2jz swap on a 2nd gen (2009)...need direction.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by livelifetolive, Jan 13, 2017.
  1. Jan 13, 2017 at 9:22 AM
    livelifetolive
    livelifetolive [OP] Well-Known Member
    SOBERDAVE
    Florida
    2009 4dr Tacoma TRD OR 4x4
    Is there anyone that has done it on a 2nd gen that I can actually talk to? A shop that does it? I have to rebuild my freaking motor again. And I'm looking at different options. I'm not looking for someone that says they can but someone that actually has on a 2nd gen not a 1st. I've seen plenty of first but that doesn't help when I have a 2nd. Thank you in advance for any info.
  2. Jan 13, 2017 at 10:06 AM
    will.carroll7
    will.carroll7 Well-Known Member
    2023 DCSB TRD OR 4x4 LR
  3. Jan 13, 2017 at 10:14 AM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
  4. Jan 13, 2017 at 11:30 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I've seen pictures of it done.
    RedRed likes this.
  5. Jan 13, 2017 at 12:08 PM
    ChandlerDOOM
    ChandlerDOOM International tent trafficker
    Chandler
    STL
    Truck
    37s yo
    If your looking for a shop to do the work then take it over to titan motor sports. If I were to tackle it myself. 2jzgte,2jz bell housing, r151 trans, wiring specialties for a standalone
    Toyojake and livelifetolive[OP] like this.
  6. Jan 13, 2017 at 1:44 PM
    livelifetolive
    SOBERDAVE
    Florida
    Yeah, I have before. Trying to see where it was again. But then there was no one specific I can talk to our get more info from.
  7. Jan 13, 2017 at 1:44 PM
    livelifetolive
    SOBERDAVE
    Florida
    Thank you, ill start there
  8. Jan 13, 2017 at 1:46 PM
    ChandlerDOOM
    Chandler
    STL
    Truck
    37s yo
    Id be curious to see what they quote you
  9. Jan 13, 2017 at 2:51 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  10. Jan 18, 2017 at 12:53 PM
    livelifetolive
    SOBERDAVE
    Florida
    Got my first quote today. I can see why there's not that many out there. All n all, everything done. About 12k to 15k turn key. I would have to probably change it to manual also
    ChandlerDOOM likes this.
  11. Jan 18, 2017 at 1:02 PM
    Toyojake
    Toyojake Well-Known Member
    Jay
    Central TX
    2009 T4R Sport 4x4
    Why wouldn't they keep it automatic? The 2JZ in the supra comes with the A340 4spd which is the same as the AW4 that goes behind the 4.0L Jeep motor, and almost all of those are 4x4. Build up one of those, and drop an NP231 behind it.
  12. Jan 18, 2017 at 1:03 PM
    Toyojake
    Jay
    Central TX
    2009 T4R Sport 4x4
    And not to mention the AW4 has a standalone TCM, and I think the A340 was integrated into the ECM.
    livelifetolive[OP] likes this.
  13. Jan 18, 2017 at 1:07 PM
    ChandlerDOOM
    Chandler
    STL
    Truck
    37s yo
    12-15k is better than I thought it would be, mind sharing who you got a quote from
  14. Jan 18, 2017 at 2:06 PM
    livelifetolive
    SOBERDAVE
    Florida
  15. Jan 18, 2017 at 2:12 PM
    livelifetolive
    SOBERDAVE
    Florida
    ChandlerDOOM[QUOTED] likes this.
  16. Jan 18, 2017 at 2:48 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Almost 10 years ago, that was the same price. ;)
