2nd Gen LCA Bushings - Recommendations?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoFNG, Feb 15, 2018.
  1. Feb 15, 2018 at 1:44 PM
    TacoFNG
    TacoFNG [OP] Well-Known Member
    Jim
    Quito, Ecuador
    15 DCSB TRD Off-Road
    Not much yet
    2015 Taco Offroad crew cab.
    Looks like I blew out one of my Lower Control Arm Bushings -
    Tacoma world searches are at least 6 months old.
    I see MOOG brand, and Whiteline online. Looks like all the Poly "Energy Suspension" require a lot of work, and reuse hardware.
    Looking for something that will be bolt on, but not looking to replace the whole LCA.
    What are your suggestions/recommendations?
  2. Feb 15, 2018 at 1:46 PM
    mtbjohn42
    mtbjohn42 Well-Known Member
    Laporte, CO
    2005 Toyota Sequoia
    I went with whiteline. I cant comment on the others. Just make sure you grease the hell out of everything!
    blu92in99 likes this.
  3. Feb 15, 2018 at 1:51 PM
    blu92in99
    blu92in99 Hates everyone, equally
    Elk Grove, Ca
    Whether you go back with stock style rubber or poly/delrin bushings; neither will be bolt-on in comparison to installing a new LCA (with regards to time/effort spent).
    New bushings would require R&I of the LCA and R&R of the bushings.
    New LCA, just R&R of the LCA.
  4. Feb 15, 2018 at 1:54 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
  5. Feb 15, 2018 at 1:57 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    How are you determining you blew out a LCA bushing? Is it ripped or torn? pics?
    I've replaced the LCA bushings with poly. It's not an easy task unless you have a press. If I was making a recommendation, I would stay with OE rubber bushing.
  6. Feb 16, 2018 at 12:17 PM
    TacoFNG
    Jim
    Quito, Ecuador
    Not much yet
    Thanks Everyone - I bought Moog brand online from Suspension.com. You need K200772 for the front, and K200773 for the back of each LCA. So buy 2 of each to replace both Driver and Passenger side LCA bushings - Cost me $10 - with USPS Priority shipping.
    To answer CROM's questions -
    First, I noticed the alignment was pulling tot he left/ passenger side. Then I noticed a distinct clunk metal sound when I went over a speed bump. Steering also seemed to be slightly sloppy. Visual inspection, I could not see anything obvious. So I took it to a local auto shop here where the owner is a friend. He put it up on the rack, and found the wheel loose, and then found the bushing damaged. I trust his judgement.
    Crom likes this.
  7. Feb 16, 2018 at 6:24 PM
    Crom
    Nick
    San Diego, CA
    Millions
    Good luck with the Moog bushings. Many reports said that they fit too loose. I run their ball joints in the upper and lower control arms, no issues with those.
  8. Feb 16, 2018 at 10:27 PM
    KCTaco77
    KCTaco77 Well-Known Member
    Kansas City
    2011 Tacoma 4X4
    3" Lift, AMP Running Boards and tailgate step, ANZO head and tail lights.
    How have the Whiteline bushings been? About to tackle this job and replace mine with Whiteline bushings.
  9. Feb 16, 2018 at 11:00 PM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    Hmm.
    I blew out most all of my UCA / LCA bushings, looked for some replacements, and then said F it, and used the situation as an excuse for buying long travel... :anonymous:
    xguntherc, bfaris1, Mully and 3 others like this.
  10. Feb 16, 2018 at 11:04 PM
    Sterling_vH111
    Sterling
    socal
    And as for signs of bushing wear (more extreme cases like mine) : wheels will shutter back and forth in the wheel well on take off and coming to a stop.
    Vid for reference: @ 0:45 sec. in
    https://youtu.be/83Pw3V8pMeI
  11. Aug 30, 2018 at 5:57 PM
    CanOfRockstar
    CanOfRockstar Active Member
    2012 Barcelona Red TX Pro
    Where did you guys find whiteline bushings for 2nd gen? Their website has nothing for our model truck. I used to run whiteline ball joints tie rod ends and rack n pinion bushings on my evo when I had it and were huuuge improvement on everything from driving straight to being very precise in steering.
    Also, anyone know if there is something like a Perrin PSRS (positive steering response system) for the taco? this mod combined with above made the difference in my previous car's steering/handling
  12. Aug 30, 2018 at 6:35 PM
    mtbjohn42
    Laporte, CO
    2005 Toyota Sequoia
    Sorry I didn't see this earlier. I have had no complaints with the whitelines. Still seem very solid!
    KCTaco77[QUOTED] likes this.
  13. Aug 30, 2018 at 6:37 PM
    mtbjohn42
    Laporte, CO
    2005 Toyota Sequoia
    I got mine off Amazon.
    https://www.amazon.com/Whiteline-W53312-Front-Control-Bushing/dp/B0070I9I12
    BandanaBerg likes this.
  14. Aug 30, 2018 at 6:43 PM
    YamaDirtrider
    YamaDirtrider Custom bumpers @FORT-ifyRigs
    Josh
    Elizabeth CO
    06 DCLB sport postrunner
    What hasn't been modified?
    @eccracer104 is who who got mine from.
    eccracer104 likes this.
  15. Aug 30, 2018 at 7:53 PM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    BandanaBerg and b_r_o like this.
  16. Aug 30, 2018 at 8:00 PM
    CanOfRockstar
    eccracer104[QUOTED] likes this.
  17. Aug 30, 2018 at 8:01 PM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Had I known my bushings were seized before I installed my Kings, I would have gone LT since the shocks are the same price, the LCA cost is the only difference basically.
  18. Aug 30, 2018 at 8:36 PM
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    Not that I want to deter you from LT but you could go with a stock length lower. There’s Solo, TC, Dirt King and LSK (lsk coming soon).
    BandanaBerg and Sterling_vH111 like this.
  19. Aug 30, 2018 at 8:59 PM
    Gunshot-6A
    Conner
    Everett, WA
    I know stock lowers exist. But for like 200 extra dollars, you'd get LT. I'll prob still go TC LCAs
  20. Apr 2, 2019 at 3:18 PM
    erdub54
    erdub54 Well-Known Member
    Erwin
    '05 Tacoma AC 4x4
    How could you tell that your LCA bushings were seized? Does it drive differently?
