2GR-FKS failure at 150K, looking for input/some questions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Woodythebluetaco, May 10, 2021.
  1. May 10, 2021 at 11:02 AM
    Woodythebluetaco
    Woodythebluetaco [OP] Well-Known Member
    2016 Tacoma SR5 Blazing Blue
    Stacked plate transmission cooler Front: Custom Fabtech 2.25 Resi Coilovers, King springs, Eibach Tenders Rear: Fox 2.0 Resi, Custom OME Dakar Leafs, Caltracs Rebuilt 3.5
    Good morning everyone. So like the title says, my 3.5L 16' SR5 with 150,000 miles died on me two days ago on the way to work. I'm not talking about catastrophic failure like many of the posts on this site have been regarding the 2gr-fks, the damn thing went out with a whisper.
    I was lined up with some cars waiting for my turn to drive through a one-lane construction zone, when I moved to drive through, the dash put up the "Trans temp too high - low oil pressure" warning and swapped over to limp-mode, no grinding, no jolt or sudden stop, if it weren't for the warning I wouldn't have noticed the truck died. I initially assumed it was another failed CMPS, since that's exactly how it presented once before around 60,000 miles (before the CMPS TSB came out) but after getting pulled to the side, the truck wouldn't turn over, even after a battery reset.
    Got the truck towed home, waited around 8 hours and went to turn the truck over again and heard the starter grind against the flywheel. Let it rest a bit figuring there may be a flooded cylinder, when I tried again the next day I heard that telltale single "CLACK" when I turned the key.
    I've ran a scanner and found no pending, current or history codes(this was before pulling the battery). No loss of coolant, oil is clean with no shavings (changed about a month back), and no damage to the outside of the motor, battery is strong. I tried turning the engine over with a breaker bar with the truck in neutral and no luck, so it seems that the motor seized but for the life of me I can't figure out why.
    I maintain the truck like a motherf@cker, oil change and filter ever 3k - levels chacked every day, spark plugs at 66k, coolant always checked and air filter cleaned on the regular.
    Any thoughts or previous similar experiences would be appreciated.
    My next steps will be to remove the upper intake and spark plugs and try to turn the engine by hand again, if that doesn't work I can't imagine it could be anything but a locked motor and from there it'll be a teardown top to bottom to figure out what the hell happened.
    The fun part is a new 2GR-FKS runs $21K (On Sale! :D ), and a used 2gr runs $3k. Hopefully its something salvageable.
    Running Board Man and k20pham like this.
  2. May 10, 2021 at 11:22 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    Sorry to hear that. Not a lot of things that can cause that without making some noise prior to failure. I am thinking the timing chain let go and you are jammed against the valves. Hopefully you will update us with your findings when you tear into it.
    RedWings44, SR-71A and SandyTaco4x4 like this.
  3. May 10, 2021 at 11:26 AM
    Itchyfeet
    Itchyfeet Well-Known Member
    I'd be on LKQ looking for a used engine
  4. May 10, 2021 at 11:33 AM
    ToyodaSun
    ToyodaSun Well-Known Member
    Parts Unknown
    17' DCLB TRD OR
    Subbed to see where this goes. Sorry to hear about your troubles, hope you are able to figure this out expediently.
    I picked a truck that came with a lifetime powertrain warranty for this exact reason. Random stuff happens.
  5. May 10, 2021 at 11:36 AM
    littlefish
    littlefish Buzz, your girlfriend...
    Hudson Valley NY
    2016 TRD Off-Road DCSB
    The one who dies with the most stuff wins.
    Good luck on your search for answers OP. Please give us updates, and don't fall off the face of the earth like the last few guys to have a catastrophic failure. The collective blue balls in the search for answers is slowing killing us all.
  6. May 10, 2021 at 11:38 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Let's not compare blue balls, okay? :D
    Good luck, @Woodythebluetaco !
    :cheers:
    Junkhead likes this.
  7. May 10, 2021 at 11:39 AM
    TacoGreg
    TacoGreg Well-Known Member
    Tomball TX
    2017 Tacoma TRD Sport 4x4
    Oil pump failure caused the seize?? :confused:
  8. May 10, 2021 at 11:40 AM
    eurowner
    eurowner Duke Sky
    Scoty
  9. May 10, 2021 at 11:41 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
  10. May 10, 2021 at 11:45 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Another car motor?
  11. May 10, 2021 at 12:00 PM
    coopcooper
    alberta canada
    yes
    GillyLink, Junkhead and MaverickT883 like this.
  12. May 10, 2021 at 12:02 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Geez. At least put a truck motor in thar.
  13. May 10, 2021 at 12:04 PM
    CDNTacoma2019
    CDNTacoma2019 Well-Known Member
    Ontario, Canada
    2019 SR5 DCLB 4x4
    Same....then off to the Toyota dealer to trade it in on a 2021 before engine two blows.
    Seventh and Woodythebluetaco[OP] like this.
  14. May 10, 2021 at 12:14 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Can u pull codes? Might be some good freeze frame data in there.
    Woodythebluetaco[OP] likes this.
  15. May 10, 2021 at 12:46 PM
    Woodythebluetaco
    I wonder if there are 3rd gens out in the LKQ yard, I hadn't seen any before but I guess there are a lot more third gens out there @Itchyfeet. We'll see.
    @coopcooper @tonered , I looked up the cost of a new 2GR and when I saw it was $25K I immediately looked up turnkey manual hellcat crates ($29K) but then came to my senses and looked up used 2gr's. But still, an LS turnkey crate with an auto trans runs around $8k....
    @Arries289 @TacoGreg @Skydvrr I checked history codes and data on my scanner before I pulled the battery and it came up clean except for some voltage issues in the headlight array. Had I known it wasn't the sensor I would have waited to run a full diagnostics before the hard restart.
    Oil in the pan was clean, no burnt smell that I would imagine would be there with an overheat failure. Looks like the 2GR is non-interference so fingers crossed it's a timing chain that jumped or broke and damage is limited to the timing assembly, not cheap but not motor-swap $$.
    If the upper end is damaged, it may be an opportunity to swap out with some MWR valves and springs, maybe a cam... if the engine really is non-interference and the upper end is okay, then maybe some MWR valves and springs, maybe a cam...
    Requesting some vacation time off from work in a couple weeks, I'll update on the tear-down then. My only anxiety is having to dig to find all the torque values and procedures when (hopefully) slapping everything back together.
  16. May 10, 2021 at 12:50 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I was mainly joking about motors.
    Check car-part.com also.
    Lemme maybe help here with a couple SM choices:
    http://www.ttguide.net/toyota_tacoma_2015_2018_service_manual-171.html
    Or a PDF (140mb):
    https://drive.google.com/file/d/1cx5nnlnCzlhI45D1vbBMj1ni983SKdKf/view?usp=sharing
    There is also a Torque Listing somewhere, but it might be more 2nd Gen stuff?
  17. May 10, 2021 at 12:52 PM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    You mentioned the Trans warning. You ever check the oil level and quality on that? Wonder if something in the TC failed and thats whats locking it up...?
    Chew and Jason J like this.
  18. May 10, 2021 at 1:02 PM
    Woodythebluetaco
    @SR-71A I top-off and drain the excess fluid in the trans with the oil-change. The ATF fluid gets burnt real quick otherwise, I've found. That warning comes up in reference to the Camshaft position system too, apparently so I figure it could be a timing issue more so than a trans issue, hopefully.
    If it is the trans locked up and fused with the motor, I'm gonna lose it. Had that happen to a 93 blazer.
    saf023, SR-71A, Taco_Coma and 2 others like this.
  19. May 10, 2021 at 1:03 PM
    Woodythebluetaco
    @tonered Thanks for the links! got some reading to do.
    tonered likes this.
  20. May 10, 2021 at 1:04 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You're welcome!
