275x70R17 or 265/70/17
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JeremySD, Jun 21, 2023.
  1. Jun 21, 2023 at 5:09 PM
    JeremySD
    JeremySD [OP] New Member
    2023 Tacoma TRD
    Bought my first 2023 Tacoma TRD Sport w/ the Stock 265/65R17 Sounds like 275/70R17 are the largest tires w/o lift on youtube but have heard that can rub too. Go big or stay safe w/ the in between 265/70R17. New here hope that makes sense? Thanks
  2. Jun 21, 2023 at 6:19 PM
    Koolbreeze7
    Koolbreeze7 GRILL MAN
    Jon
    Jersey
    2017 TRD Sport 4x4 DCLB Black, Trail Limo. RIP- 2009, 2000, 91,89,87 trucks
    Rigid pod fogs, SpartanX stealth grill and hood LED's, 17" SEMA's on 275/70/17 Falken Wildpeak AT3W's, Fox 2.0 on all corners , TRD CAI, LEER 100XQ Blacked out, w/ Thule racks, and Cargo slider Flow master American Thunder "dual" exhaust, remote start, tint, TRD Pro grill and TRD shadow graphics, Alcan custom 8 leaf Spring Pack
    275/70R17 w fox2.0 coilovers, no rub at anytime.
  3. Jun 21, 2023 at 6:27 PM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    265-70-17 will fit just fine.
    any bigger and you might rub, depending on your wheels offset.
  4. Jun 21, 2023 at 6:28 PM
    Bishop84
    Bishop84 Well-Known Member
    275 has a lot less choices, but you can still get BFG's or Falkens no issues.
    I've installed lots of 275s no rubbing.
    Honestly I encourage 265 70 17 simply due to limited impact on driving. It's bigger, but not so big that you notice the power loss. It's truly the sweet spot for Tacoma.
    I like to merge and retain my powerband, bigger tires eat torque.
    Telkins88 and RustyGreen like this.
  5. Jun 23, 2023 at 8:24 AM
    pquintal
    pquintal Active Member
    Phil
    Bay Area , California
    22 Barcalona Red TRD Sport 4x4
    TRD Pro Grille w/ Raptor style lights BakFlip MX4 Tint Fronts 20% Rears 5% VLED Interior Lighting VLED LED Headlight Bulbs MESO Custom Total Tails MESO Custom Blacked out Sequential Turn Signal Morimoto XB Amber Fog Lights Black out Emblem Overlays MESO Custom Chrome Delete TRD Shift Knob TRD Black Exhaust Tip RRW RR5-H 17x8.5 -12 Mickey Thompson Baja Boss AT Matte Black Wrapped Roof Matte Black Wrapped Hood Scoop Desert Does It Seat Jacker
    Running the Mickey Thompson Baja Boss AT's in 265 70 17. On stock suspension. Not a huge difference in mileage. But, because i have a -12 offset i have a slight rub only turning in reverse.
  6. Jun 23, 2023 at 9:30 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    Clearing bigger tires is all in the alignment. I can clear 34's with no cutting or trimming and only adding UCA's. A lift wont clear any bigger tires.
    Junkhead likes this.
  7. Jun 23, 2023 at 9:34 AM
    4x4Taco2012
    4x4Taco2012 Well-Known Member
    Tim
    Huntingdon Valley, PA
    2022 DCSB Limited 4x4
    TRD lift, TRD SEMA wheels, TRD skid plate, TRD Pro fog lights, TRD Heritage Grill, OEM bed cover, LT275/70/17 Falken Wildpeak AT3Ws, OEM bed lights, OEM all weather floor mats, OEM door skid plates, OEM mud guards, OEM bed mat, Black lug nuts
    If you aren't lifting, stay safe w/ the in between 265/70R17 and there's only a minute chance you'll have rubbing using stock wheels (I've only seen one or two people on here that had minor rubbing with that size). As other mentioned, wheel offset can play a big role.
  8. Jun 23, 2023 at 9:43 AM
    TacoTime55
    TacoTime55 TT58
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    I'm looking for the offset currently on OP & my Sport...I know it's not "Zero Offset" but read somewhere it makes the tire poke out a little.
    I'm looking for some pokey since I have Bushwacker Fendys.
    @Koolbreeze7 has 275/70R17 w fox2.0 coilovers, no rub at anytime.
    @Bishop84 encourages 265 70 17 simply due to limited impact on driving.
    Well, I'm not getting new wheels/tires until at least 50K+ miles....currently at 22K miles.
    Good luck OP and post pics of your decision.
    EDIT: I found my post (#161) regarding the offset...but I didn't list the source.
    https://www.tacomaworld.com/threads/trd-sport-5-14-2021-celebrating-2-years.738836/page-9
  9. Jun 23, 2023 at 10:02 AM
    TacoTime55
    TacoTime55 TT58
    Ed
    Delaware
    This offset has me researching...
  10. Jun 23, 2023 at 11:34 AM
    Koolbreeze7
    Jon
    Jersey
    I am running the T4R Sema wheels 7" wide. Offset is 4mm. The fronts are dam close to even. The rear, my bed is off a bit and I should try to center it, so one side has a bit more "poke"
  11. Jun 23, 2023 at 12:06 PM
    Molina67
    Molina67 Well-Known Member
    Ken
    2022 Tacoma SR5
    I put 265/70 R17 on mine and they did rub in the front ended up putting 265/65R17 no rubbing.
  12. Jun 23, 2023 at 12:36 PM
    OnePuttBlunder
    OnePuttBlunder Well-Known Member
    AZ
    2018 TRD Offroad DCSB Premium +GFC
    My 265/70-17 on t4r trd pro wheels were close and that was a minimal offset wheel no mud flaps.
    My 275/70-17 now with -10 offset wheel I don't think would have cleared had to trim a tiny bit of the front bumper and with new ucas proper align they fit with no cmc after lift.
    AkRippa43 likes this.
  13. Jun 23, 2023 at 1:01 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Before my 2" lift, I upsized from 265/70/16 to 265/75/16 without rubbing, but it was awfully close to rubbing my upper control arms. My next tires will be 33" 255/80/17 pizza cutters.
    I'd rather add ground clearance, without the extra bulk & weight of a wider tire, and keep my mud flaps. That fits my needs perfectly.
  14. Jun 23, 2023 at 2:02 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    As long as you stick with stock Sport rims, you should be able to run any of them just fine. I went with 255/75R17 and I maintained a lot of clearance even with mud flaps. On aftermarket rims, you rub on pretty much any tire larger than stock because the rims are moved significantly further out. This is exactly why I kept the stock rims, as they offer the perfect tire placement, plus I think they look great anyways.
    The width of the tire typically affects rubbing more than the height. In other words, you're more likely to clear a 255/75 than a 275/70. Personally, I don't see any reason to choose 275/70. I'd keep the choices to 265/70 or 255/75.
  15. Jun 23, 2023 at 2:21 PM
    TacoTime55
    TacoTime55 TT58
    Ed
    Delaware
    @BLtheP
    Soooooo,
    Keeping the stock Sport Rims/Wheels but getting 265/70s is the way to go?!
    Edited...nevermind.
  16. Jun 23, 2023 at 2:24 PM
    BLtheP
    Plano, TX
    I went with 255/75, but 265/70 would have about the same clearance. Definitely plenty of clearance even with mud flaps. I was concerned about it all the way up until I saw them mounted. I had the Sema 17x7 +4 wheels for a while with 265/70 and they definitely rubbed the flaps on turns with bumps.
  17. Jun 23, 2023 at 2:57 PM
    TacoTime55
    TacoTime55 TT58
    Ed
    Delaware
    I've got Bushwacker Fendys and looking for some pokey! lol
    My lil tires are swimming in the wheel well...lol.
    I'm exaggerating of course. lol
    I wouldn't mind doing a 270/70 since I don't have mud guards anymore.
    Maybe dropping down to a 16 wheel with the same offset?
    So many options! lol
    This without doing a lift...but maybe new UCAs?
