265/85/16?
Discussion in 'Wheels & Tires' started by TRD19, Jul 15, 2021.
  1. Jul 15, 2021 at 11:05 AM
    TRD19
    TRD19 [OP] Active Member
    Will
    2019 Tacoma TRD Offroad
    Stock
    Hello!
    I currently have 265/70/16 on. Wondering if I could get away with a larger tire. Considering a 265/85/16. Same width, but more height. Will they fit?
    I have a Toytec Boss 2.0 installed with UCAs and leafs on a 2019 TRD Offroad. The rims are an offset of 1. I'm trying to avoid CMC of any kind. I don't mind some trimming of plastics.
    I have attached some pictures.
    Thanks!
  2. Jul 15, 2021 at 12:31 PM
    E.J.
    E.J. International Overlander
    Josh
    NWA
    2017 White Tacoma TRD Off Road
    I could be wrong but I don't think anyone makes a tire in 265/85 16. 255/85 16 is a popular size that's taller than what you have and fit 3rd gens fine.
    Thunder Fist and skeletron like this.
  3. Jul 15, 2021 at 12:33 PM
    skeletron
    skeletron Disgraced Member
    Clark
    Sakerlina
    2020 TRD Broh
    Yeah that's exactly what I was going to say. The 255/85 is close to 33x10
  4. Jul 15, 2021 at 12:53 PM
    TRD19
    Will
    Stock
    You're correct. I'm going for the 285 75 16 option of the ko2. I know I'll have to do some trimming, but it will give me the height I'm looking for and a little wider stance too.
    Man, I'm praying the rubbing won't be too bad.
  5. Jul 15, 2021 at 12:56 PM
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    lol you gonna rub.
    skeletron likes this.
  6. Jul 15, 2021 at 12:57 PM
    TRD19
    Will
    Stock
    How bad do you think? I'm hoping not to rub on the UCAs. We shall see.
  7. Jul 15, 2021 at 1:10 PM
    Thunder Fist
    David
    Birmingham, AL
    Like, so many.
    I think you're more likely to rub your cab mount, but clearing the UCAs should be a consideration as well. Spacers may help.
  8. Jul 15, 2021 at 2:47 PM
    TRD19
    Will
    Stock
    So, they are on. No rubbing forward or reverse on pavement! I had already chopped some plastic and that might have helped.
    Next, offroad time. We shall see. Going to take it out to Marble, CO. Marble is only about an hour away. Ouray is about 2 hrs. We are going to do a trail called Lead King Basin Loop.
    I really like the stance the tires gove the truck.
  9. Jul 15, 2021 at 2:49 PM
    skeletron
    Clark
    Sakerlina
    2020 TRD Broh
    Good luck brother let us know how you do
  10. Jul 15, 2021 at 2:52 PM
    TRD19
    Will
    Stock
    Will do!
  11. Sep 27, 2022 at 9:18 AM
    ZooliganLo
    ZooliganLo Well-Known Member
    Carlo
    2020 sr5 4x4
    any update with a 285? Would like to see some pictures and, what tires did you run?
  12. Dec 18, 2022 at 12:55 PM
    hoytshooter1
    hoytshooter1 Well-Known Member
    Cave Creek, AZ
    2020 DCSB
    ICON's Method's w/265-70-17 (Gone) '16SR5 Wheels with 255-85-16 Falken MT's AZ pinstriping
    Evidently it was a catastrophe and he did not survive the initial offroad excursion...... RIP TRD19......
