255/80/r17s pizza cutter thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ares32, Dec 20, 2017.
  1. Mar 28, 2019 at 5:53 PM
    #281
    solscooter
    solscooter Sh!t Outta Luck
    Brian
    Minnesota
    2016 TRD OR DCSB 4x4
    Yes. My wheels are also -10 offset. Deff rub on the cab mount
  2. Mar 28, 2019 at 5:59 PM
    #282
    nosamk
    nosamk Well-Known Member
    Keith
    Little River, SC
    2017 DC/SB/OR/MGM >>gone
    OK. so I assume that is caused by the diameter of the tires and not the width. I'm also doing a lift. not sure it will make a difference....
    Maybe I need to find a different size as I am not interested in cutting the cab mount
  3. Mar 28, 2019 at 6:07 PM
    #283
    backcountryj
    backcountryj Pending Approval
    Jonathan
    GA
    The tire is a contributing factor, but the wheel specs often play a larger role. With Ray 10s, I’d expect some contact somewhere.
    Gnarman and solscooter like this.
  4. Mar 28, 2019 at 6:17 PM
    #284
    nosamk
    Keith
    Little River, SC
    So no matter what size tires I put on the Ray10s are going to cause an issue? If thats the case I'm disappointed I bought them - I had assumed they were supposed to work for our trucks
  5. Mar 28, 2019 at 6:35 PM
    #285
    backcountryj
    Jonathan
    GA
    I didn’t say they wouldn’t work. Just said you’ll likely have some contact somewhere.
    You’re talking about putting a 33” tire mounted on an 8.5” wide wheel that has -10mm offset on a mid size pickup. Things may not work out just as Toyota designed it is all I’m saying.
    BC Hunter, Boghog1 and DavesTaco68 like this.
  6. Mar 28, 2019 at 6:47 PM
    #286
    Matt3400
    Matt3400 Well-Known Member
    2007 Lexus GX470
    I have the exact wheel tire setup on an ICON stage 4 lift, needed the CMC done.
    nosamk[QUOTED] likes this.
  7. Mar 28, 2019 at 7:31 PM
    #287
    nosamk
    Keith
    Little River, SC
    Thanks man
  8. Mar 29, 2019 at 6:41 AM
    #288
    TetonBuck
    TetonBuck Well-Known Member
    2016 Black TRD OR
    Stock
    I lifted my 3rd gen 2.5” and just put on the ray 10’s with stmaxx 255/80 17. Only very slight rub on mud flap at full turn on incline or over bump. No cmc. Did a lot of research here and found many others with little or no rub so went for it.
    Also got UCAs, I think this is a big factor in moving wheels to maximize the space?
  9. Mar 29, 2019 at 11:07 AM
    #289
    PuyallupJon
    PuyallupJon 2020 AG Pro
    Jon
    Puyallup, WA
    2020 Tacoma
    Can you post up a bunch of photos?
  10. Mar 29, 2019 at 11:47 AM
    #290
    kperatt09
    kperatt09 Well-Known Member
    Kaylor
    Denver Colorado
    2016 Tacoma OR
    34's with all the fun attached
  11. Mar 29, 2019 at 2:03 PM
    #291
    TetonBuck
    2016 Black TRD OR
    Stock
    A9F2A8E7-3D72-4905-AFF0-510C51933537.jpg 93D5815E-CF92-442C-9683-D164CFBAD54F.jpg
    Here’s the rub , I’m pretty sure removing mud flap will eliminate it but if not I’ll dremel out some more plastic. I’ll let you know. Love these wheels and skinny tires!
    Roddy13 likes this.
  12. Mar 29, 2019 at 2:09 PM
    #292
    nosamk
    Keith
    Little River, SC
    What UCAs and suspension did you get?
  13. Mar 29, 2019 at 2:20 PM
    #293
    TetonBuck
    2016 Black TRD OR
    Stock
    5100’s all around with OME 888 springs in front and BSW heavy duty leafs. UCAs are spc light racing, got all but the leafs from @HeadStrong Off-Road , Marie was excellent help
  14. Mar 30, 2019 at 5:49 PM
    #294
    ptat
    ptat Well-Known Member
    2019 Tacoma SR5 4WD DCLB
    @TetonBuck do you have UCAs? I think they can be used to push the wheel forward (caster) so you wouldn't rub.
  15. Mar 31, 2019 at 7:47 AM
    #295
    TetonBuck
    2016 Black TRD OR
    Stock
    Yes I bought Light Racing UCAs and the shop set caster to 3 which is slightly out of range but shouldn’t effect tire wear. Removed front mud flaps yesterday and no more rubbing!
    ptat[QUOTED] likes this.
  16. Mar 31, 2019 at 10:28 AM
    #296
    ptat
    I wonder if your wheels offset has anything to do with the rubbing? I'm trying to do the same setup as you with TRD Sema Pro wheels.
  17. Mar 31, 2019 at 1:14 PM
    #297
    solscooter
    Brian
    Minnesota
    Deff. That -10 makes it rub
    BC Hunter likes this.
  18. Mar 31, 2019 at 1:19 PM
    #298
    ptat
    So the TRD Pro Sema should be ok right? They're 17x7 +4 offset.
  19. Mar 31, 2019 at 1:45 PM
    #299
    solscooter
    Brian
    Minnesota
    Dunno. From what I've read should be ok
  20. Apr 13, 2019 at 7:43 PM
    #300
    hiwasseetaco
    hiwasseetaco Well-Known Member
    SE Te Te Tennessee (Cleveland)
    03' 4wd DC
    OME 881's, Dakaars, Leer Topper, and a wish list.
    What is your rim width?
