2nd gen Clutch replacement suggestion?
Discussion in '4 Cylinder' started by VermonterLost, Oct 11, 2013.
  1. Aug 14, 2015 at 10:52 AM
    Scooter WCT
    Scooter WCT Well-Known Member
    Scott
    Wesley Chapel, FL.
    2014 DCSB TRD Sport 4x4 w/ 6speed Manual
    3" Lift using Bilstein 5100 Height Adjustable front shocks and complete rear Old Man Emu Dakar springs from Toytec, 17" 4Runner TRD Pro Series w/ 32" BF ATs, Tint and much more to come
    I no longer have the truck I installed the LCE Clutch in. I traded it in back in June of 2014 w/ around 70k miles (I had installed the LCE around 48k) and it was still fine. I ended up selling my old one to a good ole boy and he kept it for just over a year and traded it back in w/ 104k and the clutch was still perfect. I then sold the truck again and he will be servicing it here, so I will get to see it and check up on my ole baby lol. My 2014 V6 Taco is also a Manual and I will be replacing the stock clutch w/ an LCE near the end of the year, which will be around 40k. I drive 30k per year.
  2. Aug 30, 2015 at 1:16 PM
    Taco Pete626
    Taco Pete626 Well-Known Member
    Peter
    Southern California
    2013 Regular Cab 5-spd (Sold )
    - Undercover Flex tonneau cover - Pop N Lock tailgate lock - Weathertech DigitalFit floor liner - Sick Speed Ol' Skool white shift knob - Bench seat mod - Wiper mod - Cruise control mod
    Just curious, for those that replaced the clutch, did you guys need any adjustments to the clutch pedal? There should be some freeplay and if the clutch is catching a lot sooner, it may be because the clutch pedal freeplay was not adjusted properly. This could cause extra wear on the throwout bearing and it could be the cause of that noise you guys are describing...
  3. Jan 13, 2020 at 8:49 PM
    RyanTacoMC
    RyanTacoMC 96 Tacoma LX (RIP)
    Bay Area, CA
    2005 Base Access Cab 5-Lug RWD Manual
    4x4 Springs, QA1 TS703s, Rear Sway Bar, blah blah
    Back...from...the...dead...
    Anyone still around with the LCE? How long did it last? A love forever? Or an affair gone sour?
  4. Jan 14, 2020 at 1:09 PM
    dirtdigginjoe
    dirtdigginjoe Resident meth-head
    Joe
    Long Island, NY
    Paco The Turbo Taco
    GTX 3071r @8psi...
    I'm still running the Dual Comp kit from them. Had it on there almost 2yr to the day.
    I had initially gone to this clutch because as soon as I went turbo, the stock one slipped immediately under boost.
    I've got about 40k on the LCE clutch and I'm extremely happy with it.
  5. Jan 16, 2020 at 7:27 AM
    STEVO 1957
    STEVO 1957 Active Member
    STEVE
    2005 TACOMA ACCESS CAB, LOADED
    NONE, REPLACED COMPONENTS WITH OEM PARTS WHEN NEEDED
    Very interesting reading. I don't off road at all and got 320K out my my clutch, I swapped it out during the frame swap, saved a few bucks, I have the 2.7 4 cyl 4WD. And yes I baby this girl.
  6. Feb 6, 2020 at 5:50 AM
    TYetti
    TYetti 4cylinders of awesomeness
    Mat
    Abbotsford, BC, Canada
    09 Tacoma AC 2.7L 5spd 4x4
    I'm running the LCE pro clutch. It handles 35s so far. I wanted a clutch I could slip and wasn't an on/off switch, so far I'm happy with it. The chirping some are hearing is the throw out bearing, grease that mofo.
    RyanTacoMC likes this.
  7. Feb 7, 2020 at 12:56 PM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    What flywheel are you running?
  8. Feb 8, 2020 at 7:43 AM
    TYetti
    Mat
    Stock just had it resurfaced
