2nd Gen Access Cab Jacking points?
Discussion in 'Wheels & Tires' started by iTz IAN, May 30, 2013.
  1. May 30, 2013 at 12:11 AM
    iTz IAN
    iTz IAN [OP] Well-Known Member
    Ian
    Santa Barbara,CA
    4x4 TRD FTW
    Hey Im trying to jack up my left/right side of my taco using a 3 ton floorjack so I can rotate my front tires to the back, are the sides of the frame strong enough that I can jack from here and also where are safe jacking points.
    thanks
  2. May 30, 2013 at 12:54 AM
    Vegas Tacoma
    Vegas Tacoma Well-Known Member
    Brian
    Las Vegas
    06 prerunner sr5(RIP) 2018 Focus Hatchback
    Not to sound like a dick, but check the owners manual
    specter208 likes this.
  3. May 30, 2013 at 1:20 AM
    iTz IAN
    Ian
    Santa Barbara,CA
    4x4 TRD FTW
    I remember it saying something about using the shock mount on the rear axle but that didn't work
  4. May 30, 2013 at 1:37 AM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Anywhere on the frame will be fine.
    Under the rear differential will allow you to lift both rear wheels off the ground.
    There is a horn on the front crossmember that will allow you to lift both front tires off the ground
    JimboAnz likes this.
  5. May 30, 2013 at 3:16 AM
    pavemobile
    pavemobile Well-Known Member
    Wichita Falls, Texas
    2009 TRD Sport SR5 PreRunner
    K&N Intake
    I use a 6 x 6 x 12 piece of oak under the front cross member to lift the front and then put jack stands under the frame perimeter. Then, I use a small piece of 2 x 4 x 4 under the rear U-bolt clamp area to lift one side at a time. Depends what kind of floor jack you have though. I have used that same piece of wood under the pumpkin to lift the entire rear at the same time. Always be safe and use jack stands, cheap insurance for you & your truck.
  6. Jun 1, 2013 at 4:19 PM
    flyfishma
    flyfishma Member
    MA
    07 SR5 Double Cab Long Bed
    @maxamillion if you jack up under the rear diff, where can you put the jack stands?
  7. May 24, 2015 at 8:02 PM
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
  8. Aug 28, 2017 at 10:45 AM
    Crontegy
    Crontegy Member
    2014 DCSB TRD Sport
    Is this front jack point accurate? I hate the diagram Toyota has because it looks like the jack point is behind that point on the oil pan.
  9. Aug 28, 2017 at 7:35 PM
    tundra2tacoma
    tundra2tacoma Well-Known Member
    Greg
    Pittsburgh
    '11 DCLB SR5
    ProComp 7089 16x8, Cooper Disco ST MAXX 255/85/16, Leer cap, ome 885 and nitros in front, Wheelers 3-leaf AAL and Bilstein 5100s in the rear, ImMrYo's rear-view mirror lift bracket, BAMF LCA Skids, 4-Low yellow wire mod
    Front is accurate
  10. Aug 29, 2017 at 12:52 PM
    16Tacos
    16Tacos Well-Known Member
    Zach
    Boston
    08 Access Cab 4x4 V6 SR5
    OME Nitrochargers w/886s & Dakars, ARB Deluxe Bull Bar w/Warn winch, RCI sliders with kick out, IFS & Mid skids, BFF Hi-clearance rear bumper, Brushed Copper 17" SCS Ray10s w/285-70 KO2s, Black OEM 16" steelies w/255-85 KM2s, Leer contractor cap w/Smittybilt overlander xl RTT, Off-Grid Engineering dual battery kit and bed power panel, Blue sea aux fuse block, Wyntner 60L fridge freezer, ARB dual compressor, Pioneer 720BT head unit, CB radio, @Matt_Gecko bed and engine bay lights, @TacomaTruckParts Dirt bike tie down bar, color matched OEM grill, A-Pillar phone mount mod, @Docloco rear seat molle panel
    Agreed, that is what I used. Now that I have my skid plates on I wasn't sure where to do it but I just jacked from about the same spot on the skid plate, but seemed a little sketchy since it's just a smooth surface.
  11. Aug 29, 2017 at 4:42 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Either side of the axle tubes. The farther out the better.
  12. Jan 27, 2024 at 11:40 PM
    Reapacheap
    Reapacheap Well-Known Member
    Kam
    Memphis/Bay Area
    2015 TRD sport double cab
    All-pro Fox 3" lift, FN wheels, 33" general M/Ts
    Anyone know what the open hole on the jba UCA arms are for (comes covered with painter tape). Forgive my ignorance.
