285's and alignment
Discussion in '3rd Gen. Tacomas (2016-2023)' started by NwNative, Mar 6, 2024.
  1. Mar 6, 2024 at 7:27 PM
    NwNative
    NwNative [OP] Member
    tacoma
    hey First post here! I ordered 285/75/17s for my 3rd gen, I understand what it takes to properly fit them. question is where are you guys going for alignments with bigger tires? will les shwab do it properly or should I go somewhere else? im in western washington.
  2. Mar 6, 2024 at 7:37 PM
    Veet-88
    Veet-88 Well-Known Member
    18 Tacoma DCLB sport
    What wheel offset, do you already have a cmc? What UCA?
    I think I'm at 4.5 with 295's on -25 offset dirt king uca's
  3. Mar 7, 2024 at 4:08 PM
    NwNative
    tacoma
    im on stock trd wheels 17's. i have not done my cmc yet, I will be doing it this next week. Im also runing icon 2.5 lift kit and add a leafs, and stock upper control arms. Do you think i will be able to get an alignment with stock upper control arms?
  4. Mar 7, 2024 at 9:51 PM
    Veet-88
    Maybe but I wouldn't think you'll hit a good alignment depending on how high of a l8ft you do. Not sure if your saying you have a 2.5 kit or a 2.5 lift. And are those the trd pro wheel or trd OR wheels. Best to know the full specifics of the wheel.
  5. Mar 7, 2024 at 11:16 PM
    NwNative
    tacoma
    I have a icon 2.5 kit, roughly getting around 2.5 inches of lift. and they are trd pro wheels that came on the 4runner 17x7 I believe, +4 mm offset and 4.5" bs. thanks for your response hopefully I can get a good alignment, if not ill look into upper control arms. here is a picture of the truckPismo.jpg
    winnipegbeachtacoma90 likes this.
  6. Mar 8, 2024 at 12:34 AM
    TacoTuesday1
    FL
    a place that is good at alignments or DIY
    Tire size does not affect alignment
    probably not
  7. Mar 8, 2024 at 2:21 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Call around and ask. Might get better results than asking the internet and stock uca on those wheels and tire specs can yield a good alignment with no rubbing. I have the same set up just different brand with no cutting and rubbing.
  8. Mar 8, 2024 at 8:15 AM
    808stateofmind
    808stateofmind Well-Known Member
    Kona
    '22 Lunar Rock TRD OR 4x4 DCSB 6MT
    Eibach pro truck 2.0/2R lift kit 1.5" AAL OME/ARB UCA BFG KO2, 285/70-17 SCS Blaze 10, 17-8.5, -10 offset ECGS bushing needle bearing replacement Clutch accumulator disk delete Poor mans TRD intake, K&N 57 series intake tube, K&N high flow filter, TRD flow accelerator
    They might be able to get the alignment right if they know what they are doing, if not you gotta go to an off road shop or a place that does alignments on lifted toyotas regularly. Your stock uca will limit how much caster you can get which will be close to 3° but that's the max you'll get. You'll want close to 4° or more to get your wheels as far away from the cab mount as possible
  9. Mar 8, 2024 at 9:35 AM
    Redsquirrel
    Redsquirrel Well-Known Member
    where abouts in western wa? this way we can help finding you a place to go.
  10. Mar 8, 2024 at 10:26 AM
    majpooper
    majpooper Well-Known Member
    Dennis
    North Carolina
    2022 Black TRD OR
    OTT Tune Front 2" lift OME 888 coil Bilstein 5100 DuroBump extended front bump stops Archive Garage extended rear bump stops Rear 1.85" lift Icon RXT leaf pack Bilstein 5100 SPC UCA DX4 16x8 +10 wheels 285/75R16 KO2 viper cut CMC sway bar delete exhaust reroute exhaust cut just past the rear axle U-bolt flip LFD engine skid plate RCI transmission and x-fer case skid plates Spindle gussets
    I am getting ready to do a lift and I am on a budget - I wonder if you mind me asking a couple of questions what wheels are you using , specifically what is the offset? Are you running 5100s both front and back? Do you take your truck off road ? The thing is I really don't care about looks I want to take my truck on some of the more difficult trails so no rubbing is fine on pavement but would like to know how your set up does off road.
  11. Mar 8, 2024 at 11:33 AM
    NwNative
    tacoma
    im in tacoma washington
  12. Mar 8, 2024 at 11:37 AM
    NwNative
    tacoma
    for sure ill start calling around i figured someone on here would know if stock wheels and stock upper control arms would be possible to get a proper alignment with 34s. looks like ill propbably look into upper control arms to be on the sagfe side.
  13. Mar 8, 2024 at 11:39 AM
    NwNative
    tacoma
    ok thanks man, ill call around some local offroad shops today, im leaning towards picking up some upper control arms to be on the safe side.
  14. Mar 8, 2024 at 11:42 AM
    NwNative
    tacoma
    as of right now im using trd pro wheels, icon 2.5 kit, leaf pack and 285/70/17 tires no rubbing issues or cmc truck is more than capable. im due for tires so im going to 34s which is bringing up clearing and alignment issues.
  15. Mar 8, 2024 at 11:46 AM
    NwNative
    tacoma
    looking for a place to get an alignment, i need 34s to clear cmc will stock upper control arms allow for that.
  16. Mar 8, 2024 at 11:53 AM
    Redsquirrel
    How much of a budget are we talking about?
  17. Mar 8, 2024 at 11:58 AM
    Redsquirrel
    Actually the Les Schwab in auburn the one closest to the Muckleshoot should be able to help you. My neighbors daughters BF works there I talk to him a lot they sell SPC uppers and know how to align them. So should be able to help you out ask for Blake when I see him next I’ll ask him what he thinks.
  18. Mar 8, 2024 at 12:12 PM
    TacoTuesday1
    FL
    folks with lift and bigger tires typically upgrade UCA’s
  19. Mar 8, 2024 at 1:15 PM
    NwNative
    tacoma
    i went ahead and ordered upper control arms. we will see how everything works out next week
  20. Mar 8, 2024 at 4:47 PM
    TacoTuesday1
    FL
    there’s lots to pick from
    One company I forget which has some they say were developed to shift the wheel forward for better size clearance, but that one costs much more than the rest.
    Theres other parts that can do that like pivots or fabbed LCAs but idk if they all stack together or could be just one is needed and a better choice (like pivots that strengthen a known weak point)
