2010 replacing calipers questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TreeFortRichard, Sep 4, 2018.
  1. Sep 15, 2018 at 12:00 PM
    TreeFortRichard
    TreeFortRichard [OP] Barcelona Red is the best red...
    Brian
    42.3115167,-71.6638516
    '23 SR5 DCSB 4x4 Barcelona Red
    Sharing some advice for those that buy remand calipers from AutoZone...The one I bought had a different bleeder banjo bolt. It was a 7mm very thin bleeder. I didn't have a 7mm flared wrench so I took that one off with a ratchet and took the 10mm banjo bleeder off the tacoma caliper. This will make bleeding the brakes so much easier. It's the same thread specs.
    PzTank likes this.
  2. Sep 15, 2018 at 6:07 PM
    10taco
    10taco Well-Known Member
    Massachusetts
    '23 4X4 DCSB V6 AT SR5/SX MGM
    Just finished a front brake job on my 2010 Tacoma 4X4. Obtained OEM rotors, pads, pins & springs from an eBay seller, bought new calipers at Advance Auto for $86 ea. My calipers were about as rusted as in the OP's pics; both inside lower pistons were seized. I had the most trouble with one of the 12mm brake line support screws, so rusted I had to bang on a 7/16" box to get it off. Flushed the brake lines before disassembly with 1.5 quarts of Prestone DOT 3 fluid; made a nice 'catch-can' out of 1/4" hose & a Gatorade bottle. I used lots of Permatex anti-seize during reassembly (after wire-brushing as much rust off as possible).
    I had initially planned just rotor & pad change without cracking the brake lines, but now I'm glad I replaced the calipers; they weren't very expensive and should last for years. :thumbsup:
    Edit: My new calipers also had a 7mm bleeder screw, I had the right wrench so no issues.
    PzTank and TreeFortRichard[OP] like this.
  3. Sep 15, 2018 at 6:23 PM
    TreeFortRichard
    Brian
    Yeah, I laugh at all the "Quick swap brake jobs" on youtube that are daily drivers that have never seen road salt.."Tap out the pins"...HA! I also found that the rubber bleeder stopper fits pretty snuggly on the stainless line...Not super tight, but enough to stop continuous flow...So I said hey....I took the bleeder cap off, too the stainless brake line out of the caliper and capped it with the rubber cap. That meant I didn't have to string up the crappy caliper on the 2nd wheel and made things so much smoother. The rotor was another world rusted to the hub...
    I snapped a 10mm bolt using the drive hole and was working using a sledge and pb blaster. I found another 10mm bolt (they are actually the same exact bolts that hold the skid plate on) and very carefully drove it into the hole...and eventually the rotor popped off..When I backed the bolt out it was practically on fire.
    In the end what a beauty...too bad it's going to be rusted to hell in about 2 weeks...
  4. Sep 15, 2018 at 7:56 PM
    TreeFortRichard
    Brian
    BTW @10taco did you ever get a deal quote for this job? HOLY CRAP...It was like $700 a wheel for new calipers/rotors/brakes...and I also did my wheel bearings and assemblys...It was over $4K for all that from the dealer...I did it all for around $550-600 with the new tools I also bought..and the priceless experience of realizing that the LCA's and Ball joints that are also shittastic will need to be done as soon as I'm told "I'm sorry sir but we weren't able to align it"
    Tacos4ever15 and PzTank like this.
  5. Sep 16, 2018 at 5:19 PM
    10taco
    Massachusetts
    I did not get a quote b/c I wanted to do the job myself. Technically, the job was not difficult at all. Except for the $#@(*&% rust. WOW, these Tacos rust quick in New England! I got the OEM parts from Westboro Toyota, through their eBay portal. A nice kit that included pads, rotors, pins & springs, all OEM. With the calipers (they are nice, Wearever brand from Advance Auto) and some fluid it was under $475 for everything.
    I didn't check the rear brakes yet, I'll get to it before winter tho. Could just need a cleaning, but shoes & drums are a possibility.
    @TreeFortRichard, don't forget to get the camera out again when you get to those ball joints; we'll be waiting for that write-up! :thumbsup:
    PzTank likes this.
  6. Sep 16, 2018 at 5:38 PM
    TreeFortRichard
    Brian
    NOOOOOOO!!!
  7. Feb 4, 2019 at 5:15 PM
    ryan89p
    ryan89p Member
    CO
    '10 2.7 5sp 4x4
    another NE taco 'quick' brake job... 0/4 trying to budge the pins. put it back together and got reman calipers from autozone. any other tips on breaking the rotors free? I don't imagine they are going to come off easy. Photo Feb 02, 1 50 21 PM.jpg
    PzTank likes this.
  8. Feb 4, 2019 at 10:25 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Oh my lord. I am so thankful to not live in a frozen wasteland.
    That is horrid.
  9. Feb 4, 2019 at 10:37 PM
    4x4Taco09
    4x4Taco09 Well-Known Member
    Dane
    Louisiana
    09 TRD Sport 4x4 BSP DC LB
    Kings, Deavers, Brute Force, Prinsu, Lights, all the stuff
    Geez I feel for y’all... screw all that
    PzTank likes this.
  10. Feb 5, 2019 at 7:25 AM
    Thebubble
    Thebubble Well-Known Member
    Southern California
    2006 GX470
    2009 Pre-Runner, V6: Totaled 2014 Tacoma 4x4, 5 speed, 4 Cylinder: Totaled 2000 Tacoma 5 Lug: Sold 2006 Lexus GX470: Wheeling!!!!!!!!!!!!!!!!!!!!!!!
    damn man! But it can be rebuilt and refinished easily.
    4x4Taco09 likes this.
  11. Feb 5, 2019 at 10:26 AM
    10taco
    Massachusetts
    You'll need the correct 'bolt' that threads into the face of the rotor, thru and into the inner hub; tightening the bolt pushes on the rotor and eventually breaks it free. Sorry, but I don't remember what size the bolt is; I was lucky enough to have one on hand. Using it on a pair of rotors pretty much destroys the bolt. Tighten the bolt some, bang on the rotor some, etc., repeat. Good luck!:thumbsup:
    PzTank and Markcal like this.
  12. Feb 5, 2019 at 10:42 AM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 Super White S/C DCLB TRD SPORT
    Jesus Christ!
  13. Feb 5, 2019 at 5:27 PM
    TreeFortRichard
    Brian
    There is a bolt hole in the front of the Rotor that accepts an M8x1.25mm nut. I used my impact wrench and VERY carefully...tap trigger...tap trigger...drove the bolt in there to get my Rotors off AFTER spraying PB blaster inside the openings and letting it sit and then hitting it with a sledge hammer a few times...The left front came off fine...It will be a drive...drive...drive...POP rotor comes off...The right front snapped the bolt the first try but I was using the same bolt again. I imagine the bolt you use is going to get destroyed. It's the same size that fits the skid plate I think because I happened to have some extras from when they snapped once...Just use an impact wrench or socket and be patient.
    ALSO it looks like you have a seized caliper there...see how uneven your pad wear is...that also wears your rotor unevenly...that's why I did a complete new everything...I had the same issue and did not have the time/patience to rebuild a caliper.. [​IMG]
    I went with this kit from Amazon...VERY happy. The truck stops like a champ now.. I followed all the break in procedures carefully...no issues... https://www.amazon.com/gp/product/B005FKS28C/
    Power Stop K137 Front Z23 Evolution Brake Kit with Drilled/Slotted Rotors and Ceramic Brake Pads
  14. Feb 5, 2019 at 5:54 PM
    Markcal
    Markcal Well-Known Member
    I replaced a stripped wheel stud last fall and my caliper looked almost identical to yours, with my pads wearing unevenly too, so looks like I may need new calipers when I put on new pads and rotors this spring. Would there be any way of using a c-clamp or spreader to push the piston back in to unseize it?
  15. Feb 5, 2019 at 5:55 PM
    #35
    Markcal
    What calipers did you replace the OEM's with and where did you buy them?
    Edit: Was this what you replaced the OEM caliper with? This is the aftermarket caliper
    https://www.autozone.com/brakes-and...-reman-brake-caliper-front/198799_761937_5913
  16. Feb 5, 2019 at 6:45 PM
    #36
    ryan89p
    ryan89p Member
    CO
    '10 2.7 5sp 4x4
    OP, thanks for the bolt size. Going to give it hell again this weekend. And yes, seized inner pistons on both sides - not so bad they were smoking, but definitely getting hot and I can feel them dragging.
    @Markcal - Yup, those are the calipers I got from Autozone. I think most important is that casting #, 13WG. A C clamp would work for retracting the pistons, but I picked this up off Amazon for 13 bucks.
    If you get something in there to free that piston, probably a good idea to get a new set of pins from the store and pop em in. They are cheap.
  17. Feb 5, 2019 at 7:02 PM
    #37
    Markcal
    Thanks, I bought OEM ceramic pad, rotors and pins for when I do the replacement this spring, but hadn't thought about replacing the calipers too. That looks like money well spent for spreading the pistons. I bought an air hammer to use with my compressor, with PB Blaster I was hoping that would be enough to remove the rusted pins. :fingerscrossed:
  18. Feb 5, 2019 at 10:35 PM
    #38
    TreeFortRichard
    Brian
    That's exactly what I used. Those calipers...remand. I did swap out the bleeder bolts from the remand with the ones off my originals because they are threaded the same but the originals have a larger diameter and fit on my bleeding hose..the remand once were TINY and 7mm...
    I have the spreader that @ryan89p recommended...It worked great.
    The only solution other than the remand calipers for $80 or so or Genuine OEM toyotas for like $300 EACH...
    Make sure you grease up the caliper pins with a high temperature grease...I use superlube. I then rotate and check/regrease the pins when I change my oil that way they never seize..
    PzTank and Markcal[QUOTED] like this.
  19. Feb 6, 2019 at 1:37 AM
    #39
    Markcal
    Thanks, I wished I had done the preventive maintenance on the pins, which is the key where we live, so when it does come time for a brake job it can almost go as fast as the people on YouTube. This is what I will be using when I do my brakes in the spring: Brake lube.jpg and I just order the caliper spreader.
  20. Mar 12, 2019 at 1:12 PM
    #40
    ryan89p
    ryan89p Member
    CO
    '10 2.7 5sp 4x4
    :D - Driver and Pass. calipers, rotors, pads, and a fluid flush for about $350. PB and patience... Thanks for the help in this thread.
    TreeFortRichard[OP] and PzTank like this.
