24F vs 27F Battery or..?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by RDT415, Jan 4, 2023.
  1. Jan 4, 2023 at 9:55 AM
    RDT415
    RDT415 [OP] DUCTACO
    Sonoma County
    23 TRD Pro 6MT / past 04 DCSB 4WD
    I know there are numerous threads about this. I did search, but did not find anything definitive or recent.
    I am looking at replacing the battery on my truck to accommodate some extra electrical bits, ditch lights, light bar, scene lighting, but most importantly a Smittybuilt X20 10k winch. Per Smittybuilt the winch needs a battery with at least 650 CCAs. My stock battery puts out a 582 CCAs.
    I have had two X2 AGMs (Northstar for Batteries+Bulbs) in the past and they are solid. I always kept them topped off on a Noco Genius tender and they have lasted well past their warranty.
    I have read threads/posts about the radiator support cracking under use with heavier battery set ups group 35, dual bats etc., hell I have read some posts about folks who wheel hard with the stock battery and have cracking issues at or near the radiator support on 2nd and 3rd gens. In the cracked radiator support thread with larger tire sizes its possible heavy hits may cause the tire to hit the wheel well during up travel causing or exacerbating the issue.
    None the less - I am trying to decide on a battery while minimizing the potential for cracking the rad support. I don't wheel hard nor hit whoops at 60+, I use my truck to hunt and take it slow on the rougher terrain where a wheel might lift etc. But there are times when hauling ass down a gravel/washboard road do happen.
    Current choices
    - Stock 24f is around ~42lbs (winch may kill this thing)
    - 24F X2 AGM is 56.9lbs 840 CCA, 76AH, 160 min reserve (Drops right on in)
    - 27F X2 AGM is 66.95lbs 930 CCA, 92AH, 190 min reserve (Gotta purchase 2nd gen tow package tray)
    Hoping some folks might chime in on their experience going with a lighter adequate battery, or wishing they went larger/smaller etc.
    Thanks TW!
  2. Jan 4, 2023 at 10:07 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Similar situation. 24F AGM
    /thread lol
    RDT415[OP] likes this.
  3. Jan 4, 2023 at 10:14 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    24f AGM
    simple solution to a simple problem
  4. Jan 4, 2023 at 10:20 AM
    bmgreene
    bmgreene Well-Known Member
    Brian
    L.A. Westside
    2010 PreRunner V6 SR5/OR
    Alcan Leaf Packs, OME884 Coils, 5100 shocks, U.S. Offroad Winch Mount w/Winch, Trail Gear Rear H/C Bumper, Prinsu Cabrack, DIY custom in-bed storage/sleeping deck, Sway bar delete, hidden "snorkel" intake mod, In-dash CB, Bestop Supertop, Undercover Swingbox, hood lifters, assorted lights and front spotting camera
    I think the 27F is an inch or two longer on the long side than the 24F.
    I run my Tacoma (2010 V6) on a stock size AGM battery (probably the size 24), I can't remember what brand, but the CCA is in excess of 800A, and it's held up fine for a Smittybilt 9500 lb winch when I've needed it.
    I upgraded the battery in my 2008 T4R V8 trail rig (tacoma is a pre-runner with a locker but can't handle some trails that I want to do) to a 27F Optima Yellow top. I ended up just scrapping the tray on the 4Runner since the "universal" tray I bought would have needed some cutting to access the battery tie-down points on the frame, and I didn't feel like spending the extra cash to get the Optima specific bottom-clamping hold down mount. Is there really a need for a tray on a sealed battery, especially if the tray isn't structural? Fitting the 27 in that engine bay is workable, but pretty tight on that vehicle (a V6 Tacoma probably has a little more space)
    I also have a 9500 lb winch on the 4Runner, but haven't used it yet. I don't know how important the extra few minutes of reserve would end up being on a winch pull (those reserve times are only for something like a 15A draw) or heavy lighting use. If you're looking to use the lighting a lot without the engine running, it might be better to run two smaller batteries with a switching set-up which protects one from getting run down by the accessories so you'll always be able to start up the next morning.
  5. Jan 4, 2023 at 10:25 AM
    Sungod
    Sungod Well-Known Member
    St Augustine
    No. You get zero benefit from running an AGM unless your vehicle was designed for an AGM and the Tacoma's were not.
    MannyS and VB25 like this.
  6. Jan 4, 2023 at 10:25 AM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    -group 31 Wet 55lbs, 950CCA 175Reserve (+aftermarket 31 tray +Cruiser oil filler.)
  7. Jan 4, 2023 at 11:15 AM
    TireFire
    Olympic Peninsula
    Hahahahahahahahahahahaha
    edit: hahahaha
    still laughing.
  8. Jan 4, 2023 at 11:47 AM
    LTG4087
    LTG4087 Well-Known Member
    LT
    DFW
    2019 TRD Off Road
    I think the 24F X2 AGM is a solid choice as long as you can deal with the charging voltage.
    When you say "stock" 24F I hope you mean a premium offering not the battery Toyota slaps in there or any other bargen basement battery. Maybe something like the Wal-Mart EverStart Maxx which will give you 750 CCA and has a complete replacement 3 year warranty so if you do fry it they'll replace it. About $120.
    GoldenBrew and auskip07 like this.
  9. Jan 4, 2023 at 12:03 PM
    RDT415
    RDT415 [OP] DUCTACO
    Sonoma County
    The stock Clarios battery that came with the truck. I mentioned the weight of the OE for comparison sake of the AGMs mentioned and the radiator core support. You are certainly correct, a premium flooded 24F offering is far superior than the OE. I've had great luck with the X2s in the past hence my preference.
  10. Jan 4, 2023 at 12:09 PM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    True. But lots of people are tuned and it's an easy fix to change the charging voltage to accommodate AGM batteries..
    6MTPro, Rainoffire and RDT415[OP] like this.
  11. Jan 4, 2023 at 12:51 PM
    calzonical
    calzonical Without the 2nd, there is no 1st.
    2018 Taco TRD OR DCSB A/T
    @vicali - Which year(s) and Land or FJ for Cruiser oil filler are you referring too?
  12. Jan 4, 2023 at 12:56 PM
    vicali
    mike
    Kam,BC
    2017 TRD Sport 1D6
    RyanDCLB and calzonical[QUOTED] like this.
  13. Jan 4, 2023 at 1:47 PM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
  14. Jan 4, 2023 at 2:13 PM
    Benny22
    Benny22 Well-Known Member
    20Tacoma
    I run a 27f and it only needed minor cutting of the tray. still lots of room.
    RDT415[QUOTED][OP] likes this.
  15. Jan 4, 2023 at 2:26 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    34R here
  16. Jan 4, 2023 at 2:49 PM
    TireFire
    Olympic Peninsula
    It also doesn’t spill, takes less maintenance, and many have deep cycle ability (or at least more than flooded cell) which you need for winching, which the OP specifically asked about.
  17. Jan 4, 2023 at 3:02 PM
    RDT415
    RDT415 [OP] DUCTACO
    Sonoma County
    Interesting read, I've seen Kayak/trolling motor anglers running Dakota batteries. The operating/charge low temp threshold is -20F per Dakota, thats impressive for a Lithium battery.
  18. Jan 4, 2023 at 3:36 PM
    cwdog
    cwdog Well-Known Member
    Asheville, NC
    2017 Tacoma Limited
    Meguiars Ultimate Wax, Rain-X, Dog Bed, Undercover Tonneau Tri-Fold, Debadged.
    CCA's or Cold Cranking Amps mean nothing for a winch or anything that draws amperage from a battery for sustained period of time! It is the RC or Reserve Capacity rating that counts.
  19. Jan 4, 2023 at 4:54 PM
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    CCA/CA does mean something to a winch, too little and the motor will stall. RC is minutes to 10.5V at 25A, while CCA/CA is current output after 30 seconds.
  20. Jan 4, 2023 at 5:04 PM
    JoeCOVA
    Joe
    Colorado Springs
    I have ran winches off OEM lead batteries and AGM, doesn’t much matter. The 650 is a recommendation, not a requirement
    RDT415[OP] and willtill like this.
