there.
  7. Jun 27, 2023 at 12:21 AM
    #687
    mk5
    mk5 Probably wrong about this
    SoCal
    '05 access cab 4x4
    I don't know if you're still working on this AC issue... and I'm unaware of what the exact purpose of these signals is in this application. But I have a lot of experience interfacing electronics that weren't designed to be interfaced with each other.
    This totally looks like something I'd tackle with a cheap little microcontroller, like an Arduino. Compared to the complexity of the rest of your project, this would be quite straightforward, assuming you only need to deal with analog or digital/pwm signals (vs. interface with a bus)... if you can articulate what you want it to do, then it is easy to make the microcontroller do that. Sometimes you need to add in extra parts to convert between voltages, but it's pretty easy to figure out, and also easy to breadboard it to see if it works. Once you have a solution, you can design a little circuit board and solder together a permanent solution. A bit on the time-consuming side, but ultimately a convenient way to interface old and new electronics, or create new functionality that wasn't there.
    TnShooter, saf023, SR-71A and 2 others like this.
  8. Jun 27, 2023 at 12:28 AM
    #688
    dpanibratets
    Denis
    Vancouver, WA
    Ultimately yes, I will need all the help I can get to setup the coolant temp signal. The guys have been awesome on here and have located which pin I need to tap into on the ECU for rpms. The climate controls have been put on pause until the engine is in. Thank you for your willingness to help out! I will get in touch with you when the time comes.
    saf023, WilliamJames and MSN88longbed like this.
  9. Jun 27, 2023 at 6:48 AM
    #689
    Jowett
    Jowett Well-Known Member
    Brian
    North Adams, MA
    All the 2UR heads in the USA are direct injection and have electronic/motor adjusters for the intake VVTi. Both the FSE and GSE heads will bolt to the various blocks, but the timing covers are different, mainly due to the intake VVTi adjusters.
  10. Jun 27, 2023 at 10:16 AM
    #690
    Jowett
    Brian
    North Adams, MA
    I’m running (or will be) a GX460 Koyorad aftermarket stock replacement radiator in my 3rd Gen. There’s a thread around here with a pic… was planning to buy OEM Lexus, but this unit looks decent enough. OEM Lexus is now surprisingly inexpensive.
  11. Jun 27, 2023 at 10:29 AM
    #691
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Why would you do that? Inlet & outlet are on opposite sides vs the Tacoma
  12. Jun 27, 2023 at 10:42 AM
    #692
    Jowett
    Brian
    North Adams, MA
    Supercharged. Coolant ports exist that send coolant the to the proper side.
    AZ Pete likes this.
  13. Jun 27, 2023 at 2:34 PM
    #693
    dpanibratets
    Denis
    Vancouver, WA
  14. Jun 27, 2023 at 2:39 PM
    #694
    Jowett
    Brian
    North Adams, MA
  15. Jun 27, 2023 at 3:01 PM
    #695
    Jowett
    Brian
    North Adams, MA
    Pick up the oil filter cap from a Lexus IS-F/RC-F 2UR-GSE part # 15620-38030. It will allow the long oil filter from the 5.7 to fit.
    dpanibratets[OP] likes this.
  16. Jun 27, 2023 at 9:11 PM
    #696
    dpanibratets
    Denis
    Vancouver, WA
    I had some extra time today after bolting in the engine. I got the front kings mounted, still waiting on the front secondary shocks but I have plenty of things to keep me busy right now. I scored a new take off sway bar for 50 bucks with links off of a 3rd gen. Its sitting tall right now.
  17. Jun 28, 2023 at 11:51 AM
    #697
    dpanibratets
    Denis
    Vancouver, WA
    I also wanted to add that those are GX460 steering knuckles which shouldn't have sway bar holes due to gx460 KDSS and 3rd gen Tacoma sway bar mounted up just fine.
  18. Jun 28, 2023 at 1:21 PM
    #698
    dpanibratets
    Denis
    Vancouver, WA
    Lower oil pan and front diff clearance is right on the money.
  19. Jun 28, 2023 at 1:32 PM
    #699
    libagui
    libagui Well-Known Member
    Dominican Republic
    05 tacoma prerunner
    Bilsteins 5100 set at .085 Rear custom 1" add a leaf 265/70 R17 tires. Custom made aluminum tonneau cover with bike rack. 4x4 conversion with 4Runner transfer case.
  20. Jun 28, 2023 at 2:36 PM
    #700
    Brownmatthall
    Brownmatthall Well-Known Member
    Saratoga Springs, NY
    2016 TRD OR DCSB
    That is so satisfying haha
