2016 Air Dam on a 2014
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SilverJack, Nov 23, 2015.
  1. Nov 28, 2015 at 5:52 AM
    mcgov303
    mcgov303 I'd rather be in the mountains
    Denver
    2015 BRM TRD Off Road 4x4
    Toytec 3" w/ AAL, Leer 100R, 16" SCS F5s, 265/75 KO2s, pro grille, cmc
    Ya just diy like this guy, but you should take your time, this looks like shit
  2. Nov 28, 2015 at 11:57 AM
    SilverBullet19
    SilverBullet19 Well-Known Member
    Scott
    Sacramento County
    2015 DCLB Prerunner TRD Sport
    You're saying exactly what I'm saying lol...paying for it would negate any savings.
    The air dam itself does not account for a lot in terms of MPG, its a huge combo that gets the 2016 better mileage.
    I wasn't taking about horsepower with the intake. They also always say 1-2 more mpg or so. So doing the math, paying for it would negate any savings unless you drive it for years.
    Yota64[QUOTED] likes this.
  3. Dec 1, 2015 at 10:06 AM
    tgear.shead
    tgear.shead Well-Known Member
    Just keep in mind when comparing 2016 to anything before, that the only valid comparison is between 4-cyl with manual transmission, since all other configurations have incomparable engine or transmission.
  4. Dec 1, 2015 at 5:04 PM
    SilverJack
    SilverJack [OP] no one
    Did they finally put a 5 speed auto in the 4cyl?
  5. Dec 1, 2015 at 5:13 PM
    Pigpen
    Northwest Montana
    With a heat gun, dremmel and a drill, you can make it work - I'm sure you can. Someone always has to go first on these mods. It's your turn this time. We're all cheering you on! :bananadance::bananadance::cheers::dancingbacon::dancingbacon::broccoli::broccoli::taco::taco:
  6. Dec 1, 2015 at 5:19 PM
    SilverJack
    Damn, I'm out of ductape. Not sure what I did with all that tape. Hmmm
