2nd Gen spark plugs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bowen_, Oct 12, 2019.
  1. Oct 12, 2019 at 10:57 AM
    Bowen_
    Bowen_ [OP] New Member
    Derrek
    2013 Tacoma- White 2D RWD
    ReadyLift Lift/ Level Kit Goodyear Wrangler A/TS Tint
    Does anyone have a good thread for replacing spark plugs on my 2nd gen? (location under the hood, best plugs to use; etc) I'm trying to learn and change them by myself for the first time:D
    TIA
  2. Oct 12, 2019 at 11:07 AM
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
  3. Oct 12, 2019 at 11:24 AM
    Lucifer1
    Lucifer1 Well-Known Member
    Lucifer
    Plano TX
    2023 Silver TRD Sport Access cab V6 automatic
    Toyota Bed divider
    My personal recommendation is start with a stone cold engine, your truck could have Denso or NGK plugs in it, or both (yeah they did that at the Factory) my preference is go back with NGK iridiums, take your time, and if possible, get someone to help you that has done this before. Plugs can be broken ( the porcelain ) when installing use anti seize,and a torque wrench to tighten them down. having the right tools plan on two hours.
    the maintenance schedule sayes stock plugs are good to 100000 Mi. In my Humble opinion, Thats marketing Hype, replace them at 60000 and see what a difference it makes in throttle response, and smooth operation.
    Good Luck
    E-Paz 732NJ and Hardscrabble like this.
  4. Oct 12, 2019 at 12:39 PM
    Bowen_
    Derrek
    @TACOVRD mine is the 4cyl 2.7L, do you know if the locations vary between 4 & 6 cyl?
  5. Oct 12, 2019 at 12:41 PM
    Bowen_
    Derrek
    @Lucifer1 im at ~ 78k, so im practically on the verge of needing them im assuming
    Lucifer1 likes this.
  6. Oct 12, 2019 at 1:32 PM
    Hardscrabble
    Hardscrabble Well-Known Member
    Scott
    McDonough, GA
    ‘20 Sport M/T AC 4WD & '15 TRDOR DCSB 4WD
    A little of this and a little of that.
  7. Oct 12, 2019 at 1:34 PM
    NYCTaco52
    NYCTaco52 Half man, half goat
    Somehow known as Stewart, but named Ben
    Ft Lauderdale, FL
    2022 Subaru Ascent
    I replace mine every 15k miles :anonymous:
    AlCapwn likes this.
  8. Oct 12, 2019 at 1:35 PM
    Hardscrabble
    Scott
    McDonough, GA
    ^^Good info^^. Always change spark plugs on a cold engine.
    Lucifer1[QUOTED] likes this.
  9. Oct 12, 2019 at 2:26 PM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    You’re joking right?
  10. Oct 12, 2019 at 2:27 PM
    NYCTaco52
    Ft Lauderdale, FL
    2022 Subaru Ascent
    Nope, I get them for like 30 bucks a set and it takes me like 45 mins to do. So I figure screw it.
    I know full well they can last 4 times that. But meh
    AlCapwn likes this.
  11. Oct 12, 2019 at 3:18 PM
    Lucifer1
    Lucifer
    Plano TX
    Toyota Bed divider
    @Bowen_
    I would say you are right on time
    Again
    Good Luck!
  12. Oct 12, 2019 at 3:27 PM
    Lucifer1
    Lucifer
    Plano TX
    Toyota Bed divider
    @NYCT52
    This is a textbook example of OCD, In my opinion you need Counseling.
  13. Oct 12, 2019 at 3:38 PM
    NYCTaco52
    Ft Lauderdale, FL
    2022 Subaru Ascent
    Indeed. You should see how often I clean my air filter o_O
    AlCapwn and Lucifer1[QUOTED] like this.
  14. Oct 12, 2019 at 8:32 PM
    Lucifer1
    Lucifer
    Plano TX
    Toyota Bed divider
    @NYCTaco52
    What? So how many air filters per spark plug change ?
  15. Oct 12, 2019 at 8:43 PM
    NYCTaco52
    Ft Lauderdale, FL
    2022 Subaru Ascent
    Got a friend that gets me OEM filters for cheap. Replaced every 5k
  16. Oct 12, 2019 at 8:44 PM
    NYCTaco52
    Ft Lauderdale, FL
    2022 Subaru Ascent
    I'll also clarify that I dont drive my taco as often as others. This year alone I've only put about 3500 miles on it
    AlCapwn likes this.
  17. Oct 13, 2019 at 12:14 AM
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    Do not use iridium plugs. Iridium plugs burn hotter. The aluminum heads on these engines are already very heat sensative. All you would be doing is adding heat and not really gaining anything. Save your money and engine and stick with normal plugs :)
    Blockhead likes this.
  18. Oct 13, 2019 at 5:10 AM
    JustAddMud
    JustAddMud Professional Grease Monkey
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    @Lucifer1 This is one of those debates for the ages. If I was at home, I'd screen grab and insert photos but alas, I'm not so link's will have to do. Since we dont know if OP has a 4 or 6 cyl, I included both. Neither of these manuals tell the mechanic to use anti-seize of any type when reinstalling spark plugs. Denso doesn't recommend using anti-seize when installing their spark plug either (http://densoautoparts.com/spark-plugs-original-u-groove.aspx#undefined), at the bottom they state that they have a 'Precision machined-rolled threads to resist seizing ...' and none of Denso's manuals request that anti-seize compound be used when installing. I was in the same boat as you, heard it from a guy who heard it from an old school mechanic whose mantra was Anti-Seize the plugs. Something may have changed in the way engine blocks are made or in the way spark plugs are made but from now on, I am no longer using anti-seize on my plugs when I change them every 30k. My '12 4.0 didnt have anti-seize when I removed them at 30k but I didnt think anything of it as I beaded on a small dab of anti-seize when I plopped in the new plugs. Long story short, I am no longer using the stuff. Are you wrong for using it? Debateable. If you were to use the stuff, use the copper based stuff high temp over the graphite based anti-seize. Copper handles the heat better. But like I said above, I wouldn't use it. http://densoautoparts.com/spark-plug-installation Additionally, using anti-seize will make it easier to over-torque your plugs, so if you do use it, reduce your torque value by ~20%. The denso installation linke that I included states that 'IF you do use lubrication IE Anti-seize, to reduce torque by 1/3' but it doesn't state that it is required and again that seems to be a catchall for all vehicles utilizing Denso for their plugs. For reference (1GR-FE: http://www.customtacos.com/tech.old...f/06toyrm/06toypdf/06rmsrc/rm2006ta/02000.pdf, 2TR-FE: http://www.customtacos.com/tech.old...f/06toyrm/06toypdf/06rmsrc/rm2006ta/02100.pdf )
    Last minute edit: https://ngksparkplugs.com/en/resources/5-things-you-should-know-about-spark-plugs
    Another post stating about not using Anti-Seize.
    This is another one of those debates, I'm all for following and using the correct plugs for your engine. That being said, 4 cylinder = Iridium, 6 cylinder = Copper. Instead of restating, I'll just quote from a previous post in this thread:
    https://www.tacomaworld.com/threads/anybody-good-at-reading-plugs.623924/
    https://www.tacomaworld.com/threads/anybody-good-at-reading-plugs.623924/page-4#post-21319775
    Make sure you 'Click to Expand' to see the whole post.
    Bottom line, changing the spark plugs isn't as bad or hard as you might believe. As long as you have the proper tools, IE Spark plug socket and wrench extentions, you should be good to go OP. Another good rule to follow, use a bit of electrical tape and tape your socket to your extention just in case your socket comes off your extention and sits in your spark plug well. You'd need some mechnical fingers or a magnet to fish your socket out. You'll do fine OP, follow the links on how to change your spark plugs that others have posted above, they have pictures. Torque your plugs to 13 ft lbs, do not over tighten.
    -J
  19. Oct 13, 2019 at 5:22 AM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    So if you change your plugs every 15k, that’s every 5 years. Doesn’t sound unreasonable.
  20. Oct 13, 2019 at 5:40 AM
    TacomaInTx
    TacomaInTx Well-Known Member
    Roger
    Eddy, TX
    2012 DCLB 4x4 TRD Sport Tacoma
    Bilstein 5100 all 4 corners, OME 886 front springs, adda leaf progressive rear packs. Front upper control arms replaced also ,Group 31 battery conversion with Odyssey gel battery . Warn winch bumper and winch. Prinsu roof rack,Full grille replacement with ridgid duallys mounted behind, and 17" SCS bronze wheels with copper 255/80/17 ,
    Not sure where you are located but... why not have a maintenance / mod party? Get the local guys together I am sure there are a few that have that experience. Learn, meet & greet and have fun in the process :)
    RoNeil and Lucifer1 like this.
