2nd gen double cab interior trim panel removal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BassAckwards, Jan 9, 2019.
  1. Jan 9, 2019 at 10:47 AM
    BassAckwards
    BassAckwards [OP] Well-Known Member
    2009 Tacoma AWD Turbo 2TR-FE
    Can anyone help me out with some tips on how to remove the interior trim piece that houses the seat belt in the back seat of a double cab? Trying to track down a rattling noise and need to remove this piece to troubleshoot..
    I took the bolt out that is behind the SRS airbag logo. Then also removed a screw and bolt that holds the storage box in.. that is where i became stuck and couldnt figure it out
    Here is what im trying to remove
  2. Jan 9, 2019 at 10:52 AM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    IIRC remove that bolt and screw then pull back the door seals on front and back door. You should have to remove the lower section first then access to a final bolt about midway up the B piller to remove the top piece and then obviously remove the seat belt to feed it back through.
    BassAckwards[OP] likes this.
  3. Jan 9, 2019 at 10:59 AM
    BassAckwards
    Okay that makes sense. So I need to start with the lower section? and have any tips on directionally, which way to pull on the panels when removing them? im guessing pull out towards the center of the cab?
  4. Jan 9, 2019 at 11:16 AM
    zippsub9
    Halfmoon, NY
    14 DCLB
    You will need to remove both the front and rear (kick/skid panels??) on the bottom of the door opening first. You will see the underlap for that bottom piece in the B pillar as it notches into them. Then remove the door seals just enough and you can see behind the plastic where the fasteners are. They are just snap in pieces on the bottom section. I like to use a small pry bar with tape on the end to help prevent scratching and trim removal tool as well. You will want to pull them all 90 degrees (straight out from the mounting face).
  5. Jan 9, 2019 at 11:45 AM
    BassAckwards
    Thanks much for the detailed instructions.. Gonna give this a go later this evening. Sounds like I started in the wrong area.
  6. Jan 9, 2019 at 11:48 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    At the very top of that piece there is a round plastic panel clip that's different than all the other white ones. I believe it was either green or red (it was 9 years ago for me) so I think it's stronger material. I recall it being a total bitch to get out too. Pry tools would have helped dramatically I'm sure.
  7. Jan 9, 2019 at 11:56 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    In the same boat currently.. Trying to track down a super annoying noise around the window switch panel on the drivers door :rolleyes:
  8. Jan 9, 2019 at 12:12 PM
    BassAckwards
    interior noises are the worst, and a complete pain in the ass to track down
    SR-71A[QUOTED] likes this.
  9. Jan 9, 2019 at 12:38 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    Pickup some Peel and Seal from Lowe’s so you can sounds deaden while you are in there. $17 for a 25 sq ft isn’t bad. I put it on the whole cab and front and back of all door panels. OR get a louder radio!
