2nd gen Joying Head Unit Thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ben95, Feb 7, 2021.
  1. Dec 6, 2021 at 8:45 AM
    #361
    scootter82
    scootter82 Well-Known Member
    Aurora, CO
    You do have to wire up the transmitters and camera for power and ground, but it should work with the joying
  2. Dec 6, 2021 at 10:24 PM
    #362
    Regnar
    Regnar Well-Known Member
    Kodiak,AK
    2014 DCSB PreRunner SR5
    Will it work with the head unit? Yes. Plug and Play not so much. You will have to find a 12v source which I would recommend the head units power. You will have to run a ground which again you can run off the head unit, but the RCA is plug and play. There are many ways to skin this cat but I would recommend soldering into the Joying Harness and leaving the factory wiring alone as much as possible.
    Hardest part is going to routing the wires through the firewall.
    greyboxer[QUOTED] likes this.
  3. Dec 7, 2021 at 6:48 AM
    #363
    greyboxer
    greyboxer Well-Known Member
    Pittsburgh
    2022 TRD Sport Army Green, 6MT
    Thanks for the advice man. I think I will end up taking the backup cam, and the Joying HU to a local shop to have it wired. No idea what the labor will be but at least I can get it up and running.
  4. Dec 8, 2021 at 12:32 PM
    #364
    apoteker
    apoteker Well-Known Member
    2012 DCSB O/R debadged
    JBL/Entune Touchscreen Navigation with speed sensor override mod, JBL Speaker refit, debadged, chime removed, overhead led mod, switch LED mod, rear cupholder LED mod, ImMrYo Rear-View Mirror Lift Bracket #339, Custom Cobra CB install, Iggy Switch panel, OEM Katzkin leather seats, Seat heaters, Illuminated 4runner 4WD switch, 4runner side mirrors (heated, turnsignals, puddle lamps), husky x-act fit floor mats, climate control knob upgrade, air injection pump filter mod, underhood LED light mod, KB Voodoo bike bar
    i have a 2012 non-jbl that i converted to jbl back in 2013.. with a 2009 amp. I have run into issues with the bluetooth calling on this unit... seems the problem is that the older JBL amps did not have seperate tweeter output lines, the newer jbl amps had seperate tweeter output and the phone audio was trying to run out those non-existant channels in my setup... i got around this by bypassing the jbl front speaker amp outputs and connecting the front speakers to the joying front audio output directly... not perfect, but workable until i find a better solution.
  5. Dec 9, 2021 at 7:44 AM
    #365
    Castle
    Castle Well-Known Member
    SF Bay Area
    2012 DCLB SR5
    Bumpers,lockers, gears, lift...
    Anybody have issues with the mic volume being low when making calls? Im constantly being told folks have difficulty hearing me during calls. It’s a 2012 with JBL. Joying sent me an update and it didn’t help much. Any fixes?
  6. Dec 9, 2021 at 7:17 PM
    #366
    dvose
    dvose Member
    Derek
    New York
    2015 Tacoma TRD Sport
    So i’m looking into getting the 10 inch display model for my 2015 tacoma without job and i was wondering if anyone got the obd2 and tpms options for their unit. If so what does the unit display as in for the information for the truck and if it works smoothy. I have a mvh1400nex pioneer as of now with the idatalink maestro. does this unit just plug right in and everything works without a maestro? Thanks guys.
  7. Dec 11, 2021 at 2:53 PM
    #367
    scootter82
    Aurora, CO
    Just ordered the 9". Hoping I get fast shipping from China, got an Xmas road trip coming up
  8. Dec 11, 2021 at 5:52 PM
    #368
    Regnar
    Kodiak,AK
    I think I remember reading in the Audio/Video Forum that the TPMSare not worth getting. IDK as I didnt purchase them but for the cost your still Pioneer unit new you would still come out ahead.
  9. Dec 12, 2021 at 12:44 PM
    #369
    YFZ450MOE
    YFZ450MOE When you blow off steam you get an eyepatch
    Moe
    Auburn, WA / Roseburg, OR
    09 white DCSB TRD (it's getting there)
    Icon Extended Travel 2.5" Coil Overs All-Pro U-Bolt Flip Kit Bilstien Rear Shocks Fabtech Add-a-Leaf Icon Upper Control Arms All-Pro Rear Bumper w/ Wrap Arounds & Hitch with custom LED plate light BHLM and Morimoto III D2S retrofit Satoshi Grill 2 Hella Black Magics behind Grill Bestop Supertop BAMF sliders
    Where have you guys plugged in the back (orange) and brake (blue with white strip) wires too? I'm thinking just grounding the brake so I can do whatever I want anytime. But what about back? It doesn't say backup cam or anything.
  10. Dec 13, 2021 at 4:57 PM
    #370
    apoteker
    i have the Panlong Bluetooth OBD2 from Amazon and it works well with Torque pro. I am still having challenges getting an aftermarket backup camera to work with this unit however... still trying to troubleshoot it
  11. Dec 13, 2021 at 11:47 PM
    #371
    Tac11
    Tac11 Well-Known Member
    Luis
    2011 white Tacoma sport TRD
    3" Front lift OME/5100 set at 0, 1/4 spacer on driver side CMC, BFG 285's, SCS ray 10’s -38 offset 1 inch rear block N-Fab steps Bumper Cali Raised LED light bar Cali Raised LED fog lights After market exhaust, and muffler tip Redline hood struts Tacoma Bed-liner mat Tailgate lock Tinted windows 20% HID headlights Short antenna Clazzio Seat covers Joying head unit
    Did y’all keep original stereo brackets?
  12. Dec 14, 2021 at 5:17 PM
    #372
    fizik
    fizik Accidental Offroader
    Minnesota
    '13 DCSB SR5, '10 DCSB TRD OffRoad (deceased)
    What you install for seat warmers?
  13. Dec 14, 2021 at 5:37 PM
    #373
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    I bought the truck second hand and they were already installed. I believe they are stock or were installed at the dealership by the prior owner.
  14. Dec 14, 2021 at 5:50 PM
    #374
    fizik
    Minnesota
    So, you really only need to install the 4G antennas if you are going to install the sim card and use the cell service directly on the unit, right?
    Also, does this thing take a SD or microSD card to increase memory?
  15. Dec 14, 2021 at 11:25 PM
    #375
    Tac11
    Luis
    Awesome! I just installed it and i love it. I’m struggling with Bluetooth Apple car play connection staying on. Where did you connect your cord for the car play? Did you put your iPhone charger directly on the back of the unit?
  16. Dec 15, 2021 at 11:19 AM
    #376
    fizik
    Minnesota
    On Joying's website, they show the following USB layout:
    What is the difference between OTG USB and USB? Also, will either of those support a USB hub?
    Tac11 likes this.
  17. Dec 15, 2021 at 12:17 PM
    #377
    Tac11
    Luis
    Ok yea support told me to put my phone cable directly into that otg port. They told me to not use usb extensions that came with it.
    Thoughts?
    I have a USB port entry coming out from the unit cables too
  18. Dec 16, 2021 at 12:42 AM
    #378
    Tac11
    Luis
    @TodayWasTHeDaY
    Do both USB ports connect for car play? It's the unit 2 USB ports? I'm having issues connecting with USB. Also where do you get the nova application?
  19. Dec 16, 2021 at 5:01 AM
    #379
    FourDoorsOutdoors
    FourDoorsOutdoors Active Member
    11 TRD Sport
    I used the included extension and haven't had a problem yet. I also ordered the USB port adapter so that it looks a little more factory.
    https://www.amazon.com/dp/B0742DFK2L?ref=ppx_yo2_dt_b_product_details
    No, only one of the ports allows for car play. I wanted to have a port go over to the drivers side by the switches and have one by the center console but this doesn't allow that.
    mistrchow likes this.
  20. Dec 16, 2021 at 7:48 AM
    #380
    scootter82
    Aurora, CO
    with a little bit of luck it arrives before the 23rd! Neeeeeed this before the road trip
    Shipment information received
    December, 13 2021 13:46 Local time | Service Area: HONG KONG - HONG KONG SAR, CHINA
