2GR FKS ENGINE
Discussion in '2nd Gen. Tacomas (2005-2015)' started by snakefist, Nov 24, 2021.
  1. Nov 24, 2021 at 3:42 PM
    snakefist
    snakefist [OP] New Member
    kelvis
    tacoma 2005
    n/a
    Hi, I am currently having issues with my 1GR FE engine for a 2005 Tacoma. I had a damage conrod bearing and rod due to seemingly oil starvation. I machined the crankshaft and fitted 10 thou' bearings twice after noticing metal shavings from bearings in the engine oil. I suspect it may be a damaged oil pump that is causing and has caused the initial problems. My mechanics are very hard headed and will not carry out any research. With that said, I have started sourcing a replacement engine for my truck but is having problems finding a 1grfe. I came across a 2gr and was wondering if it could fit in a 2005 Tacoma.
    Geeves77 likes this.
  2. Nov 24, 2021 at 4:43 PM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    It would physically fit, but it wouldn't be a plug and play swap. I'm surprised you're having issues finding a 1GR, there are tons of them out there, but I suppose it could depend on your region.
    Jeff
    rheath08, Dm93 and TnShooter like this.
  3. Nov 24, 2021 at 6:40 PM
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    I had the same problem recently. There are some used engines, but high miles and 30-90 day warranty with no extension.
  4. Nov 24, 2021 at 6:44 PM
    Bishop84
    Bishop84 Well-Known Member
    No, you'd need engine management and harness from a 2016+ tacoma, that would bankrupt a small nation.
    Most 2nd gens get short blocks now from Toyota and do a headmill/refresh.
  5. Nov 24, 2021 at 6:56 PM
    metrick1215
    metrick1215 Pirate Medic
    Habersham GA..
    Black 2008 4x4 4door
    is it possible. Yes... just depends on how deep your wallet gets.
    to do a 2gr Looks like you could get the computer from ebay for about $200 with a warranty, and the wiring harness off a few sites in google search from $300-600. I would say your biggest problem would be transmission mounting, motor mounts, rework of plumbing (AC,intake,radiator etc) Plus sourcing a motor. and im sure there is more that would need to be sourced or fab'd.
    I also am surprised that you are having problems finding a 1GRFE. They are usually a dime a dozen with as many years and vehicles they came in.
    Have you checked these? Not sure what your budget is, but
    Clicky
    or Clicky
    or Clicky
  6. Nov 24, 2021 at 8:00 PM
    Jeff Lange
    Calgary, Canada
    The 1GR-FE and 2GR-FKS (from a Tacoma) use the same engine mounting and transmission bolt patterns. A/C, intake, radiator could all be used from a 2016-2022 Tacoma without much modification. So yeah, you'd need to get the associated bits as required, but it wouldn't be much if any fabrication, just need to get the right stuff to do it.
    Personally, I would say the electronics would be the most difficult to get fully sorted.
    Jeff
    metrick1215[QUOTED] likes this.
  7. Nov 24, 2021 at 8:06 PM
    rheath08
    Russell
    Bakersfield, CA
    He will need the 3rd gen transmission. they may bolt up but the ecu will not control the A750" trans properly, if at all. I say if your chose to go the route of complete drivetrain swap then put a v8 setup in there. Even it is the 4.6 or 4.7 from the GX series. Now that I think of it, a lot of them are using the A750" trans.
    Naveronski likes this.
  8. Nov 24, 2021 at 9:40 PM
    Jeff Lange
    Calgary, Canada
    That's true if it's an automatic, but if it was a manual, his original transmission and clutch would bolt up with a 2GR flywheel.
    Jeff
    rheath08 likes this.
  9. Nov 24, 2021 at 11:48 PM
    TacoTuesday1
    FL
    don't 3rd gen Taco engines have problems
  10. Dec 30, 2021 at 9:38 AM
    Woodythebluetaco
    Woodythebluetaco Well-Known Member
    2016 Tacoma SR5 Blazing Blue
    Stacked plate transmission cooler Front: Custom Fabtech 2.25 Resi Coilovers, King springs, Eibach Tenders Rear: Fox 2.0 Resi, Custom OME Dakar Leafs, Caltracs Rebuilt 3.5
    the 2GR-FKS in the 3rd gen has the same issues as the 2GR-FSE from the second gen, the two motors are very close castings with different heads to achieve a higher compression ratio and to accommodate the new VVTI Wide system in the 3rd gen.
    Like the 2nd gens, some 3rd gen fks engines have an issue with oil starvation to cylinder #5 causing overheating of the cylinder and increased risk of a rod going bad and taking out cylinder #5 and #6, probably cracking heads in the process.
    It seems to tend to happen more if there’s an issue with timing or improper service intervals leading to dirty oil. The service life for the top end on a 2GR fks is to 150,000 miles at which point it will need replacement/overhaul to avoid failure (which requires the removal of the engine from the truck).
    Torspd likes this.
