2013 Toyota Tacoma 4x4 V6 6,400 lbs towing capacity?
Discussion in 'Towing' started by sunflower2013, Jan 21, 2013.
  1. Jun 30, 2013 at 6:49 PM
    TXPROMAN
    TXPROMAN Well-Known Member
    Martin
    NY
    2012 TX PRO TACOMA
    Are you in NY ?
  2. Jul 16, 2013 at 6:11 PM
    jeffwesley
    jeffwesley New Member
    Jeff
    Louisiana
    2012 Tacoma TSS
    After trying to make my 2012 V6 non-tow package Taco work with our 26 ft. travel trailer, I gave in and traded for a 2013 fully-equipped 4.6L Tundra. This is why: it became clear after several trips that the Taco was somewhat unstable with the swaying. I didn't have a tow package so my intent was to install a transmission cooler and perhaps an oil cooler. After weighing it out, I just decided that it made more sense to buy something made for towing. I also decided to buy a 4.6 L vs the 5.7L because I needed the mileage. That was probably a mistake, as the 4.6L seems to struggle more than the Taco did when pulling the trailer. The gas mileage is less too. I was getting about 10 MPG with the Taco, vs the Tundra, which is only getting around 8 MPG. The advantage is that the Tundra does feel more stable on the road.
    If I had to do it over, I would still get the Tundra, only I would elect the 5.7L tow package. I really liked the Taco, but from a safety perspective, the Tundra just feels better.
    Kimber45man likes this.
  3. Jul 16, 2013 at 7:19 PM
    skeighter
    skeighter Well-Known Member
    If you're doing long haul towing buy a Tundra. We just finished up a 1800 mile jaunt. Less than 10 mpg and the Taco struggled pulling our 4000 lb load up passes. Also drove me crazy using the cruise control. There is no "control". Either no gas or full throttle. We plan on using our TT to camp up and down the coast here in SoCal so no worries.
  4. Jul 16, 2013 at 7:43 PM
    smd3
    smd3 Well-Known Member
    Which mountain passes? I'm about to cross the divide with my Taco and a 22ft 3800lb trailer. I'm going over Monarch pass on Hwy 50 in Colorado.
    I wasn't worried until I read another thread about someone hitting over 200 degree temps with an upgraded trans cooler.
    I'm going to look around at adding a bigger cooler with a fan this weekend (I leave next Wednesday)
    I've also ordered a 6" fan to strap to the existing cooler, if swapping the cooler isn't feasible.
    Did you monitor transmission temp?
    I'm not trading for a Tundra, I love my Tacoma, and I won't be making this trip a bunch. I'm just renting the trailer for the week, I'm also building plenty of time in my schedule to go up the pass slow.
  5. Jul 18, 2013 at 4:56 AM
    Jwunsch
    Jwunsch New Member
    HI everyone. I know this question has been around for long time and I like to hear your opinion.
    I have a 2012 Tacoma Sport TRD V6 4.0 double cab. I love my taco. It the best purchase I ever made in my life. I used to own a Nissan Frontiers in the past and this truck beat big time. The comforts, the way it drives and the best of all the look. My taco has a factory installed tow packages and it stated can tow up to 6500lbs.
    I want to upgrade from Jayco pop up camper to a bigger travel trailer. The dry weight I am looking at is 3800 to 3900 dry. Have anyone had any problem or have a travel trailer towing this size? The trailer is 23 feet long but the box is around 21.
  6. Jul 18, 2013 at 5:12 AM
    smd3
    I'll be pulling one that size/weight over the divide in less than a week.
  7. Jul 18, 2013 at 7:11 AM
    stewartx
    stewartx Well-Known Member
    Huntsville AL
    2012 Silver DC SB TRD Off-Road
    Winch, front hitch, step bars, bed extender, bed step, gull-wing toolbox, tailgate lock, security system, cb radio, etc.
    I had the exact same dilemma (will the Tacoma be enough or should I get something larger) while shopping for a truck. As others have said, you'll be okay towing <5000-lbs with the Tacoma. You won't be passing anybody on the hills, but you'll get to your destination just fine.
    I personally wouldn't push it to the very limits of the truck's towing capacity (6500-lbs for the 4x4 double-cab short bed), but plenty of others have done so and insist it's no problem. I've set a personal limit of right around 5000-lbs (often slightly less) and am quite satisfied with the results.
    In the end, I'm glad I didn't buy a larger truck. Since a larger truck, with larger engine, would typically drink more gas just sitting still, any fuel I might have saved while towing would have been lost over the long run just driving around town. And, since I do far more of the latter, I certainly wouldn't have came out ahead.
    Of course, just like with any vehicle towing a fairly heavy load, make sure the Tacoma is set up properly - towing package, brake controller, weight distributing hitch, and, if needed, sway bar.
    The tail end of a pickup is light, so trailer brakes with a brake controller (adjusted properly) helps to prevent jackknifing on wet or icy roads, or just when braking hard. A weight distributing hitch will smooth out the ride and reduce the tendency for the truck to droop or bounce in the rear.
    You might be able to get by with Toyota's build-in Trailer Sway Control (included with the V6 Tow Package). It works, but it's difficult to determine how well since, when it's working, you should feel very little or nothing. However, if your trailer is especially unruly (blown around easily, etc), a sway bar will usually tame it.
    The V6 Tow Package includes a class IV hitch receiver, transmission cooler, supplemental engine oil cooler, 130-amp alternator, heavy-duty battery, connector under dash for the brake controller, pre-wired connector at the hitch for trailer electronics, and Toyota's build-in Trailer Sway Control.
    In my opinion, you're pushing it at 6500-lbs, with or without the Tow Package, but especially without. However, if you're not traveling great distances or doing this often, it might be just fine. I'd certainly get a proper tow package installed.
  8. Jul 18, 2013 at 5:55 PM
    Jwunsch
    Jwunsch New Member
    I do have all those package with the tow package. I am just wondering if anyone has a problem with the truck it self after towing travel trailer. I hate to see my taco having to go into shop for any issues that may caused by towing. Do you tow in drive 4 or leave it on D? Just wondering. Sorry if it sounds stupid.
  9. Jul 19, 2013 at 9:45 AM
    jeffwesley
    Jeff
    Louisiana
    2012 Tacoma TSS
    John, I relented and traded my non-tow package 4.0L for a 4.6 L Tundra. Like you I was concerned about pushing the limits. This is the difference between the two trucks pulling my 25 ft. TT weighing in around 5500 lbs. First, the Taco actually seems to pull better. The transmission didn't "hunt" nearly as much as the Tundra's. Secondly, the Taco got about 10.5 MPG's pulling on flat land vs. 8 for the Double cab Tundra. Next, however, the Tundra is a more substantial truck and I didn't notice nearly the sway. I felt safer. And, finally, the transmission ran cooler.
    If I had it all to do over again, I would probably still trade up to the Tundra, though I would have opted for the 5.7L, just because it is a bigger truck that can handle a larger trailer. For smaller trailers I am convinced the Taco with the trailer package is just fine.
  10. Aug 20, 2013 at 6:25 PM
    elcomicguy
    elcomicguy New Member
    california
    2nd gen
    I'm waiting for my "Wolf Pup" RV that weighs in at 2425lbs. Tow vehicle is 2007 access cab 2.7 auto. I was thinking of giving it a trial run before having airbags installed. We plan on traveling light as possible, putting around the US and buying as we need. Definitely having trans cooler done. I was wondering what kind of tires would be best for the truck.
  11. Sep 15, 2013 at 7:14 AM
    skeighter
    Sorry...Just saw this message. Lot's of passes...Montgomery, Donner, etc. It pulled it, just labored a lot. Actually could see the needle on the gas gauge fall when going up Montgomery Pass in southwestern Nevada. No mods to the truck. Didn't impact temps or stress it, just burned gas and got on my nerves. Tundra??? I don't like the looks of them and they burn way more gas around town than my Tacoma. Only wish for one on infrequent stretches uphill.
  12. Sep 15, 2013 at 7:22 AM
    smd3
    Just because the temp gauge didn't move doesn't mean temps didn't go up
    I saw as high as about 215f of coolant temp, and 230f transmission pan temps on my scanguage climbing Monarch pass in Colorado. Mid 50's ambient temps, and a little under 13,000ft elevation.
  13. Sep 15, 2013 at 7:31 AM
    VTTACOMA
    VTTACOMA Well-Known Member
    Benj
    Vermont
    TRD Sport, Black
    Supercharge it. No more lag up hill!
  14. Sep 15, 2013 at 8:06 AM
    smd3
    I'd like to, perhaps if my wife gets his job she's applying for.
    I must have a much lower tolerance for the lack of power. The number of people who are happy towing 5000lb through the mountains really surprises me.
  15. Sep 15, 2013 at 9:16 AM
    #35
    ATHiker
    ATHiker Well-Known Member
    Tom
    Tennessee
    15 Tundra DC 4X4 SR5 OR 5.7L
    I think this is the route that I'm going. I just don't want to drive a huge truck.
  16. Sep 18, 2013 at 5:04 PM
    #36
    tacohead75
    tacohead75 Member
    You can never have enough truck. If your towing a lot, buy a bigger truck. I have overloaded my truck many times and its a scary feeling when trying to brake.
  17. Sep 18, 2013 at 6:40 PM
    #37
    campthewestcoast
    campthewestcoast Oceanfisherman
    Napa, CA
    Power extend/retract towing mirrors,brake controller,30amp charging system for TT,snug top camper
    I just installed cooper discovery AT3, 265/70/16, very nice tire, use a class c rated sidewall. max wieght for the tire 2469 lbs. I'm towing 3800lbs. with a V-6. E rated tires will be to stiff for your truck. I'm using an all-terrian tire because of gravel roads I travel time to time.
  18. Jan 24, 2014 at 6:07 PM
    #38
    Lesterawacs
    Lesterawacs New Member
    TRD 4x4 SR5 Full up towing package
    I have a 2012 Taco 4.6L TRD 4x4 SR5 with full up towing package. I agree gas mileage is bad while towing but worried I am over stressing it. Travel trailer is 4400# empty and add maybe 500# load plus 500# in the truck for cargo. We only add about 5-ish gallons of water in potable tank to facilitate rest stops on the way. We have a good brake controller and an Equil-I-Zer sway controller/weight distribution hitch. It seems to tow very nicely and on trip from Oklahoma City To Grand Canyon it handled grades in and out of OK/TX panhandles and in and out of Albuquerque well. Thought s and opinions?
  19. Feb 4, 2014 at 3:42 AM
    #39
    TheMuffinMan
    TheMuffinMan Banana Nut
    Coeur d'Alene, ID
    2023 Tundra Limited Crewmax 6.5' 4x4
    Get a supercharger if you're towing a lot, and maybe upgrade the rotors and pads.
    I personally take any tow rating, divide it by 2 and then that's how much I think a vehicle can comfortable pull. If the trailer is wider then the truck get some form of sway control. And of course a trailer brake controller.
  20. Mar 27, 2014 at 1:09 AM
    #40
    justinmn56
    justinmn56 New Member
    justin
    houston
    2012 tacoma tss 4X4
    i have a 2012 4X4 tacoma tss i pulled a 15 passenger van (overall weight of trailer and van was about 8500 lbs) from northwest arkansas to houston with no problem i wasn't getting passed and i don't have trailer brakes gas mileage went down significantly but other than that it was fine i wouldn't suggest doing that on a daily basis but it will do it
