2nd Gen Taco, same size as 1st Gen Tundra?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Marc702, Jun 23, 2013.
  1. Jun 23, 2013 at 2:24 PM
    Marc702
    Marc702 [OP] Well-Known Member
    Marc
    Las Vegas
    DC/PRERUNNER
    Since I'm new to the Toyota scene I've never really paid attention, until now.
    The second gen Tacoma's look almost the same size as the first gen Tundra's.
    True?
    Did I even get the "generations" thing correct?
  2. Jun 23, 2013 at 3:31 PM
    Mr. Biscuits
    Mr. Biscuits gentleman and a scholar
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    - OME 881s, Dakars + D43XL - Custom front tube bumper - 33x10.5R15 BFG KO2s - Deckplate mod + Airaid intake tube + AFE reusable air filter - Aero Turbine 2525 exhaust, chopped before leaf spring - Toyota Horns emblem by Diaz Fabrication - BOSS CarPlay head unit, 500W amp + 12" Pioneer in ported box - camper shell
    the tundra has a slightly larger body and wheelbase but yeah they're almost the same dimensions. there's a pic somewhere of a side by side if I can find it here in a sec I'll post it
  3. Jun 23, 2013 at 3:34 PM
    Marc702
    Marc
    Las Vegas
    DC/PRERUNNER
    Awesome, thanks.
  4. Jun 23, 2013 at 3:37 PM
    taco206
    taco206 Well-Known Member
    Tundra is bigger. Especially when comparing DC to DC because the DC Tundra has a deeper bed than the AC and its still 6 1/2 feet.
  5. Jun 23, 2013 at 3:41 PM
    Marc702
    Marc
    Las Vegas
    DC/PRERUNNER
    Well.....I guess seeing an older Tundra and a newer Tacoma on the road they just "looked" to be a similar size to me.
    For sure though, both models have grown significantly over the years.
    I think that's a good thing.
  6. Jun 23, 2013 at 4:46 PM
    TACK
    TACK Well-Known Member
    Nevada
    10 PreRunner TRD Off-Road MGM
    Bilstein 5100s at 1.75", Level 8 Tracker wheels, white lithium grease mod for creaky clutch pedal
    I had a 1st gen Tundra before my Tacoma (both access cabs) and they are very similar.
  7. Jun 23, 2013 at 6:23 PM
    12 TRD OffRoad
    12 TRD OffRoad Well-Known Member
    Robert
    South Carolina
    2018 Tacoma SR 4x4 utility package
    The 2nd gen Tacoma really isn't much bigger then the 1st gen Tacoma. I think people get a little carried away about it. I think it's only like 4 inches longer or wider (can't remember). I compared the demensions and weights between the two from Wikipedia onetime and was quite surprised about all the fuss was about compared to what I was seeing. As for as it being as large as a 1st gen Tundra I have no idea but I've parked next to a few and it doesn't really look all that close. Tundra was taller, seems wider, good bit heavier I would guess too. It's not like this gen Tacoma was a 110lb model and turned into a 200lb whale.lol
  8. Jun 23, 2013 at 6:35 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    There are significant differences in all dimensions and cargo volume except for front legroom, and the lower front legroom is offset by the higher seating position, resulting in there being more apparent legroom.
    This was discussed a couple of weeks ago and all of the measurements were posted.
    1st Gen Tundra Doublecab was significantly taller than the RC/AC... it had an extra inch and a half added at the "belt-line". The original DC was more closely related to the Sequoia than the Access Cab... the electrical and front clip were interchangeable.
    This post compares access-cab to access-cab
    http://www.tacomaworld.com/forum/2n...ure-mid-size-truck-segment-8.html#post6969414
    Keep in mind that "only a couple of inches" is a BIG difference.
  9. Jun 23, 2013 at 6:40 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    My dad has a 01 Tundy...there isnt much difference is size stock for stock...the bed is a little longer and the body is taller but its about the same
  10. Jun 23, 2013 at 6:46 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    2000 Tundra - SR5 Access Cab 4WD
    Wheelbase (in.) 128.30
    Length (in.) 217.50
    Width (in.) 75.20
    Height (in.) 71.50
    Track Front (in.) 65.90
    Track Rear (in.) 64.90
    Ground Clearance (in.) 11.40
    Cargo Bed Dimensions
    Length (in.) 76.50
    Width at Wheelwell (in.) 49.30
    Width at Wall (in.) 61.20
    Depth (in.) 16.70
    Turning Diameter (ft.) 44.30
    2011 Tacoma - Access Cab V6 4X4
    Wheelbase (in.) 127.40
    Length (in.) 208.10
    Width (in.) 74.60
    Height (in.) 70.30
    Track Front (in.) 63.00
    Track Rear (in.) 63.40
    Ground Clearance (in.) 9.30
    Length (in.) 73.50
    Width at Wheelwell (in.) 41.50
    Width at Wall (in.) 56.70
    Depth (in.) 18.00
    Turning Diameter (ft.) 40.70
    That's 32.5 sq/ft of bed area compared to 26.6 in the Tacoma.
    Even with the bed sides being over an inch shorter, the Tundra's 45.2 cubic feet STILL beat the new Tacoma's 43.4 (not factoring in the wheelwells on either, Tacoma would lose more ground if I did but I don't have all 3 measurements for the wheel wells, but Tacoma wheel wells are just over 7" wide and Tundra was just under 6" wide).
    Interior?
    Tundra SR5 Access Cab 4WD
    Standard Seating 5
    Optional Seating 6
    Front Headroom (in.) 40.30
    Rear Headroom (in.) 37.00
    Front Legroom (in.) 41.50
    Rear Legroom (in.) 29.60
    Front Shoulder Room (in.) 62.40
    Rear Shoulder Room (in.) 63.20
    Front Hip Room (in.) 59.30
    Rear Hip Room (in.) 56.60
    Tacoma Access Cab V6 4X4
    Standard Seating 4
    Optional Seating N/A
    Front Headroom (in.) 40.00
    Rear Headroom (in.) 35.20
    Front Legroom (in.) 41.70
    Rear Legroom (in.) 28.20
    Front Shoulder Room (in.) 57.70
    Rear Shoulder Room (in.) 57.70
    Front Hip Room (in.) 53.60
    Rear Hip Room (in.) 53.60
    5" wider inside, more rear seat leg room, more hip and shoulder room, 5-6 passenger compared to 4....
    The Tundra was significantly bigger in ALL dimensions other than bed wall height and front leg room.
    And the headroom/legroom numbers are deceiving. The Tundra had a higher seating position than the Tacoma. Your butt was a good 2" higher than in the Tacoma, so even though the headroom numbers are comparable at 40.3, the cab was actually taller and your legs were in a more natural "chair" position rather than the more stretched out passenger car position.
  11. Jun 27, 2013 at 1:44 AM
    Mr. Biscuits
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    ^ damn they seem neck and neck. I wonder what a test drive between the two, lifted on 33's would be like, especially with the power differences between the V8 and V6
  12. Nov 3, 2013 at 6:05 AM
    Canyonman
    Canyonman Active Member
    Sven
    Beattyville ky
    New
    De badged,murdered,hell bent steel 2.5" level kit.
    I've heard the 2nd gen tacoma is built in the 1st gen tundra frame
  13. Nov 3, 2013 at 2:17 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Totally different truck. I had a 2003.
    The 1st Gen Tundra is larger in all dimensions (except for the DCLB Tacoma.) They are close in some dimensions, but they are not the same, and the frame is completely different.
    The different wheelbase and nearly 10" difference in length tells you right there that they are not the same frame.
  14. Aug 10, 2015 at 9:50 AM
    bdunna
    bdunna Well-Known Member
    2005 tundra access cab
    It's alive. Thread resurrection. I know this thread has been dead, but as a 2005 access cab tundra owner I think an important fact has been omitted.
    Drum roll please........the tundra can fit a 4 x 8 sheet between the wheel wells with an inch to spare.
    I will say the 4.7 liter is the smoothest I've ever owned. Don't know all the details, but bases on a lexus v8. Transmission makes for a smooth transition.
    Back seat is not optimal for adults over 5ft
    SportsmanJake likes this.
