2nd Gen 6 Speed Shifter Upgrade and Replace Tutorial (URD Short Throw)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sprockethead, Oct 22, 2019.
  1. Oct 22, 2019 at 8:43 PM
    Sprockethead
    Sprockethead [OP] Member
    Travis
    San Diego
    2006 Tacoma TRD 4x4
    King Performance RR Shocks, Total Chaos upper control arms, OME Dakar Leafs, 2.5 Degree axle shim, carrier bearing drop
    Hi all, I've been toying with upgrading my shifter on my '06 AC 4x4 for a while, and finally got around to doing it. Couldn't find any good tutorials on it, so I threw one together. Hope this can help some of you dealing with a sloppy shifter feel or those that just want a crisp (and I mean crisp), short throw.
    https://youtu.be/PhbiztnXI-8
    Egan70, lo2hi, darkyota33 and 5 others like this.
  2. Oct 22, 2019 at 10:30 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I’m an Auto. But I will say “Thanks” for the video, man.
    I do appreciate the time you took to show us how it’s done.
    :thumbsup:
    Sprockethead[OP] likes this.
  3. Oct 23, 2019 at 3:44 PM
    Jacked Burton
    Jacked Burton Well-Known Member
    35s 4.30s 6speed TruTrac Fx Pros Bilstiens Dakars
    Tires: 35/11.5/17 Toyo AT3s Wheels: FN FX Pro Gunmetal 17s with TRD center caps Zinc Metallic lettering. Yukon 4.30 gears with TruTrac Front Suspension: OME 887 w/5100s, Freedom Offroad UCAs n Superbumps Rear: Archive Hammer Hangers,Dakar Mediums, Bilstien 5125s Ubolt flip n Superbumps, Headlights: Selfmade Retrofits URD shortshift kit Airaid CAI No name throttle controller
  4. Oct 23, 2019 at 4:00 PM
    tathambenjamin
    tathambenjamin Well-Known Member
    ben
    2008 4Runner SR5
    -2.5/1.5 spacer lift -270/65/17 Cooper AT3
    Really nice. I am getting ready to do the seat and bushing. Your video is the best I’ve seen so far for this.
  5. Oct 23, 2019 at 4:48 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Nice video Sproket! I may need to do this to mine in a few years but it's nice and tight for now.
    That left thumb looks like it hurt when you smashed it!
  6. Nov 4, 2019 at 12:52 PM
    mojojojo78
    mojojojo78 Well-Known Member
    2007 Prerunner Access Cab SR5 V6 6 Speed Manual
    None... yet
    Nice video.
    Did you ever get the actual shifter fixed? It looked like in your video that it was the shifter and not the bushing that is the problem.
  7. Nov 4, 2019 at 2:25 PM
    tathambenjamin
    ben
    2008 4Runner SR5
    I did the seat, bushing, and epoxied the inside of the shifter shaft also. Feels nice and tight, makes lots of snick and clunk noises still. I installed MLV over the trans tunnel under the console. I think it made things quieter, but something in the new setup amplifies the frequency that 4th gear has. Is driving me crazy, makes more noise than ever. 1st, 2nd, 3rd have less vibration, shift cleaner. Weird.
    Your video was a great visual reference when I did this. Thanks!
  8. Nov 4, 2019 at 9:31 PM
    badger
    badger Well-Known Member
    07 SR5
    Nice video, good job!
    I have run this short throw kit for 145,000 miles now. I recently removed the shifter to do some mods to it and found that the extension was loose. The set screw had not backed out. It was still right where I staked it. Under normal use, the shifter extension will eventually loosen due to wear. I heated the set screw and removed it, then got a new set screw and re-tightened everything. My suggestion is to pull the shifter and check it every 75-100 thousand miles. You will need a new shifter tip and seat by then anyway!
  9. Nov 4, 2019 at 9:36 PM
    TacoTuesday1
    FL
    why not the Hurst Core shifter? I hear that one is the best
    mojojojo78 likes this.
  10. Nov 4, 2019 at 9:40 PM
    badger
    07 SR5
    It is much better, but also more expensive. It was not an option when I did mine. The URD kit works fine and is a big improvement for little money.
  11. Nov 5, 2019 at 6:21 PM
    Sprockethead
    Travis
    San Diego
    2006 Tacoma TRD 4x4
    I wish I could report that all my sloppy problems were fixed... But I believe that the main problem was needing to epoxy the rubber isolater from the get go. It should be a quick and easy fix, but I have to be honest, It shifts like hell right now haha.
  12. Nov 5, 2019 at 6:24 PM
    Sprockethead
    Travis
    San Diego
    2006 Tacoma TRD 4x4
    Epoxying the shifter is my next move, as this did not fix the entire problem. Made it better, but the rubber isolater has been degrading at a rapid pace since I did the job.
  13. Nov 5, 2019 at 6:39 PM
    tathambenjamin
    ben
    2008 4Runner SR5
    When I epoxied mine I pressed the shaft down onto itself. It shortened the overall length by probably and inch. It also tilted the shift knob back toward the console because shortening changed the angle.
    I have more vibration than before especially in 4th. Seems to be getting better as bushing wears in- hard to tell though, maybe I am imagining. Another possibility is that the epoxy has transmitted more vibration.
    epoxying the shifter was really quick and easy though. Took 20min for epoxy and another 10 to put back together.
  14. Nov 7, 2019 at 7:16 PM
    Waasheem
    Waasheem
    2007 xrunner
    I was hoping to find a video exactly like this, I’ll b pulling mine out soon and didn’t want to break anything because I didn’t know I should have removed a fastener first. Appreciation.
  15. Nov 11, 2019 at 2:21 PM
    Waasheem
    Waasheem
    2007 xrunner
    Here’s what I needed.
    Something to pull that carpet out of the arm rest box
    1/4 drive sockets 10mm & 8mm
    Spinner handle or ratchet & extension
    I didn’t pull my shifter off but I think it’s 10 or 12mm, it might need 3/8 drive if it’s too tight.
    The front plastic fasteners, you push the center dimple in, it clicks, then it will pull out. To get it back in, I pulled the dimple out so it’s still in it but sticking out, put it in place, then push the dimple down flush.
    I only needed to confirm what is in there, a shifter handle in dire need of epoxy repair.
  16. Dec 5, 2019 at 5:33 PM
    Jacked Burton
    I'm about to replace the seat,bushing, and install the URD short shifter kit tomorrow.
    Thanks for the Vid as a walk through before I dig in. :burnrubber:
  17. Dec 6, 2019 at 5:23 PM
    Sprockethead
    Travis
    San Diego
    2006 Tacoma TRD 4x4
    I pulled the shifter back out yesterday, due to a large amount of slop still present. Epoxied the two pieces back together as the rubber isolater had clearly deteriorated. (not sure how I did not notice it before) I used some epoxy made for cementing bolts into concrete made by Simpson Strong Tie from home depot. I also installed a new white bushing on the shifter ball end. Put it back together and it's as if it was brand new! Super happy with how everything came out.
  18. Dec 6, 2019 at 6:15 PM
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    I had no idea epoxy was a fix for the bushing. Back when I had my 06' MT, I bought the URD SS kit and one day the shifter broke in two. Later, I bought the B&M short shifter and that thing was awesome. Seems like they don't make that anymore though.
  19. Dec 6, 2019 at 8:39 PM
    bluezzy
    bluezzy Love My SuperCharged 07 Sport!
    Monty
    Eugene, Oregon
    I'm a manual guy from way back when and I kinda always thought these things were a waste of time but after seeing how bad yours was in first gear... man o man, I would find that totally unacceptable... if I ever find that I need to do mine I'll look up this vid for sure... thanks!
