2500 RPM rev limiter?
Discussion in '1st Gen. Tacomas (1995-2004)' started by perzaklie, Apr 2, 2023.
  1. Apr 2, 2023 at 12:57 PM
    perzaklie
    perzaklie [OP] Member
    I am posting this question for my son. He has a 1995 Tacoma with the 5VZFE engine. He doesn't drive it regularly. He lives in CA, I live in AR. I just returned from a visit in September and we drove it around several times and it ran perfectly, just as it has for the last 20+ years he has owned it. Just recently, he needed to use it and when it got to 2500 RPM, it refused to rev any higher and sounds and acts just like it hit a rev limiter. He first thought it was the clutch shuddering but after closer examination, realized it was the engine. He and I are at a complete loss as to what it might be, what might have caused it. Can anyone shed some light on this situation?
    Many thanks for a suggestion or a solution!
  2. Apr 2, 2023 at 4:52 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    First thing I'd do is pull the negative off the battery for 10 seconds, put it back, and see if it still does it. That'll rule out a few things
  3. Apr 2, 2023 at 5:14 PM
    perzaklie
    Will do and will let you know.
  4. Apr 3, 2023 at 6:47 AM
    perzaklie
    He did as you suggested and now it will rev to 3000 before it hits the rev limiter. Any ideas/suggestions?
  5. Apr 3, 2023 at 6:58 AM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    If a check engine is on and the engine will only rev to 2500 -3k rpm the ECU is limiting engine rpm to protect it from further damage . This is more commonly called " Limp mode "
  6. Apr 3, 2023 at 7:02 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Usually this suggests some sort of ignition failure. I don’t remember what ignition system these had in 1995, but I would test the coil(s) and distributor.
  7. Apr 3, 2023 at 7:04 AM
    1997tacomav6
    Denver
    A bad camshaft sensor or crankshaft sensor or bad wires or connectors will cause this too going to the sensors
    0xDEADBEEF likes this.
  8. Apr 3, 2023 at 7:04 AM
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    Blockage in the cat or muffler.
    0xDEADBEEF and 1997tacomav6 like this.
  9. Apr 3, 2023 at 7:05 AM
    perzaklie
    Thank you. I neglected to state in my original post that no engine check light is on or has come on. It seems every thing is normal except for the strange behavior of the rev limiter. Starts and runs perfectly, it just won't rev. It was normal one day, next day the issue arose. The no check engine light has both he and I puzzled.
  10. Apr 3, 2023 at 7:06 AM
    1997tacomav6
    Denver
    X2 yup clogged cat will do this too
  11. Apr 3, 2023 at 7:06 AM
    perzaklie
    Thanks all!
    I will have him check the cam and crank sensors and also the exhaust system.
  12. Apr 3, 2023 at 7:13 AM
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    Check the plugs. check wiring for mice, etc.
  13. Apr 3, 2023 at 7:42 AM
    perzaklie
    Would not the cam/crank sensor wiring or the CAT create a check engine light? My thoughts are if the CAT were clogged, it would throw the O2 sensor readings off and create a check engine light. When the rear CAT went out on my Nissan the check engine light came on and same with the knock sensor and same with the O2 sensor. I'm just puzzled at the fact that no check engine light has come on on his truck. In any event, he is going to have the CAT checked first as it seems to he and I to be the most likely suspect. Thank you all for the suggestions! You are much appreciated!
  14. Apr 3, 2023 at 8:28 AM
    1997tacomav6
    Denver
    Typically it would but not always on the sensors.
    My crankshaft sensor didn’t, my camshaft did when I was switching to standard alone ecu
  15. Apr 3, 2023 at 8:30 AM
    1997tacomav6
    Denver
    Start with exhaust 1st because it should be easier
