295/70/17
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dr. Emmett Brown, Feb 22, 2020.
  1. Feb 22, 2020 at 10:02 PM
    Dr. Emmett Brown
    Dr. Emmett Brown [OP] Well-Known Member
    Update. Tires are on. Will update how much trimming needs to be done to fit them offroad.
    Just order some 295/70/17 mud tires. I'm on a 2.5" front and rear lift and I have JBAs already on the truck and have CMC plates sitting at home ready to weld on. My alignment shop said they might be able to fit them without a chop so I'm holding off until I see for sure they rub off-roading.
    I also have a pretty aggressive bumper chop, cuz why not lol.
    Anything I'm gunna need to do to prepare for mounting or should I just wait and see what rubs?
  2. Feb 22, 2020 at 10:06 PM
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    Wait and see but I would bet the cab mount is going to rub close to full lock
  3. Feb 22, 2020 at 10:12 PM
    Dr. Emmett Brown
    On 265/70/17s I'm about 1/2" away at closest point but that's on flat ground
    I also think I'm only at about 3 degrees caster at most so maybe they can squeeze a little more out of the JBAs.
    El Duderino[QUOTED] likes this.
  4. Feb 22, 2020 at 10:18 PM
    Tbrooks2444
    Tbrooks2444 Well-Known Member
    How bad you rub will depend on wheel specs. I had 295/75r16 and I had to do the cab mount chop as well as fender liner/fender trimming. It’s really not a huge deal. Cut the mount, plate it, weld it, good as new. I cut the fender and fender trims very meticulously with a small Dremel. Took my time and made it as hard to notice as possible.
  5. Feb 22, 2020 at 10:20 PM
    Tbrooks2444
    You may also find that you wished you just went with the typical 285/70r17 as they are just going to fit better than the 295s and there’s always going to be more of those sized tires available in case of blowout or damage on the trail leaving you in need of a quick fix. Have a full size spare and call it good.
  6. Feb 22, 2020 at 11:47 PM
    Dr. Emmett Brown
    Great advice! I'm going to see how I like 295s.
    I went with 265 right off the bat and always wished I went with 33s so when I decided to get bigger tires now I knew I wanted to go with bigger than 285s because I would inevitably want bigger tires so I think 295s will hopefully be a good balance of bigger with minimal fitment issues.
    I'm running 17x8 wheels with 0 offset so I'm thinking those specs will help to limit my rubbing issues.
  7. Mar 1, 2020 at 3:04 PM
    Dr. Emmett Brown
    It's like Tetris tryna fit everything. Tires finally in. Will be mounting them this Tuesday so I will update fitment issues for on road use within the week and offroad use within the next two weeks. Probably gunna go ahead and do the CMC this week because why not.
    El Duderino and Flkracker like this.
  8. Mar 4, 2020 at 6:59 AM
    Dr. Emmett Brown
    295/70/17 on
    Caster maxed and still have a little rubbing on passenger side rear of front fender well plastic under compression and cab mount. Will be doing CMC asap.
  9. Aug 19, 2022 at 7:34 PM
    Cschauer22
    Cschauer22 Member
    Cody
    2020 Magnetic Gray TRD
    4” lift
    Just installed 295 70 17 Toyo MT with zero rubbing or trimming. No wheel spacers
    Cemeterygate and Thewhite_emu like this.
  10. Aug 19, 2022 at 7:42 PM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    You'll probably rub at full compression
    AmateurTaco1313 likes this.
  11. May 22, 2023 at 12:29 PM
    B.Andy405
    B.Andy405 New Member
    William
    Black TRD OR 4x4
    •King 2.5” Extended travel Front and rear suspension •285/70/r17 Yokohoma geolandar MTs •Trd pro 4runner wheels •Morimoto gen 2 XB LED headlights (amber drl) •Baja designs squadron fog lights •Souther Style Off-road slimline hybrid front bumper •Heise led 20” bumper lightbar •Prinsu roof rack •Cali raised 40” lightbar •Warn Zeon 10-S winch •Trd Pro grille • BMC
    How much lift are you running in the front and what UCAs?
  12. May 22, 2023 at 6:35 PM
    1dayKapaa
    1dayKapaa Well-Known Member
    Northern VA
    2019 Tacoma DCLB
    Great size and still goes in the spare. I just moved away from it tho.
  13. May 23, 2023 at 2:20 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I want 285/75s next.
  14. May 23, 2023 at 2:34 AM
    TrdTaco20
    TrdTaco20 Well-Known Member
    CenCal
    2020 trd off road cement
    Front Fox 2.5 coilover dsc, rear chevy 63 fox 2.5 12inch shocks
    I have 17x8 0 offset motegi trail lite on 295 70 17s, i did CMC and heated back fender liner to push it back, they got close to rubbing, just did it to clear when tire tucks up at compression
    Cemeterygate likes this.
  15. Sep 21, 2023 at 1:21 AM
    hmgtaco09
    hmgtaco09 hmgtaco19
    2019 Tacoma TRD off-road dlbcab
    Bilstein 5100, OME 887 Coils second notch, SPC UCA, Deaver 1.5-2 AAL
    How high is your lift and what kind of mpg do you get nowadays? I have the same truck, same year and trying to upgrade to bigger tires from 285/70r17. I already have a cmc I was wondering if there will be any additional trimming.
  16. Aug 27, 2024 at 12:06 PM
    Thewhite_emu
    Thewhite_emu Well-Known Member
    2017 tacoma trd offroad
    Ome 3" front lift (887 coils & nitrogen sport shocks) 2" ready lift rear blocks w/ ome nitrogen sport shocks 285/70/17 bfg k02's on 17x7 trd pro 4Runner wheels Bakflip teaunno cover N fab step bars Heritage grill 15% window tint
    Hey how did this tire size and wheel combo work out? I have 285’s and wanna go bigger and have the stock 17” trd pro wheels like you. Did you ever have any issues ? Thanks
