2GR-FKS Direct Injection
Discussion in '3rd Gen. Tacomas (2016-2023)' started by geekspeed, Jul 23, 2023.
  1. Jul 23, 2023 at 1:02 AM
    geekspeed
    geekspeed [OP] Member
    2017 TRD Sport / 2016 4Runner SR5
    Flowmaster 40 Series Cat Back dual rear exit Spare Tire Delete Yotaverse Trd Grille w/ Raptor Lights / DRL SoundAlert Lamphus 100w / 130db Horn American Outlaw 16x9.5 w/ Goodyear Wrangler Duratrac 265/70/R17
    Reading up on fuel delivery in my 3rd gen an something hit me.
    As I understand it, single fuel pump that supply to a Y in the engine bay. 1 end goes to the port injection "fogger" that fogs into the intake, the other goes to a mechanical pump for direct injection.
    The ecu determines when each (or both) are in use. This is why idling will see the engine randomly ramp up (direct injection kicks in) an fall.
    So if one could programmatically control that function: ideally a secondary microcontroller that would inform the ecu it's time to switch, or just hijack the electrical signals but also relay the proper responses back to the eco so no trouble codes. One could then permanently disable direct injection.
    Going one step further - one could also use that same system, with their own controller for either a nitrous or methanol setup.
    A dry nitrous system could easily be worked into the port injection, an have main fuel delivered via the direct injection. Though a wet nitrous system could take advantage of either and utilize the secondary controller to make sure the proper amount of fuel is available at all times.
    Methanol/Alcohol would be similar as the dry nitrous but only utilizing the port injection.
    Just something I was pondering...am I nuts here?
    Only caveat: with this motor being an Atkinson cycle as opposed to an Otto cycle - breathing becomes an issue with alcohol (not so much with nitrous) an you may have to add on some forced induction.
    Thoughts?
  2. Jul 23, 2023 at 3:32 AM
    099 Well-Known Member
    2022 White Tacoma Double Cab SR5
    Ummm...... Sure.
    Old goat1914 likes this.
  3. Jul 23, 2023 at 4:37 AM
    Gfenza89
    Gfenza89 Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    The port injection is similar to “regular” port injection it doesn’t have an injector in the intake manifold . The injector sprays directly behind the intake valves
  4. Jul 23, 2023 at 5:05 AM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    Why yes, yes you are :anonymous:
    Blak Shinobi and Chew like this.
  5. Jul 23, 2023 at 5:10 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Screen name checks out...
    Chew likes this.
  6. Jul 23, 2023 at 7:52 AM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    The Atkinson cycle can be tuned out. Similarly, the DI and PI can be tuned to your liking using vF Tuner.
  7. Jul 23, 2023 at 8:14 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Chew, FL_TRD Sport and Hammerstorm like this.
  8. Jul 23, 2023 at 8:30 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Better keep reading.
    shakerhood likes this.
  9. Jul 23, 2023 at 8:48 AM
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    You want to run meth on an underpowered and relatively fragile Tacoma engine? Just making sure I read this correctly
  10. Jul 23, 2023 at 8:57 AM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Fragile? Some folks ran twin turbo on it.
  11. Jul 23, 2023 at 8:58 AM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    I imagine that it would be easier to install your own nitrous or methanol injectors in the manifold than to utilize the existing system. Plus, those port injectors are there to keep the intake valves clean. Believe me, you don’t want coked up valves and stems.
  12. Jul 23, 2023 at 8:58 AM
    Gfenza89
    These people who say fragile crack me up. There’s nothing fragile about this engine.
    Junkhead, RedWings44 and Pwakchop like this.
  13. Jul 23, 2023 at 10:30 AM
    turkeyslayer66
    turkeyslayer66 Well-Known Member
    mike
    22 AG Trd Sport
    Over 1 hp per cubic inch is hardly under powered by any measure. 6000 rpm horsepower
    peak doesn't indicate a fragile engine to me. I would like to see how one runs with a small hit of n.o.s.
    Pwakchop likes this.
  14. Jul 23, 2023 at 10:34 AM
    soggyBottom
    soggyBottom Well-Known Member
    The direct injection allows the engine to run super lean. If you disable it, you may need to also return the fuel maps.
  15. Jul 23, 2023 at 11:00 AM
    AM6217
    AM6217 Well-Known Member
    2021 SR-5 DCSB Silver metallic
  16. Jul 23, 2023 at 11:17 AM
    soggyBottom
    The fueling is way more complicated than these 2 graphs. This is stock on a 2018 3.5. I'm not sure what "fuel time" means. It could be duty cycle e.g. miliseconds. The second graph is probably more interesting here since it shows the difference in fuel between the two types of injectors. Note the part about "0" being 100% direct injection.
  17. Jul 23, 2023 at 2:55 PM
    Vlady
    Issy, WA
    Could you please clarify? Are you saying tacoma runs lean in DI mode?
  18. Jul 23, 2023 at 3:51 PM
    soggyBottom
    Let me clarify that I'm not an expert in this. When running a traditional engine (carbureted, fuel injected, etc) too lean, NOx emissions go up. Normally A/F is limited to around 14.64:1 while LDI (Lean Direct Injection) allows around 40:1. I don't fully understand the mechanism of being lean and not creating NOx. From what I've read, in lean combustion engines, the excess air acts as a heat sink, which lowers the flame temperature and reduces NOx emissions.
    Here is a paper from Toyota, 1996 which talks about D-4 and ultra lean combustion. https://global.toyota/en/detail/7901843
    In there, they mention air fuel rations of 50:1
    Another area where this technology is used is in jet engines. The GE9X (largest jet engine ever made) uses this same concept to lower NOx and save a ton of fuel. Here is a video clip explaining NOx formation and how the GE jet engine overcomes it.
    Skip to 18:20
  19. Jul 23, 2023 at 4:04 PM
    lavrishevo
    lavrishevo Well-Known Member
    2023 Trail Edition
    WMI, or water meth injection is often used on forced induction platforms to provide extra fueling capabilities when you don’t have access to e85, which allows for CPI, or charge pipe injection. WMI offers cleaning and cooling benefits over CPI but requires a separate fuel tank vs cpi tapping off the LPFP. It’s also expensive to buy quality methanol. I ran WMI / e40 on my tuned Kia Stinger pushing the motor up past 500 hp. Methanol also has as high as 111 octane vs e85 maxing out around 105. Anyway, yes if you put a turbo or supercharger on the Tacoma it could benefit from this kind of setup but nobody seems to be tuning for it. If you can’t control the MAF / fueling to target the correct AFR you can f’up your motor pretty easily. I run e30 in our family commuter / wife’s daily. It’s a Tucson Hybrid our a 1.6t that will easily roast my Tacoma pushing 25 lbs of boosts. Stock is about 13 - 15. It’s all about octane and keeping timing up.
  20. Jul 23, 2023 at 4:14 PM
    Vlady
    Issy, WA
    I think all this died after Lexus IS250 fiasco.
    2gr-fks is no near these numbers. Tacoma runs on reach side.
