21mm Lug Nut Wrench
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mr_805, Mar 27, 2021.
  1. Mar 27, 2021 at 6:27 PM
    Mr_805
    Mr_805 [OP] Active Member
    Eric
    ‘20 Tacoma SR5 Double Cab
    Where can I find a durable, 21mm thin wall lug wrench? Anyone have any suggestions?
  2. Mar 27, 2021 at 6:29 PM
    LarryDangerfield
    LarryDangerfield One Larry a day keeps the money away ™ Moderator
    Tyler
    Northern Wisconsin
    Black 2020 Nightshade Edition 4Runner
    Oh there will be some mods all right
  3. Mar 27, 2021 at 7:12 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    I have the same as above, works very well, but wouldn’t trust it long term with impact.
  4. Mar 27, 2021 at 7:19 PM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    If you are using on factory lugnuts, i used a standard deep socket from Lowes. Didn't need thin walled. Unless 3rd gen differs from 2nd gen and 4Runner on lug clearance.
  5. Mar 27, 2021 at 7:24 PM
    Shellshock
    Iowa
    Clearwater Bill likes this.
  6. Mar 27, 2021 at 7:26 PM
    Clearwater Bill
    Billy
    Largo Florida
    I use standard sockets, nothing spiffy.
    12 points are usually thin wall in a quality brand.
    6 points are the better fitting/gripping socket, best for tight/corroded fittings to reduce rounding risk.
    Every tool box should have both 12 and 6 point sets so you always have what you need.
    No reason for them to be 'new' either. Pawn shops, yard sales, C List, etc are all budget friendly sources.
    MadKatt likes this.
