2016 Grille Diagram
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DeTako, Oct 13, 2015.
  1. Nov 11, 2015 at 7:59 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Ma-Taco likes this.
  2. Nov 11, 2015 at 8:34 AM
    texanhoyt
    texanhoyt Well-Known Member
    Seth
    2016 Silver Tacoma TRD off road
    tagged for later
  3. Nov 11, 2015 at 10:23 AM
    qnyla
    qnyla Well-Known Member
    NM
    2006 & 2016 DCSB TRD Off Road 6-Speed
    I just did mine last night. Replaced TRD grill insert with SR grill insert.
    Anyone who wants a Super White bezel with no grill insert, drop me a PM.
  4. Dec 3, 2015 at 8:43 AM
    2016 Tacoma 387
    2016 Tacoma 387 Active Member
    Terry
    Philadelphia, PA
    2016 Tacoma TRD Sport 4x4 DCLB / 2001 Reg Cab, 5 lug, 4 banger.
    So once the two screws are out, and the two plastic push pins, the grill will come out?
  5. Dec 3, 2015 at 9:27 AM
    axe
    axe Well-Known Member
    I did the SR grille as well. It's not even the chrome that bothered me that much, it was all that lattice work in it. ...if it was a chrome SR style I mightve left it alone.
  6. Jan 20, 2016 at 4:21 PM
    josh2015
    josh2015 Well-Known Member
    Josh
    2021 Tacoma MGM TRD OR 6MT
    Did you have any trouble separating the body color surrounds from the TRD and SR grill inserts? I asked a dealer and they weren't sure about how they come apart. I see in the diagrams that they don't show the grill coming apart from the surround, only the Toyota emblem, trim, and the surround with the insert attached. Thanks in advance!
  7. Jan 20, 2016 at 6:03 PM
    qnyla
    NM
    No trouble separating the body color bezel from the grille. Take it slow. A bit tedious, and took an hour to figure out and complete.
    josh2015 likes this.
  8. Jan 20, 2016 at 9:00 PM
    GrisMunkyNinja
    GrisMunkyNinja Well-Known Member
    '16 3.5 AC 4x4 SR5 MGM
  9. Jan 20, 2016 at 9:07 PM
    SLACKBOY
    SLACKBOY Toyota For Life!
    Erich
    Washington State
    2016 MGM Toyota Tacoma OR 4x4
    Blacked Out Emblems Wet Okole Seat Covers Installed Tinted Front Windows Weathertech Digital Floor Liners for the Front Plasti Dipped OF Grill - Removed BAMF Grill - MGM Installed Icon Stage 2 Kit. TRD Pro Wheels - 17's Ko2s installed (275 70 17) TRD PRO Rigid Led Fogs N Fab 3" Step Bars TRD Pro Auto Shift Knob TRD Pro Tail Lights
    SR grill looks good.
  10. Jan 31, 2016 at 8:14 AM
    peto48
    peto48 Well-Known Member
    Central NY
    2020 Tacoma DCSB TRD Off Road Cement 4x4
    Salex Center console organizer, glove box organizer, Husky Xact contour front and rear digital floor liners, OEM black running boards, TRD PRO Sema 4runner wheels black, Blackout badge kit, Bakflip MX4 hard folding tonneau.
    Sub'd
  11. Feb 5, 2016 at 7:46 PM
    swimmer
    swimmer Well-Known Member
    Tucson
    2016 TRDORAC4WD
    So can the chrome bezel be removed without removing main grill surround?
  12. Oct 13, 2016 at 7:07 PM
    mtbrooster
    mtbrooster New Member
    Darren
    2016 White Tacoma Double Cab TRD Off-Road
    New to this forum and just got an off road '16. How do I remove the front grill I want to do an aftermarket grill insert. I didn't see any step-by-step/diagrams on this thread.
  13. Oct 13, 2016 at 9:35 PM
    Ch78
    Ch78 GBO!
    Tomball, TX
    25’ Landcruiser 1958
    Tuned By D3 Performance
    There's 2 bolts and 2 tabs on the top, open your hood and they are easily found. The bolts are on each side right in front of your radiator, the black plastic tabs are at the top edge of the grill by the headlights. Use a small screw driver to pop them up the pull them out. Once the 2 bolts and tabs are out, grab the grill and pull. It takes a little force but not much. It's really simple to do.
  14. Oct 28, 2016 at 3:30 AM
    lincoln26
    lincoln26 New Member
    2017 gray tacoma trd sport
    Does anybody know if the 2016 black grille surround will fit a 2017? I got a black billet grille but need to replace chrome surround with black. I can only find 2016 surrounds.
  15. Oct 28, 2016 at 8:26 AM
    #35
    Ch78
    Ch78 GBO!
    Tomball, TX
    Yes, it's the exact same truck.
  16. Oct 28, 2016 at 8:35 AM
    #36
    lincoln26
    Thanks CH78. I thought it was. I just wanted reassurance.
    Ch78 likes this.
  17. Nov 13, 2016 at 9:42 PM
    #37
    Corneeeeelius
    Corneeeeelius AMERICA!
    Cory
    MIssion Viejo, CA
    2017 TRD Sport 4x4 DCLB W/Tech
    What a fun truck!
    This video worked well for me. It shows a grill replacement, but he is very clear about how to remove the original grill. I actually just removed mine, plasti-dipped it, and reinstalled.
    Total time:
    5 minutes to remove
    5 minutes for first coat of plastidip
    30 minute dry time
    5 minute second coat (killed the can)
    4 hours to dry (per manufacturers recommendation)
    5 minutes to reinstall
    Video link: https://youtu.be/qBElHs4m2mE
    HHIDave likes this.
  18. Dec 30, 2016 at 7:06 PM
    #38
    Gabtap
    Gabtap Well-Known Member
    2017 Black Offroad
    Did you tape off the black or just peel, that gives directions to pull out the whole chrome insert but that seems like a lot of work
  19. Jan 3, 2017 at 9:53 AM
    #39
    Corneeeeelius
    Cory
    MIssion Viejo, CA
    What a fun truck!
    I popped the chrome trim piece off. It's seriously not that much work. Just a few screws and clips that are easily popped off with a flathead screwdriver. Putting it back together is even easier as the clips just slide into place.
  20. Jan 3, 2017 at 11:39 AM
    #40
    Gabtap
    2017 Black Offroad
    for some reason the clips would stay disengaged, but I got it done Taped and used a razor to fit it inside the sides. looks good
