27F Battery: Optima VS NorthStar
Discussion in '2nd Gen. Tacomas (2005-2015)' started by js312, Jun 12, 2016.
  1. Sep 9, 2016 at 7:55 AM
    js312
    js312 [OP] Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Hankook DynaPro AT2 (Summer), Blizzak DM-V2 (Winter)
    Ordered a Northstar today, @ramonortiz55 got me a deal on it that dropped the price enough to justify ordering that over driving to get an X2.
    I figure at this point the truck has 105k and I plan on holding onto it for 5 more years. I'll never have to buy a battery for it again. I also do have potential for more draw than stock (heated seats, heated mirrors, small subwoofer, aftermarket headunit, LEDs in bed, brake controller), so it's not going to hurt to go better than OEM.
    Plus, it's endorsed by Oz. That's probably all I really needed to know in the first place.
  2. Sep 9, 2016 at 7:57 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    :cheers:
  3. Jan 1, 2017 at 6:44 AM
    js312
    Joe
    New England
    So, my NorthStar failed in a month. I'm hoping it was a fluke (new one has been okay).
    I didn't drive the truck for a day, which is unusual. I went to start it and it cranked over really slowly, as if it was -20 out, but it was in the 40s. I immediately thought there must be a parasitic draw, so I checked for that and found none. Drove the truck throughout the day and found every time I started it, it would crank like it was almost dead. Battery voltage would immediately drop to 12.2 after shutting the engine off. I found if you put a multimeter on it, it would keep dropping. After an hour it'd be in high 11 territory.
    There is a NorthStar dealer a couple hours from me and they warranteed it no questions asked. They said "it happens, but it is unusual". New one has been good.
  4. Jan 1, 2017 at 6:51 AM
    badger
    badger Well-Known Member
    07 SR5
    It's an internal short. I would bet that if you measured the voltage under load it would drop to 5 or 6 volts. Clearly a manufacturing defect. I'm loving my X2Power (rebadged Northstar). Mine has a 5 year full replacement warranty, so apparently they have confidence in their product.
  5. Jan 1, 2017 at 6:55 AM
    js312
    Joe
    New England
    Never tried measuring under load.
    I put an AGM charger on it and it never said it was fully charged. As soon as I pulled the charger, even after having it on there for hours, it would drop voltage down to the 11s. If I let it sit overnight it'd be in the high 10s.
    New one sits right around 13v when the truck is off and there's no load. I'm told 12.8v is 100% for an AGM battery, anything more is a float charge.
  6. Jan 1, 2017 at 7:19 AM
    badger
    07 SR5
    12.7 is full charge on a lead acid battery. I believe AGMs are 12.9 -13.0. Immediately after charging there is a residual charge that must be flashed off to see the true charged voltage. You can apply a quick load to the battery, and then see where it settles. Unfortunately car charging systems are not so good for actually maintaining a battery. The good shore charging systems have de-sulfination cycles that really extend the life of a battery. They also go above 14V which is helpful for AGMs.
  7. Jan 1, 2017 at 9:26 AM
    FlyByNight
    FlyByNight Well-Known Member
    Patrick
    WA
    2015 Black Tacoma TRD OR DCSB
    I know you've already purchased a battery, but fwiw I've always had really good luck with Costco batteries. Some of them even come with a 120 month warranty.
  8. Jan 1, 2017 at 11:24 AM
    mcdee
    mcdee Well-Known Member
    mike
    Northern Cal
    12 PreRunner OffRoad TRD
    TRD center cap, quick bed mat, Gatekeeper, WTs, TRD skid plate from bpfab, plastidip emblems, security slider bar, interior LEDs, AFE Pro Dry air filter
    I just tried to get 27f at costco the other day and was told they do not have this particular size. I asked if they could order me one and not possible (I think Interstate provides their batteries and they don't make that size). Employee was surprised as he gets requests often. I plan to get the duralast at AutoZone, you can get 20% coupons.
  9. Jan 1, 2017 at 4:33 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    They may not carry it at Costco, but Interstate definitely makes/offers a 27F battery. I planned to upgrade my OEM battery to their Mega-Tron Plus 27F, until the last Northstar Group Buy...
  10. Jan 1, 2017 at 4:47 PM
    mcdee
    mike
    Northern Cal
    Thank you, good to know. That is why we have TW!
    Norton[QUOTED] likes this.
  11. Jan 1, 2017 at 5:52 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    Just for fun of adding to the conversation, I was going to go with a NorthStar but my original battery died a while ahead of the most recent group buy which was a bummer. Anyways, I ended up with a Duracell Gold 27f from BatteriesPlus. Has some nice specs for a $130 lead acid battery. Doing great so far.
    Still need to alter the stock battery hold down as the Duracell is a bit larger than the original battery.
    https://www.batteriesplus.com/productdetails/sli27fm
  12. Jan 1, 2017 at 6:08 PM
    Perfuseme
    Perfuseme Well-Known Member
    Rick
    Always an Autozone around the corner
  13. Jan 1, 2017 at 6:54 PM
    Pigpen
    Northwest Montana
    Not true, at least not if you're in remote areas. That's why I chose the X2(Northstar)
    In hunting season, I tow my camper down 50+ miles on dead-end dirt roads in sub zero temps to chase elk for a week. I want peace of mind that the truck will start when I need it - and that the winch will work if I need it.
    shakerhood likes this.
  14. Jan 1, 2017 at 6:57 PM
    Perfuseme
    Rick
    Well, I guess that's true. I'm coming from the sports car crowd. This is my first truck...lol...honestly il do a dual battery set up at some point and do whatever the best stuff out is
    Pigpen[QUOTED] likes this.
  15. Jan 2, 2017 at 1:14 AM
    #35
    BlueMile
    BlueMile Frozen north specialist
    Patrick
    North/Central Alberta
    2009 TRD Sport
    ATV trail dents, many, many lights, 4-6 beer cans.
    Same here, picked up a 27F for ~100$, its done beautifully so far in 3 Edmonton winters, no problems cranking or maintaining charge at -30 to date. Can't beat the no questions asked warranty either.
  16. Jan 2, 2017 at 5:05 AM
    #36
    js312
    Joe
    New England
    I find NAPA to be the easiest to find in remote areas at least in the Northeast. We had them and Advance here. Only got an AutoZone recently.
