2.7L's have a 'lifelong' timing chain, correct?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Moco, Nov 4, 2013.
  1. Nov 4, 2013 at 7:21 AM
    Moco
    Moco [OP] Well-Known Member
    Eric
    NoVA
    96 Regular Cab 4x4 5spd
    Folks,
    Im getting ready to do the timing belt on my girlfriend's Accord and it got me thinking about my truck. I think I have read here that our 2.7L's have a lifelong/non-serviceable timing belt. I have 188,000 miles on my motor. By all indications, she runs fine. However, I was perusing Rock Auto and they do have a timing belt kit available for the 2.7L.
    Is this someting that I should think about or take the OEM's word for it?
  2. Nov 4, 2013 at 7:36 AM
    Hansel
    Hansel Well-Known Member
    Glenn
    Arizona
    base
    My understanding is that the 2.7 has a timing chain that is good for a very long time. If the oil has been changed regularly in the past (I use synthetic), you should still be fine.
  3. Nov 4, 2013 at 7:43 AM
    Moco
    Eric
    NoVA
    Sorry, you're correct - I meant to say timing chain. I kinda want to do it as an excuse to tear into my motor.
    Im not sure about its early years, but since I've had it, the motor has gotten Mobil 5-30 every 3-5K miles.
  4. Nov 4, 2013 at 8:48 AM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    I think originally, yes it was supposed to be a lifetime part. But Toyota grossly underestimated the 3RZ's longevity and some engines have been ticking along for so long that they have managed to wear through the guides for the chain. So you really would only need to do the guides, but it's one of those "since you're already in there" situations you might as well replace the chain too for peace at mind. IIRC it is an interference engine unlike the 5VZ so if that chain jumps timing you're fucked.
  5. Nov 4, 2013 at 9:04 AM
    offrdmania
    offrdmania Taco Wagon
    Templeton, Ca
    96 Tacoma LX 4 banger
    What about the 2.4, is it any better on chains?
  6. Nov 4, 2013 at 10:04 AM
    Hansel
    Glenn
    Arizona
    base
    x2 regarding what MowTaco wrote
    Unless you hear some noise from the timing chain area of the engine, I wouldn't be too concerned yet. Maybe others on this list could give additional opinions on this.
    In MOST vehicles I have had with timing chains, the original chain was good for 250k+ miles.
    I had an 87 toyota pickup and it was making quite a racket...you could hear the "chain slap"....the guides needed replacement, so it made sense to put in a new chain at that point also.
    the 2.4 would be similar to the 2.7 regarding the timing chains. I have a 2.4 in my taco.
  7. Nov 4, 2013 at 1:05 PM
    MowTaco
    Kansas
    The 2.4 and 2.7 are essentially identical, 2.7 just has a longer stroke. So I'd think they have very similar tendencies for wearing stuff out.
    Currygoat likes this.
  8. Nov 4, 2013 at 7:26 PM
    CUtacomaTIGER
    CUtacomaTIGER Unprofessional Driver
    San Diego
    '01 4X4 SR5 Chrome Stepside
    Black Wheels Tow Hitch w/4 Pin Weathertech Floor Mats Flowmaster Deck Plate Mod Window Tint Rear Diff Breather Mod Blacked out Badges Window Rain Guards Bed Liner
    what's your source on it being an interference engine?
    the gates belt website say it isn't but yotashop.com says it is. the general consensus is that toyota chain driven engines are interference while belt driven aren't, but their isn't any certainty with regards to the 3rz-fe
  9. Nov 5, 2013 at 6:24 AM
    MowTaco
    Kansas
    My source is just remembering a few discussions on it and reaching the general consensus that you stated... Toyota uses chains if it'd be catastrophic for it to fail
  10. Mar 18, 2017 at 9:39 AM
    dashstaco4
    dashstaco4 Active Member
    Sacramento, CA
    01 Tacoma xtracab 4x4 SR5 2.7 4 cyl
    265/75R16 Goodyears with 2nd gen rims Front Rancho Quicklift RS9000 1.25" Sixity spacers all 4 Camper shell with rack Trailer hitch
    Realize this is an old thread but if anyone can explain the sound of the timing chain "slapping" or when you would most notice that sound? I have original chain and guides going on 383,000 miles. I hear a slight higher pitched vibration sound at high rpm but nothing loud or noticeable
  11. Jul 6, 2017 at 9:34 AM
    Snowman94
    Snowman94 Member
    Charlotte, NC
    2000 Prerunner 282K (sold) 2001 Limited DC TRD-OR V6
    Whoa! 383K Miles! I have the same engine you do, with "only" 205K miles. It's been running like a new engine ever since I inherited it at 61K but are there issues you've run into I should be aware of as the miles build?
    Done all regular maintenance, no suspension work yet.
  12. Jul 6, 2017 at 10:56 AM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    Timing chain has hydraulic tensioner of quite long stroke. It would take a lot to stretch the chain beyond the tensioner stroke. When I did the head gasket around 302 miles I inspected the chain, the tensioner and the part the tensioner is pushing the chain. From my observation it was still good for a million miles or so. I changed oil (dino oil) every 5k miles (that was about 3-4 months while I was using my truck for my work commute). So I guess if you run a truck on sludge then you may need to replace tensioner, but I think it still be the last thing to go.
    Regarding the chain I've been taught to check the chain by checking how much it can lean sideways. After 300+ miles the chain was still with very little sideways movement. That is very good I recon.
    cruiserguy and Snowman94 like this.
  13. Jul 7, 2017 at 10:04 PM
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    The timing chain guides and tensioner were perfect on my 2.7 when I pulled the head at 325k. They were no longer perfect after I forgot to tighten the cam gear bolt and snapped the chain. All my valves were still fine after snapping the chain so it doesn't appear the 2.7 has any interference with pistons and valves
  14. Jul 8, 2017 at 8:04 AM
    Indy
    Indy Master of all I survey.
    Sometimes you get lucky. Both the 2.4 and 2.7 are interference engines.
    The chains will last a long time, they have a lot of self adjustment. I wouldn't take apart the engine just to look at it without some indication there is a problem.
  15. Nov 29, 2017 at 4:13 PM
    austin2009
    austin2009 Well-Known Member
    Austin
    Boise, Idaho
    Lifted and Locked 09 2.7L 2TR 4x4 5 Speed
    DRIVETRAIN- -4.56 Nitro gears -ARB rear locker -SPC UCA's -Fox 2.5" RR fronts/650lb coils -Bilstein 5100's rear -1.5" AAL -285 BFG KO2’s -16x8 MK6’s ARMOR- -ABR bumper -BAMF LCA skids -Cali Raised sliders RECOVERY- -Smittybilt XRC 9.5k synthetic winch -ARB OBA -Factor 55 Pro Link, Expert STEREO- -Pioneer head unit -Rockford T series speakers -Rockford 500 watt amp -Rockford P2D4 8" sub LIGHTING- -Calirasied ditch lights -Caliraised amber fogs -Hella Black Magic’s -Blue Seas fuse panel
    Sorry to revive an old thread. I’ve got a 2009 2.7l, I’m assuming the chain standards are the same as the first gens? That being a “lifetime” chain. Mines only got 107k on it. Thanks guys!
  16. Nov 29, 2017 at 5:07 PM
    Taco302
    Taco302 Well-Known Member
    Greenbow, Alabama
    2003 2.7L 5 spd 4x4 xtracab
    I have 150k something on my 2003...until i hear it get noisy i will leave her alone...
    austin2009 likes this.
  17. Dec 1, 2017 at 2:55 AM
    Indy
    Leave it alone unless there is an issue.
    COMAtized99 likes this.
  18. Dec 1, 2017 at 7:46 AM
    ghs57
    ghs57 Well-Known Member
    Chops
    Catskill Mts. NY
    '17 Grey TRD OR xtracab 3.5L 4WD
    Pretty much stock right now
    If it ain't broke, don't fix it.
  19. Dec 4, 2017 at 12:44 PM
    Koa Boy
    Koa Boy Member
    Rob
    2001 Tacoma 4dr
    none yet
    Yikes , I got 331K on my 2.7 Runs like New .
  20. Jul 15, 2021 at 3:47 AM
    Labwagn
    Labwagn Active Member
    Hi all.
    I realize this is an old thread, but can someone tell me what it might cost to have the chain and tensioner replaced by an independent mechanic shop (i.e. not a dealership). This would be a useful piece of information to file away for future reference.
    Thanks in advance for any feedback.
