275/70/18?
Discussion in 'Wheels & Tires' started by Foozer, Mar 11, 2014.
  1. Mar 11, 2014 at 3:05 PM
    Foozer
    Foozer [OP] Well-Known Member
    Utah
    2021 TRD Pro - MGM
    265/75/16 BFG KO2
    You guys think 275/70/18 will fit on my double cab with a 3" lift with no rub? Has anyone done this or seen anyone do it?
  2. Mar 11, 2014 at 3:16 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
  3. Mar 11, 2014 at 8:56 PM
    Foozer
    Utah
    2021 TRD Pro - MGM
    265/75/16 BFG KO2
  4. Mar 12, 2014 at 2:28 AM
    LuckyCharms
    LuckyCharms Knows a little about a lot
    Socal
    '13 PreRunner TRD dclb
    You would definitely rub without any modifications.
    A lot of guys including myself run 285/70r17s which are 32.7" but are also a little wider than your 275s. I have less than a half inch of clearance on the body mount. You would be awfully close. You could get away with it with some trimming and the body mount mod. I am just looking at the dimensions though.. I have no experience with 18s.
  5. Mar 12, 2014 at 2:34 AM
    cheeseit
    cheeseit Well-Known Member
    Vancouver B.C.
    2005 SR5/TRD OR Tacoma
    3 inch toytec lift
    x2 on this. I've done some trimming and I've gotten rid off 99% of the rubbing from just driving around on the street but off road it rubs.
  6. Mar 12, 2014 at 2:41 AM
    LuckyCharms
    Socal
    Needless to say, mine rub off road too. If they rub on a truck without a lift... they will rub on a lifted truck while off roading.
  7. Mar 12, 2014 at 9:55 AM
    Foozer
    Utah
    2021 TRD Pro - MGM
    265/75/16 BFG KO2
    Thanks guys, any suggestions on tires for 18 inch wheels with a 3" lift??
  8. Mar 12, 2014 at 10:07 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    275/65/18 = 32.07
  9. Mar 12, 2014 at 3:34 PM
    Foozer
    Utah
    2021 TRD Pro - MGM
    265/75/16 BFG KO2
    Thanks for the info. My fear is that 32s would look to small with a 3" lift. Im running 31.56" with no lift right now (265s).
  10. Mar 13, 2014 at 10:08 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    go with 285/65/18's. Almost 33x11.5 and will clear fine. Also alot also depends on type of tire you will be running. They all measure differently between manufacturers.
    Ksdobe likes this.
  11. Feb 20, 2021 at 8:17 AM
    captainvfr
    captainvfr Member
    2020 Limited Cement
    Has anyone on this thread gone this route? "go with 285/65/18's" with no lift. I am interested in taller tires without a lift and keeping my factory rims. I will remove the air dam if necessary. 2020 Limited with stock 265/60/18.
