2024+ Front Shock Top Hat Failure TALLY...
Discussion in '4th Gen. Tacomas (2024+)' started by FreshMexicanTaco, Aug 12, 2024.
Has your Top Hat failed?
  1. No
    126 vote(s)
    96.2%
  2. Yes, TRD OR
    4 vote(s)
    3.1%
  3. Yes, TRD Sport
    0 vote(s)
    0.0%
  4. Yes, SR/SR5/Pre-runner
    0 vote(s)
    0.0%
  5. Yes, Limited
    0 vote(s)
    0.0%
  6. Yes, PRO / TRailhunter
    1 vote(s)
    0.8%
  1. Aug 16, 2024 at 5:44 PM
    #61
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    .45 Calibear and PDKTaco[QUOTED] like this.
  2. Aug 16, 2024 at 6:43 PM
    #62
    Gmak621
    Gmak621 Łøādîñg…
    Nørth Çøast
    2024 TRD ØR
    https://www.cspracing.com/icon-58680/icon-58680/
    Icon 58680 (coilovers)
    I caved and ended up getting them. CSP Racing is legit. My order arrived the next day and shipping was free with no tax.
    Got rear shocks to match (56518) looks like they have already raised the price on those but got them for ($189.95/ea)
    The TRD Off Road suspension in these new trucks is way too soft. Even unloaded. When loaded, good luck
    PDKTaco and Superdave1.0[QUOTED] like this.
  3. Aug 17, 2024 at 5:58 AM
    #63
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    have all 2023 and 24 f150s, rams and silverados right here. all use shock mounted bump stops.
    batacoma likes this.
  4. Aug 17, 2024 at 6:38 AM
    #64
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    I have a 23 F-150 and couldn't recall where the front bumps were located. I thought they were mounted on the shock shaft under the top hat. Same as the Bronco shocks below
    I can't recall if the Tacoma shock has that bumpstop in the same location. I thought the bump stop on the 4G was inside the shock tube it self? There was reference to the internal bump zone with the 4G offroad shocks.
    I'm under the impression there is no exteral bump stop between the shaft and tophat of the 4G offroad shock.
    I'm not sure why Toyota thought Tacoma buyers wanted a front suspension design that's shared by the domestic 1/2 ton manufacturers.
  5. Aug 17, 2024 at 7:23 AM
    #65
    Superdave1.0
    SoCal
    I was thinking of the older trucks say 2010 and older. I don't really work on brand new domestic trucks.
    I wonder why they would all go from one design to the next. Cost savings? Can't be for durability.
  6. Aug 17, 2024 at 10:26 AM
    #66
    devinzz1
    devin
    2023 aclb trd or mt
    the bump stop is mounted externally on the shock shaft itself in same location as the picture referenced. the "internal bump zone" is not a bump stop. its an area in the stroke where compression valving is firmer than the rest. it starts when the piston passes the piggyback reservoir mounted near the bottom of shock body. up until that point the fluid displaced by the shock shaft would flow into the reservoir without going through the shim stack.
  7. Aug 17, 2024 at 10:46 AM
    #67
    devinzz1
    devin
    2023 aclb trd or mt
    most likely cost savings yea. no need to design and engineer the frame and lower control arm to accept a bump stop. doesnt have be designed as strong either. since lca bump stops are usually mounted so far inward they are under a mind blowing amount of force when used because of all the leverage.
    personally i am not against the shaft mounted bump stops. every dedicated offroad vehicle sold including side by sides have them. most passenger vehicles now including half ton pickups and oddball models like raptor and trx. even on these 4th gen tacomas the bump stop setup itself is not the issue and is completely unrelated to the top hat failure. seen multiple posts and videos still blaming the bumps like some gx460 dude on youtube that needs to go back to physics class lol.
    im not sure why toyota designed the top hat like they did. what exact is holding the top part in that holds the rubber isolator? is it just pressed in or something
    Superdave1.0[QUOTED] likes this.
  8. Aug 19, 2024 at 8:46 AM
    #68
    tmac5809
    tmac5809 Well-Known Member
    Ford needs to take notes from Toyota on where to cheap out on. I'd rather have a busted top hat than a broken tie rod, amirite?
    JK... Toyota needs to get this part fixed. Can't imagine what looks to be a cast piece has the strength to take hits even as well as a flat piece of stamped steel.
  9. Aug 19, 2024 at 9:09 AM
    #69
    Gmak621
    Gmak621 Łøādîñg…
    Nørth Çøast
    2024 TRD ØR
    If anyone wants my pair of Icon top plate reinforcements, ill ship them for $50 to your door.
    I used them for one tank of gas then ended up buying coilovers.
    Super easy install
    ace_10 and PDKTaco like this.
  10. Aug 19, 2024 at 9:40 AM
    #70
    batacoma
    batacoma Truck Wars
    I still don't know why Toyota is using a shock mounted bump stomp on the Tacoma when all of the other GAF trucks are using frame mounted stops.
    Is Toyota beta testing these shocks and the shaft mounted bump stop? Maybe to see if Toyota wants to use that design on the Hilux?
    Superdave1.0 likes this.
  11. Aug 19, 2024 at 9:43 AM
    #71
    SonoranSurvivalist
    SonoranSurvivalist Active Member
    2024 Tacoma TRD Off-Road
  12. Aug 19, 2024 at 11:45 AM
    #72
    batacoma
    batacoma Truck Wars
    I know 2nd time I quoted this post.:D
    https://www.motortrend.com/reviews/...-wrangler-4xe-rubicon-comparison-test-review/
  13. Aug 19, 2024 at 11:58 AM
    #73
    tmac5809
    Some things just shouldn't be subject to cost cutting. Look at how beefy these stops were on older Toyota/Lexus models:
  14. Aug 19, 2024 at 12:30 PM
    #74
    bhester
    bhester Active Member
    Bobby
    Hopkinsville, KY
    2024 Tacoma TRD Sport Premium
    Give me more information on these coilovers .....
  15. Aug 19, 2024 at 1:38 PM
    #75
    snickers
    snickers My new, overpriced heaping pile of shit
    2024 Tacoma Tailhunter 5ft bed Bronze Oxide
    Still not convinced frame bump stops are not cheaper. Dirt simple. From scratch new frame, LCAs anyway. Versus bump stop shocks/top hats that have to undergo design, testing, and more costly supply side management. Naw, Toyota was chasing that articulation their enthusiasts want.
  16. Aug 19, 2024 at 4:57 PM
    #76
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    ^But articulation is a good thing :notsure:
    FYI the Land Cruiser has frame-mounted bumpstops, because the Land Cruiser shocks aren't as fancy.
  17. Aug 19, 2024 at 8:18 PM
    #77
    Gmak621
    Gmak621 Łøādîñg…
    Nørth Çøast
    2024 TRD ØR
    What would you like to know?
    I’ve only driven it around the block a couple times. Felt very good. Not too stiff and very planted. I’m wait to get alignment Wednesday morning.
    Pain in the culo to install them.
    Stock suspension was way too soft and bottomed out a lot.
  18. Aug 22, 2024 at 10:26 PM
    #78
    rat107
    rat107 Well-Known Member
    Kauai, HI
    2024 TRD Off Road 4x4, Automatic DC/LB Bronze Oxide
    aFe Momentum GT Cold Air Intake System w/ Pro DRY S Filter
    Icon top plate reinforcement installed. Top plate bolt torque is 33 ft.-lbs. but you can't fit a torque wrench in there.
  19. Aug 23, 2024 at 4:08 AM
    #79
    TOMRR
    TOMRR Well-Known Member
    Tom
    Mass
    2016 TRD OFFROAD, DCSB, AUTO, BLAZING BLUE, PREMIUM JBL TECT.
    Stock TRD OFF ROAD DCSB AUTO JBL TECT. Bed Mat Heated and turn signal mirrors Wet Okole Front Seat Covers Prodigy Brake Controler Front Skid Plate Power Wagon Badge Tint Driver and Pessenger door windows Inchannel window vents
    I just found their web site. Did you install yourself ?
  20. Aug 23, 2024 at 8:06 AM
    #80
    rat107
    Kauai, HI
    heartache and TOMRR[QUOTED] like this.
